Water cooling case suggestions
Juggalo23451
78 (0.02/day)
Aurora,Co
System Name Case Labs TH10 #1
Processor Intel 970
Motherboard Evga 4-way classified
Cooling heatkiller cpu,koolance gpus, ek chipset block
Memory Mushkin
Video Card(s) Gtx590 x2
Storage 129ssd/2tb hdd
Display(s) Samsung 2343 x3 (nvidia surroound)
Case Case Labs TH10
Audio Device(s) Creative Sound Blaster X-Fi Titanium Fatal1ty Pro Series Sound card -
Power Supply 1000hx (temp)
Software Windowa 7 pro x64
Benchmark Scores http://3dmark.com/3dmv/3315724
CASE LABS
MH10 -holds 360 rads
TH10 4 480 rads put 6 480 rad in if you want to
STH10 -480 rads
Cooler Master Cases
HAF932- 360 rad top
HAFX- 360 rad top
ATCS 840- 360 rad top rad on the HDD cages
COSMOS II- 360 rad top, or 480 top modification required. 240 rad bottom
CM690- 240 rad with modification
Storm Scout -360 rad with modification
Cosmos S- 360 rad top
SILVERSTONE
TJ07- 480 rad and 240 rad bottom
TJ11
LIAN LI
PC-P80-360 rad
Tyr PC-X2000F- 360 rad front
PC-A77(B)-240 rads modification
Lian-Li PC-V2120-360 rad on top and 280 in the front
NZXT
switch 810
Tempest EVO-240 rad thin
CORSAIR
800D-360 rad top, 240 rad bottom with modification
700D- 360 rad top, 240 bottom with modification
DangerDen
Waterbox -240 rads
Tower 29- 480 rad
LDR Tower 29 Double wide-480 rads
Juggalo23451
78 (0.02/day)
Aurora,Co
Processor Intel 970
Memory Mushkin
Case Case Labs TH10
fixed the last pic sorry about that
1,585 (0.28/day)
Los Angeles/Orange County CA
System Name Vulcan
Processor i6 6600K
Motherboard GIGABYTE Z170X UD3
Cooling Thermaltake Frio Silent 14
Memory 16GB Corsair Vengeance LPX 16GB (2 x 8GB)
Video Card(s) ASUS Strix GTX 970
Storage Mushkin Enhanced Reactor 1TB SSD
Display(s) QNIX 27 Inch 1440p
Case Fractal Design Define S
Audio Device(s) On Board
Power Supply Cooler Master V750
Software Win 10 64-bit
Very nice list. Thanks.
Juggalo23451
78 (0.02/day)
Aurora,Co
Processor Intel 970
Memory Mushkin
Case Case Labs TH10
4,013 (0.71/day)
This list will be helpful to many, and is quite comprehensive. I love that you put pictures with each entry.
Also, I'm pretty sure the Switch 810 is a 360 rad up top, with mods a 480, and a 240 in the bottom with no mods. It looks to be the sweet spot, with the M8/M10 at the extreme user end.
Juggalo23451
78 (0.02/day)
Aurora,Co
Processor Intel 970
Memory Mushkin
Case Case Labs TH10
yeah case labs is definitely for the enthusiast
4,013 (0.71/day)
The M8 has been my dream case since it was debuted over at OCN, but I can't justify kicking my 700D to the curb, yet. The video for the Switch 810 shown at NewEgg makes it seem very impressive, and maybe the most user friendly water cooling case to date.
Juggalo23451
78 (0.02/day)
Aurora,Co
Processor Intel 970
Memory Mushkin
Case Case Labs TH10
Yeah I have the TH10
231 (0.05/day)
Ohio
System Name Cogito Ergo Switch
Processor i7 3930K @ 4.8Ghz
Motherboard Asus Rampage IV Extreme
Cooling Custom Water (CPU/MB/GPU Blocks, 420+240rads PP)
Memory 16GB G.Skill Ripjaws Z 2133 9-11-10-27 @ 2380 9-10-10-28
Video Card(s) EVGA GTX670 FTW 2GB SLI @ 1344core/7648mem + EVGA 650Ti PhysX
Storage Samsung 830 256GB SSD (Boot) + 1TB WD10EZEX (Games/Apps) + 1TB WD10EALX (Prog) + 2x 320GB WD/HGST
Display(s) Dell U2412HM + U2312HM + 2x P2212Hbe + Viewsonic 21.5" 1680x1050
Case NZXT Switch 810 White - MODDED
Audio Device(s) Creative X-Fi Titanium HD PCI-Express
Power Supply NZXT HALE90 850W - Custom Sleeved Cables (White, No Heatshrink)
Software Windows7 Pro x64
Switch 810 in white! I got one and that is the same color scheme I am going for: white and black. Ordering some NZXT Individually Sleeved Extension Cables in white, 1/2"ID Tygon Tubing in white, and everything else black. I am thinking it should look wicked...
I was ready to press "order" on the Caselabs TH10, but then I saw the Switch and loved it, not to mention the fact that I got it plus a HALE90 850W modular PSU for less than 1/2 the price of the TH10, and I have a lot more money to put inside the case. I will still be ordering one, as after seeing it in person there is no going back, but I have pushed back the purchase until Christmas or so.
Regarding the Switch 810:
- it can hold up to a 420mm radiator (3x140) in the top in push-pull
- it can hold a 280, 240, 140, or 120 with any fan configuration if you remove the bottom drive bay (120/140 keeps bottom drive bays)
- Can hold a 140 or 120 in rear exhaust fan port, and with the "sliding fan mount" can fit push-pull yet still clear most boards
I have been trying myself to figure out the best way to set up rads... 140x3 in top + 140x1 rear + 140x1 bottom? 140x3 top + 240/280 bottom? I just don't want to lose 3 drive bays, as with 4x 5.25 bays I am limited to one ODD with a bay res, as the top bay is off limits with a 3x140 rad :/ Would a 3x120 be better, or could I fit a fan controller in top while still using the 420mm rad, 2bay res, and BD-Burner? Or should I forgo the bay res and get a pump-top, and try to find somewhere to mount it?
I have been studying liquid cooling for like 6 months now, and I still feel like I know nothing! The market, the products, and the philosophy has changed so much in the past few years it's like I am starting from scratch!
1,980 (0.39/day)
Mainland Britain
System Name H2o Box
Processor Intel(R) Xeon e5-2690 v2 Stock 3.300 GHz stock
Motherboard MSI X79A-G43 Plus (MS-7760) v3
Cooling CPU EK & Phobya G-Changer 360 V2.0 RAD H2o VGA "AlphaCool M18" Hybrid [pump replaced 18/8/21]
Memory G.Skill TridentX 16Gb 11-12-12-32 2T @ 1866Mhz [locked]
Video Card(s) Zotac GTX 1080ti AMP EXTREME
Storage HyperX Fury 120GB & Savage 480GB SSD, Seagate 250GB,250GB 7200rpm Kingston 64GB SSD
Display(s) Asus TUF Gaming VG32VQR 2560*1440 165Hz VA Panel
Case Corsair O-800D
Power Supply Be Quiet! [Dark Power Pro 11] 1200W CM replaced [7-4-2017]
Mouse Zelotes T-90
Keyboard K66 Mechanical US Layout
Software Win 10 Pro 64Bit v 20H2 / OS [build 19043.1237] WFEP 120.2212.3530.0
Juggalo23451
78 (0.02/day)
Aurora,Co
Processor Intel 970
Memory Mushkin
Case Case Labs TH10
When selecting a case you have to look at how much cooling you need/ want. A 360 rad can easily handle a cpu and gpu with no probelm. If you need help/one on one about water cooling send me a pm.
3,405 (0.59/day)
Brunswick, GA
System Name Haz0
Processor i7-2700K
Motherboard Gigabyte Z68X-UD3H-B3
Cooling Chicken Stock
Memory 16GB G.Skill Ripshits X 1600MHz
Video Card(s) Sapphire 5850
Storage Kingston 128GB SSD + WD Black 640GB + 2x 1.5TB
Display(s) 24" Acer G245HQ + 19" Lenovo L194
Case Antec NSK-4482 Orangified
Audio Device(s) X-Fi XtremeGamer
Power Supply Corsair TX750W
Software Windows 7: Electric Boogaloo
NZXT Switch 810. You will not find a more capable watercooling case for the price.
231 (0.05/day)
Ohio
I just picked up a brand spanking new Swiftech Apogee HD WaterBlock (white top), 2x Bitspower compression fittings, a Scythe Kaze Slipstream 1900rpm fan, and 2x 120mm fan grills for $40 and change! I could have gotten a Swiftech 3x120 "QP" rad for $55 but I don't know if I should get the higher fin count XP rad? I would think that having a higher fin count rad with 6x of the aforementioned fans in push pull would be significantly better...?
I can also get the MCR220 Drive rad (no pump) for $50,and the 120mm rad for $35... What do you guys think? And what about the Swiftech block mini reservoir? Good? For $23? All I'd need after that is the tubing (Primoflex white 1/2"ID?), and a pump! All these parts are brand new, too!
Juggalo23451
78 (0.02/day)
Aurora,Co
Processor Intel 970
Memory Mushkin
Case Case Labs TH10
this should be posted in a different thread or you make a new one. slipstreams are garbage for rads
HammerON
The Watchful Moderator
8,400 (1.44/day)
Up North
System Name Aki
Processor AMD 7800X3D
Motherboard ASUS ROG STRIX X670E-A
Cooling MSI MAG CoreLiquid E360
Memory Patriot Viper Elite 5 32GB 6200
Video Card(s) PNY RTX 4090 XLR8
Case Corsair 5000D Airflow
Audio Device(s) On-board
Mouse Roccat Kone Pure
Keyboard ASUS ROG Strix Scope II Wireless
Software Win 11 Pro
Nice list of cases capable of a water setup. Thanks for the pics as well:toast:
231 (0.05/day)
Ohio
Sorry about that, I was excited and just wasn't paying attention :/
I realized after the fact, but it won't let me remove the post. Again, my apologies.
727 (0.12/day)
O'fallon Mo.
Processor Intel I7 4820k EK Supremacy Nickel Waterblock
Motherboard Asus Rasmpage IV Extreme
Cooling Alphacool UT60 560 Radiator
Memory Kingston Hyper X 16gb 2400
Video Card(s) MSI GTX 580 Heatkiller Waterblock - EK Backplate
Storage SanDisk Ultra Plus 256GB
Display(s) LG 24" Flatron
Case Silerstone TJ11
Audio Device(s) Sound Blaster Recon 3Di
Power Supply XFX Pro 1000 Platimum
Software Windows 7 Ultimate 64
anyone know what thickness of a radiator the lian li v2021 can handle at the top?
