WD SATA hard drive issues.
3,603 (0.66/day)
Oregon, USA
System Name GLaDOS
Processor AMD FX-9590 X8 4.7GHz
Motherboard ASUS Sabertooth 990FX
Cooling Corsair H80i v2
Memory Corsair Vengeance 24GB (2x8GB, 2x4GB) DDR3 1600 MHz
Video Card(s) ASUS ROG-STRIX-RX580-O8G-GAMINGOC
Storage WD Blue 3D NAND 1TB Internal PC SSD
Display(s) 2 Acer S231HL 23" LED backlit LCD's on a Dual LCD stand
Case Corsair iCUE 220T RGB Airflow
Audio Device(s) Onboard - Corsair Void Pro Wireless
Power Supply Corsair 850HXi 850W
Mouse Corsair Sabre RGB
Keyboard Corsair K70 LUX RGB
Software Microsoft Windows 10 Pro 64 Bit
So today, I grabbed up a 160GB WD hard drive on Craigslist. Now, I for some reason, Windows isn't showing it, yet Windows 7 installed drivers for it successfully?
Anyone know what might be wrong?
Here's a photo of the hard drive.
5,106 (0.79/day)
Kansas
Processor Core i5 3570K
Motherboard AsRock z77 Pro4
Cooling Zalman CNPS10X Extreme
Memory 2x4GB GSkill Sniper
Video Card(s) MSI GTX970 Gaming
Storage 240GB OCZ ARC 100, Samsung Spinpoint F3 1TB
Display(s) LG 23" 1920x1080
Case Antec P100
Power Supply Antec Edge 750W
Software Windows 8.1 Pro 64
I have occasional issues under 7 if the drive is unformatted. Go into Partition Manager, see if it shows up there. If so, format/partition it there.
3,603 (0.66/day)
Oregon, USA
System Name GLaDOS
Hmmm...
Not seeing it...
theonedub
habe fidem
8,027 (1.39/day)
Northern CA, USA
System Name Erakith || AsRock NUCS
Processor AMD ThreadRipper 2990WX ES (32c/64t 3.5ghz@1.02v) || Intel i7 1360P Raptor Lake-P
Motherboard MSI X399 MEG Creation || AsRock OE
Cooling EK Supremacy TR4 Full Nickel, D5 w/ EK Top, 2X EK-CoolStream XTX 360 & Photon 270 Res || OE
Memory 32GB (4x8GB) Corsair Vengeance PRO RGB DDR4 3000|| 2x16GB Corsair DDR4
Video Card(s) Vega 64 EK FC|| Intel Iris Xe
Storage 250gb WD Black NVMe & (2) 2TB Intel 660p NVMe || 2TB Corsair MP600 Pro
Display(s) 34" Dell Ultrasharp U3415W
Power Supply Corsair HX1000
Software Windows 10 Pro x64 || WIndows 11 Pro x64
It shows up in the BIOS without issue?
3,603 (0.66/day)
Oregon, USA
System Name GLaDOS
Yup, shows up under hard drive section in BIOS. I'm very confused right now. I pretty dang sure it works, as the guy said he formatted it today and checked for errors.
5,106 (0.79/day)
Kansas
Case Antec P100
It doesn't show up even in Device Manager? Or is there a yellow triangle that may be it?
3,603 (0.66/day)
Oregon, USA
System Name GLaDOS
Nope, not showing up under device manager. only my other two hard drives are. Hmmm....
Edit- I'm going to try clearing my CMOS.
theonedub
habe fidem
8,027 (1.39/day)
Northern CA, USA
try removing and reinstalling the drive again.
5,106 (0.79/day)
Kansas
Case Antec P100
3,603 (0.66/day)
Oregon, USA
System Name GLaDOS
Cmos clear didn't work, I'll try a different SATA port now..
3,603 (0.66/day)
Oregon, USA
System Name GLaDOS
One thing I did notice is that it keeps setting itself as the boot up drive, when I unplugged it, and when I cleared my CMOS. It just now failed to install the drivers, saying that it's unplugged?
3,603 (0.66/day)
Oregon, USA
System Name GLaDOS
Okay, so I tried using a molex connector this time instead of the SATA power connector, and it's showing up under device manager, and installed the drivers right. Also showing up under disk management. (I also changed the SATA connector to a different one on the mobo.)
Still doesn't show up under next to my other hard drives in the computer window...
HALP.
theonedub
habe fidem
8,027 (1.39/day)
Northern CA, USA
Well from where you are now you just need to make a partition and the drive will show up in windows. just right click on that part that says unallocated and make a new partition.
3,603 (0.66/day)
Oregon, USA
System Name GLaDOS
Heh, wish I would've waited to see that.
I just got done install most of Windows 7 on it, now it shows up in my old install on my Seagate drive.
3,603 (0.66/day)
Oregon, USA
System Name GLaDOS
Thank you to everyone that helped me with this issue. The hard drive is now working fine. :D
3,603 (0.66/day)
Oregon, USA
System Name GLaDOS
Turns out some the issues I kept having were the SATA cable the guy included with the hard drive. Replaced it with another I had and I'm now running a fresh copy of Windows 7 on the hard drive.
