WD Shipping World's First 5 mm 2.5-Inch Hard Drive
46,808 (7.63/day)
WD, a Western Digital company and world leader in storage and connected-life products, today announced it is shipping the world's first ultra-slim 2.5-inch, 5 mm hard drives and solid state hybrid drives (SSHD), which are designed for integration into the slimmest devices and space-constrained computing environments. With 500 GB of storage capacity and models with high performance-enabling solid state hybrid drive technology, this slim product line helps to address the tradeoffs system designers often make between capacity, physical size and performance.
"With the launch of our new WD Blue 5 mm ultra slim hard drives and our WD Black SSHD products, currently shipping to OEMs, WD is delivering to our customers a variety of solutions that maximize storage capacity and volumetric efficiency, as well as performance and system responsiveness, for consumers," said Matt Rutledge , vice president of WD's client computing business unit. "Our engineering team took a clean-sheet approach with 5 mm to deliver an ultra-thin hard drive that enables a world of possibilities and applications for mobile computing and beyond."
WD designed the new WD Blue and WD Black 5 mm drives to enable new levels of device portability. The new drives are aimed to increase internal storage capacity while enabling it to fit into smaller device slots. In addition, the slimmer and more portable the device, the more vulnerable the hard drive is to user-induced stress. To battle this, WD has designed key enablers to the 5 mm form factor:
  • Ultra-slim Form Factor - 5 mm height with compact connector offers system designers a greater degree of chassis design freedom. This ultra-slim form factor reduces weight by up to 36 percent compared with a standard 9.5 mm drive.
  • Best-in-class Acoustics and Shock - WD's best-in-class acoustics use technologies that reduce noise when the drive is active or idle. The WD Blue and WD Black 5 mm drives deliver unprecedented operation and non-operation shock specifications with 400 G and 1000G, respectively.
  • Edge Card Technology - WD designed the connector and board utilizing cell phone miniaturization technology to maximize the mechanical sway space in the hard drive and ensure shock performance.
  • Edge Card Connector - WD Blue 5 mm hard drives also feature the first application of a new small form factor SFF-8784 edge connector. This new connector receives power from and interfaces with the host I/O bus via the SATA interface connector SFF-8784.
  • StableTrac - The motor shaft is secured at both ends to reduce system-induced vibration and stabilize platters for accurate tracking during read and write operations which enables consistently higher performance.
  • Dual Stage Actuator - Leading-edge enterprise dual stage actuators provide two actuators that improve positional accuracy over the data track(s). The primary actuator provides coarse displacement using conventional electromagnetic actuator principles. The secondary actuator uses piezoelectric motion to fine tune the head positioning to a higher degree of accuracy.
Price and Availability
Shipping today to select industrial distributors and OEM customers in 500 GB capacities, WD Blue 2.5-inch 5 mm hard drives, (model: WD5000MPCK) has a Manufacturer's Suggested Retail Price (MSRP) of $89.00 USD. WD Blue 2.5-inch 5 mm hard drives are covered by a two-year limited warranty.
2,067 (0.29/day)
DK
System Name Commercial towing vehicle "Nostromo"
Processor 5800X3D
Motherboard X570 Unify
Cooling EK-AIO 360
Memory 32 GB Fury 3666 MHz
Video Card(s) 4070 Ti Eagle
Storage SN850 NVMe 1TB + Renegade NVMe 2TB + 870 EVO 4TB
Display(s) 25" Legion Y25g-30 360Hz
Case Lian Li LanCool 216 v2
Audio Device(s) Razer Blackshark v2 Hyperspeed / Bowers & Wilkins Px7 S2e
Power Supply HX1500i
Mouse Harpe Ace Aim Lab Edition
Keyboard Scope II 96 Wireless
Software Windows 11 23H2 / Fedora w. KDE
Wonder how much NAND flash they put on there solid state hybrid drives....
2,558 (0.56/day)
East Europe
System Name PLAHI
Processor I5-10400
Cooling 120 AIO
Video Card(s) PNY QUADRO RTX A2000
Storage Intel 670P 512GB
Case SilverStone Raven RV03
Audio Device(s) Creative Sound Blaster Z OEM
Mouse Logitech Triathlon
Keyboard REDRAGON MITRA
Software Windows 11 Home x 64
Seagate has 8GB on both their models (laptop and desktop version). I will jump on a leg here , and guess the competition will gravitate around that number as of current moment: http://www.seagate.com/files/www-co...docs/laptop-sshd-datasheet-1784-1-1302-us.pdf
What I don't like is they pair the flash to 5400rpm drive. Basically everything that is cached out of that flash runs on the slower speed. I don't understand why not pair it with 7200rpm?
4,267 (0.69/day)
Sanford, FL, USA
Processor Intel i5-6600
Motherboard ASRock H170M-ITX
Cooling Cooler Master Geminii S524
Memory G.Skill DDR4-2133 16GB (8GB x 2)
Video Card(s) Gigabyte R9-380X 4GB
Storage Samsung 950 EVO 250GB (mSATA)
Display(s) LG 29UM69G-B 2560x1080 IPS
Case Lian Li PC-Q25
Power Supply Seasonic SS-460FL2
Mouse Logitech G700s
Keyboard Logitech G110
334 (0.06/day)
I hope they add more NAND, something like 128GB or 256GB like how Apple do with latest iMac
2,067 (0.29/day)
DK
Processor 5800X3D
Cooling EK-AIO 360
Not entirely correct - the 750 GB Seagate Momentus XT variants are 16 GB NAND flash....
701 (0.14/day)
Pensacola, FL, USA, Earth
What model #? Everything from Seagate indicates only 8 GB on the 750 GB Momentus XT.
Rebel333
29 (0.01/day)
I'm more interested to buy their new 1TB 7mm drive. Any news on that drive?
2,067 (0.29/day)
DK
Processor 5800X3D
Cooling EK-AIO 360
Sorry, You are right.
First gen was 4 gb and second gen is 8 gb
5,731 (1.10/day)
West Midlands. UK.
System Name Ryzen Reynolds
Cooling Raijintek Leto Pro
Power Supply Corsair VS 550w
Mouse Zalman ZM-M401R
Keyboard Razor Lycosa
5400rpm drives have improved on speed a lot over the last few years and am betting that with the most accessed stuff cached on the flash that this will be somewhat quicker than comparable 7200rpm drives of the same size.
