weird pc problem please help
wd90iffds
1 (0.02/day)
so the problem is my friend pc randomly freeze and every time he has to force shutdown and we tried these
switching psu
switching motherboard
switching ram
switching cpu
re install windows
resetting cmos battery
nothing fixed it. but the weird part is when he give me his pc the pc worked fine and everything good
but when i give him back the pc it freezes randomly again. he tried switching psu Caple but didn't fixed it
2,100 (0.64/day)
Processor Intel i5 8400
Storage 1TB 980 Pro
Software W11 Pro
More than likely the issue is going to require an electrician to fix.
10,970 (1.74/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Memory 64GB DDR5 6000 1:1 CL30-36-36-96 FCLK 2000
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply RIP Corsair SF750... Waiting for SF1000
Keyboard 65% HE Keyboard
look at the error log and see if anything pops up. could also be a dying graphics card.
13,633 (2.01/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
I agree with nomdeplume and it sounds like a power problem.
Every home and every computer user should have access to a AC Outlet Tester to ensure the wall outlet is properly wired and grounded to Earth ground. I recommend one with a GFCI (ground fault circuit interrupt) indicator as it can be used to test bathroom and kitchen outlets (outlets near water) too. These testers can be found for your type and voltage outlet, foreign or domestic, (like this one for the UK, or this one for German outlets) at most home improvement stores, or even the electrical department at Wal-Mart. Use it to test all the outlets in the home and if a fault is shown, have it fixed by a qualified electrician.
543 (0.44/day)
Processor Ryzen 7 9700x
Motherboard Asrock B650E PG Riptide WiFi
Cooling Underfloor CPU cooling
Memory 2x32GB 6200MT/s
Storage Kingston Fury Renegade 1TB, Seagate Exos 12TB
Display(s) MSI Optix MAG301RF 2560x1080@200Hz
Case Phanteks Enthoo Pro
Power Supply NZXT C850 850W Gold
Mouse Bloody W95 Max Naraka
switching psu
switching ram
switching cpu
re install windows
New video card and old PSU with 1/2/3 line adjustment?
*Maybe the electricity in his house is not stable/less?
10,970 (1.74/day)
Austin Texas
Case Jonsbo Z20
Audio Device(s) Yes
It could be physical damage you mentioned you "gave it back to him", did he like throw it in the back and drive down some bumpy roads?
1,778 (0.33/day)
Azalea City
System Name Main
Processor Ryzen 5950x
Motherboard B550 PG Velocita
Cooling Water
Memory Ballistix
Video Card(s) RX 6900XT
Display(s) MAG401QR
Case QUBE 500
Audio Device(s) Logitech Z623
Power Supply LEADEX V 1KW
Mouse Cooler Master MM710
Keyboard Huntsman Elite
Software 11 Pro
Check the SMART data on the drive.
43,458 (6.76/day)
switching psu
switching ram
switching cpu
re install windows
Could be power strip or electrical system in the dwelling, or monitor.
