- Feb 11, 2009
- 5,821 (0.98/day)
System Name | Cyberline |
Processor | Intel Core i7 2600k -> 12600k |
Motherboard | Asus P8P67 LE Rev 3.0 -> Gigabyte Z690 Auros Elite DDR4 |
Cooling | Tuniq Tower 120 -> Custom Watercoolingloop |
Memory | Corsair (4x2) 8gb 1600mhz -> Crucial (8x2) 16gb 3600mhz |
Video Card(s) | AMD RX480 -> RX7800XT |
Storage | Samsung 750 Evo 250gb SSD + WD 1tb x 2 + WD 2tb -> 2tb MVMe SSD |
Display(s) | Philips 32inch LPF5605H (television) -> Dell S3220DGF |
Case | antec 600 -> Thermaltake Tenor HTCP case |
Audio Device(s) | Focusrite 2i4 (USB) |
Power Supply | Seasonic 620watt 80+ Platinum |
Mouse | Elecom EX-G |
Keyboard | Rapoo V700 |
Software | Windows 10 Pro 64bit |
Ok so bit of a weird hardware issue but you never know, maybe someone here has experience with it.
I have a simple PC that I want to use as a media server type of deal, it has an i3 7100 in it, 8gb of ram and an igpu 630 I believe.
Further more a 120gb ssd with windows 10 installed on it, local account.
now this tiny pc has 2 pci slots free, one pci-e x16 and one pci-e x2.
I have an old capture card from Avermedia, the H727 and I wanted to install it in that system, I used the same drivers I downloaded eons ago on this pc and even tried the old cd that came with it.
but the problem I feel is not driver related, tis more...core...more deep then that.
Basically when that pci-e capture card is in the system (regardless of which slot I use) the PC has periodic slow downs, like every 2 seconds the system just hangs, the mouse hangs, the loading animations hang, the audio hang....and for the life of me I have no clue what could be causing it.
With the card in the pc, well, the whole thing is unusable.
With it installed Device Manager does see the card and correctly names it and claims its working fine.
Yet weirdly the software dedicated to be used with it claims no card is installed.
Now currently Im a tad too lazy to throw it in another system to see if that works without problems but for now, anyone can hazard a guess as to what is going on?
