Weird whitebar in Win11 explorer
136 (0.07/day)
Processor AMD Ryzen 5 5600X @4.8Ghz PBO 100W/60A/90A
Motherboard MSI B550-A PRO
Cooling Hyper 212 Black Edition
Memory 4x8GB Crucial Ballistix 3800Mhz CL16
Video Card(s) Gigabyte RTX 3070 Gaming OC
Storage 980 PRO 500GB, 860 EVO 500GB, 850 EVO 500GB
Display(s) LG 24GN600-B
Case CM 690 III
Power Supply EVGA SuperNOVA G2 650w
Mouse Cooler Master MM711 Matte Black
Keyboard Corsair K95 Platinum - Cherry MX Brown
Hey, Explorer on Win11 on my laptop has a weird white bar (just above the address bar) that I can't seem to remove.
Normal windows 11 explorer:
Bugged(?) windows 11 explorer:
(First screenshot is from my desktop (1920x1080 100% scaling), second screenshot is from my laptop (2880x1800 150% scaling) hence the size difference)
Any ideas how to fix this?
Thanks.
3,023 (2.04/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
anything except 100% scaling is broken on windows since it was implemented.
95Viper
Super Moderator
13,173 (2.20/day)
Maybe this will help:
Remove White Line File Explorer on Windows 10 Dark Mode
Alternate method:
How to fix White bar at the top in File Explorer in Windows 10 / 11
1 – Press Windows key and R key together from keyboard to open run.
2 – Now, write regedit in run command box and click OK.
3 – Now, go to the following path in registry editor.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Toolbar
4 – Now, in the right side , double click on locked and make sure the value is 1.
5 – Once you set the value to 1, close the registry and restart your PC.
Locked Min
This should help you resolve the problem.
136 (0.07/day)
Case CM 690 III
Alternate method:
Locked Min
Thank you, this worked. I didn't even have to restart.
