What are these weird "crackling" noises i hear inside my pc? Is it my GPU?
642 (0.11/day)
Norway, which means Amazon is not available...
System Name Winter v3.2024
Processor Intel i7 12700K (since november 2021)
Motherboard Gigabyte Z690 Gaming X (since november 2021)
Cooling Air Liquid Freezer II 360 with LGA1700 kit (since november 2021)
Memory Crucial Ballistix 2x16gb 3600mhz C16 (since november 2021)
Video Card(s) Gigabyte RTX 3060 Ti Gaming OC Pro LHR - Rev3.0 (since july 2022)
Storage 1x 1TB WD Blue SN570 SSD, 1x Seagate 4TB SATA
Display(s) 1x 55" LG C1 4k OLED, 1x Gigabyte 32" M32Q and 2x AOC 27" CG1
Case Fractal Design Define R6 (since 2018 and still working like a charm!)
Power Supply Corsair RM850x black (since august 2022)
Mouse Razor Deathadder v2 (since december 2021)
Keyboard Varmilo VEA109 v2 MX Silent Red (since august 2022)
I'm getting tired of this... I have for the first built my own pc for €2000, which a lot of money for a person like me, and for some reason, i keep hearing this weird noise inside my pc, and i cannot determine whether that is my gpu or something else that makes this sound. It cannot be my SSD's because i have disconnected everything but the M.2... So, is it the GPU that makes this sound, or? and if it is my GPU (which i bought in july or so), should i be worried? and is there a way for me to get rid of/fix that sound?
Here are the clicking/cracking noises coming from my pc (i placed my phone on top of the PSU, so it's right underneath my GPU): http://sndup.net/cfqq
You guys have helped me so often before, and since im stuck once again, i hope you lot can help me out with this one as well. PS: I wasn't sure if i should've posted this within the GPU-section or Gen. Hardware, but since i don't know what makes this sound, i posted it here... Pardon if that was wrong.
3,021 (2.53/day)
Motherboard Apple proprietary
Cooling Apple proprietary
Display(s) LG 27UL850W (4K@60Hz IPS)
Case Apple proprietary
Mouse Apple Magic Trackpad 2
Software macOS Sonoma 14.5 (with latest patches)
My PC makes that noise when a cable is rubbing up against a fan.
Solaris17
Super Dainty Moderator
26,622 (3.81/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
Display(s) Odyssey OLED G9 (G95SC)
Audio Device(s) Moondrop S8's on schitt Modi+ & Valhalla 2
Keyboard Monsgeek M3 Lavender, Akko Crystal Blues
VR HMD Quest 3
This sounds like a GPU or PSU fan touching something.
807 (0.75/day)
People's Republic of Banania
Processor Threadripper 3955WX
Motherboard M12SWA-TF
Cooling Arctic Freezer 4U SP3
Memory G.Skill Trident Z DDR4-3733 (2x8GB)
Video Card(s) 5700XT + 3x RX 590
Storage A lot
Display(s) ViewSonic G225fB
Case Corsair 760T
Audio Device(s) Sound Blaster Z SE
Power Supply be quiet! DPP12 1500W
Keyboard IBM F122
Software 10 LTSC
It sounds like an early 1900s mechanical relay ^^
Of course there are none inside a computer so it has to be a loose wire touching a fan, check the graphics card and PSU.
11,559 (5.55/day)
Midlands, UK
System Name Nebulon B
Cooling be quiet! Dark Rock 4
Storage 2 TB Corsair MP600 GS, 2 TB Corsair MP600 R2, 4 + 8 TB Seagate Barracuda 3.5"
Mouse Logitech MX Master 2S
Keyboard Logitech G413 SE
1. As others have said, check if a cable is touching a fan.
2. If everything is clear, try to tilt the pc on its side. I used to have a graphics card with a loose fan hub that made the same noise when the fan started up or ran below a certain rpm with the card in the traditional downward facing position. It wasn't a failure point, just a bit annoying.
3,266 (2.40/day)
Slovenia
Processor i5-6600K
Motherboard Asus Z170A
Memory 16GB DDR4-2400
Video Card(s) IGP
Storage Samsung 850 EVO 250GB
Power Supply Seasonic G-360
Software Oldwin
Yes, the fan can be wobbly, so the blades rub against a cable or another object some of the time, but not all of the time.
I'd try to stop the fans with my hand for a short while, one by one - those that are reachable of course, you can't do that to the PSU fan.
230 (0.19/day)
Scotland
System Name Scan 3XS System
Processor Intel Core i7 11700K
Motherboard ASUS TUF GAMING Z590-PLUS WIFI
Cooling Corsair Hydro H150i ELITE CAPELLIX RGB
Memory 16GB Corsair Vengeance RGB PRO
Video Card(s) 10GB EVGA GeForce RTX 3080 XC3 ULTRA GAMING
Storage 1TB Samsung SSD 970 EVO Plus, 2TB Seagate HDD, 240GB Kingston SSD
Display(s) Samsung C32JG5x Curved, 1080p, 1920 x 1080
Case Corsair iCUE 4000X RGB
Audio Device(s) USB Speakers 2.1
Power Supply Corsair RM750x 80PLUS GOLD
Mouse Razer Mouse
Keyboard ROCCAT Horde
Software Microsoft Windows 11 Pro 64-Bit 23H2
I occasionally hear strange crackling noises coming from my pc, but i think its just one of my hdd's intensly working in the background.
12,877 (1.94/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Take the inner tube from a roll of paper towels up to your ear and use that as a stethoscope to help pinpoint the source.
1,699 (0.51/day)
North Dakota
System Name Office
Processor Ryzen 5600G
Motherboard ASUS B450M-A II
Display(s) Dell S2719DGF
Case Fractal Define 7 Compact
Power Supply EVGA 550 G3
Mouse Logitech M705 Marthon
Keyboard Logitech G410
Software Windows 10 Pro 22H2
Bouncing off @Bill_Bright's suggestion, 5-6mm flexible tubing can also work wonders if available to you.
642 (0.11/day)
Apologies for the late reply, people, but i have tried to check every possible fan, but the evil culprit seems to be my GPU! Somehow, whenever the fans start to spin, they make the noise i mentioned in my OP. It goes for all the 3 fans on my GPU. Although it was difficult to record anything, i tried to record what happens, as you can see here: https://www.veed.io/view/e47c1d89-523d-4ebb-9ff1-694b741a64f7/showcase?sharingWidget=true
As far as i can see, i cannot spot anything touching the fans, so what can be the issue then, you reckon?
1,699 (0.51/day)
North Dakota
System Name Office
Your noise really sounds like the fans on my 3050 when they spin up. My hypothesis is that the startup torque deforms the blades enough that they rub on the fan's chassis until up to speed. If true, you have some choices:
1. Live with the noise; it's not hurting anything besides perhaps your sanity
2. Disable fan stop or set a custom curve to run at all times
3. Return the card and get a different model (other units of the same model will probably exhibit the same behavior)
642 (0.11/day)
Ouch. That's exactly what i was afraid of hearing; nothing that can be done with it, unless i let the fans spin all the time...
But yeah, it's definitely not working well with my sanity, heh. I've for years tried to obtain a QUIET pc setup, and i thought that with this setup, i do have a quiet enough pc, but then it was this noise from my GPU... :/
I guess i am only left with either letting the fans spin at all time or try finding a different card and sell this one. I bought this gpu used. I have never had any issues with used GPU's until this time, but i guess it was bound to happen at some point, heh.
May i ask what did you end up doing with your GPU upon discovering the noise?
1,699 (0.51/day)
North Dakota
System Name Office
Set a custom no-stop curve. They're inaudible (to me) under 1000 RPM, so they idle at ~900.
2,207 (0.82/day)
That link has come up blocked by my antivirus software. Give me time to find out why it's showing as dangerous website.
Norton is showing this:
Report in first screenshot
Blocked second screenshot
6,040 (1.51/day)
Over here, right where you can't see me !
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Benchmark Scores PDQ
Actually, it's just those pesky nanites working to assimilate your machine into the collective, nuthin to worry about, hahaha :)
/s
642 (0.11/day)
Ah ok ,then i will try that. Any ideas/pointers on how i do that for my gigabyte 3060 ti? A bit noob with this, so any links would be appreciated. :)
Sorry about that. YT was not working for me, so i used that random site for the video. Sorry.
3,021 (2.53/day)
Gigabyte probably has a utility for this. Check their website.
EVGA has Precision X1, ASUS has GPUTweak. I use both for an RTX 3050 and RTX 3060 Ti respectively to set custom fan curves. The 3050 idles at 600 fan rpm, the 3060 Ti at 900 rpm.
12,877 (1.94/day)
Nebraska, USA
Mouse Logitech M190
If me, I would unplug from the wall, touch bare metal of the case interior to discharge any static in my body, then remove the graphics card and place it on a non-conductive surface.
Then use a wooden glue/Popsicle stick to hold a fan stationary. Then, using a can of compressed dusting gas, carefully blast each fan individually. When you are sure that fan is clean of all dust and any possible debris, remove the stick. Blast again to get the fan spinning. Do not see how fast you can get them spinning - you might over-spin them and ruin the bearings. Listen for any cracking or ticking sounds. If noise free, move to the next fan.
