What are your idle and full load CPU temps?
  • Idle<=24°C; Full Load<=39°C
    Votes: 0 0.0%
  • Idle=>70°C; Full Load>=95°C
    Votes: 0 0.0%
  • Idle=24°C; 71°C<=Full Load<=90°C
    Votes: 0 0.0%
  • Idle=24°C; Full Load>=91°C
    Votes: 0 0.0%
  • Total voters
    35
92 (0.15/day)
Dhanbad, India
System Name Om Namah Shivay
Processor AMD Ryzen 9 7900x
Motherboard Asrock X670E Steel Legend
Cooling NZXT Kraken X63
Memory Corsair Vengeance 2X16GB DDR5 6000MHz ( At stock JEDEC 4800 MHz)
Video Card(s) ASUS Dual Fan AMD Radeon RX 6700XT
Storage 500 GB Crucial P5 Plus; 1TB Crucial P5 Plus; 1TB HDD: 2TB Adata S7 Blade; 1TB Crucial MX500;
Display(s) Samsung Odyssey G4 25" (Primary); Samsung S19B150 (secondary display)
Case Lian Li O11 Dynamic EVO
Audio Device(s) Razer Blackshark V2
Power Supply ASUS Thor 850P 80 Plus Platinum
Mouse Razer Basilisk V3 (Productivity); Razer Viper 8kHz (Secondary)
Keyboard Razer Huntsman Tournament Edition
Benchmark Scores Can it run Crysis?
I know that idle temps depend on a lot of of variables like ambient temperature, cpu voltage offset, cpu cooler, case airflow, cpu thermal compound etc.
My Ryzen 9 7900x idles at 50°C at 21°C ambient with NZXT Kraken X63 mounted on it inside a Lian Li O11 dynamic EVO.
1,942 (1.06/day)
Hungary
Display(s) 29" 2560x1080 75 Hz / LG 29WK600-W
Mouse Canyon Puncher GM-20
Well since I only have a 12100F its not hard to keep it cool even with a silent ~30$ tower cooler. 'ID-Cooling SE-224-XT ARGB V3 in my case'
Even tho my case doesn't have the best airflow for CPU coolers, only bottom intake and thats mainly blocked by my GPU so ye.
Idle is around 30-32 Celsius and during gaming its between 50-55 in most games, CPU heavy games like Cyberpunk can push it close to 60 over time.
Full load like Cinebench R23 multi looping is about the same. 'looped it for 10 mins now and it stayed at 60 max'
Currently its winter where I live but even during summer the temps barely went over 60 while gaming.
2,205 (1.08/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. i7 7700k @5. 3. i7 7700hq
Motherboard 1.aorus x570 ultra 2. z270 Maximus IX Hero,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.hyperxfury 32gb @3000 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 500gb , 2 3tb HDs 2. 256gb ssd, 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. some cheapo case that should not be named.
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847 2. 1106 cb 3.cb 970
ive gone for the 2nd one, custom water loop cpu and gpu and 2x 480 rads.
1,352 (0.27/day)
[Formerly] Khartoum, Sudan.
System Name 192.168.1.1~192.168.1.100
Processor AMD Ryzen5 5600G.
Motherboard Gigabyte B550m DS3H.
Cooling AMD Wraith Stealth.
Memory 16GB Crucial DDR4.
Video Card(s) Gigabyte GTX 1080 OC (Underclocked, underpowered).
Storage Samsung 980 NVME 500GB && Assortment of SSDs.
Display(s) ViewSonic VA2406-MH 75Hz
Case Bitfenix Nova Midi
Audio Device(s) On-Board.
Power Supply SeaSonic CORE GM-650.
Mouse Logitech G300s
Keyboard Kingston HyperX Alloy FPS.
VR HMD A pair of OP spectacles.
Software Ubuntu 24.04 LTS.
Benchmark Scores Me no know English. What bench mean? Bench like one sit on?
I voted third option, though the CPU does hit 90s under extreme loads. Room ambient is 33c right now, and it's a winter evening. Can easily hit mid 40s if I didn't have an air cooler on during summers.
I miss my h50. Never saw anything reaching over mid 60s, even after 48hours of continuous video encoding.
9,340 (5.85/day)
Louisiana
Keyboard G710+x3
Option 2 for idle 30c to be exact and option 4 max load 85c to be exact
Other option numbers are pretty out of place or used because of really shitty coolers or contact idling at 40-70c is just crazy talk :laugh:
So "I don't bother" on the poll because it's unrealistic
INSTG8R
Vanguard Beta Tester
7,975 (1.11/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 2
Software Win 10 Pro x64
I can’t vote, your differentials don’t match. 35C idle 75C max load under custom water 22C Ambient
213 (0.13/day)
Filthydelphia, USA
System Name Regular PC | Server HP Z440
Processor 9700k | E5-2698v3
Motherboard Gigabyte Z390 Gaming X-CF | Stock mobo
Cooling Scythe Mugen 5 rev. B | Stock HS
Memory 32 GB (8x4) | 112 GB (8x2 + 16x6)
Video Card(s) RTX 2070 Super | K4000
Storage 970 EVO+ 1TB | 860 1TB x2
Display(s) XV340CK x2, 1080p x2
Power Supply Corsair RM750x | Corsair RM750e
Software Pop!_OS | Proxmox
Option 2.
Because my parts are so downclocked they use less power, therefore less heat. It was so hot this summer for so long by me, I put my 2070s to 60% power (125w avg). It got annoying sweating all over my mouse and keyboard. The fps per watt is good enough to justify keeping it that way indefinitely.
freeagent
7,904 (3.73/day)
Winnipeg, Canada
Processor AMD R9 5900X
Display(s) LG 50UP7100
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
Idles cool, loads hot :D
Between winter providing cool air, and the furnace to mess it all up... every day is different :D
12,496 (1.91/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
I agree. Idle and max together just doesn't make sense. IMO, having a poll for this doesn't make sense. Simply stating actual temps (rather than a range) makes more sense.
And freeagent is correct too - there are just too many variables influencing the temps. Even time of day for me since the sun shines through my (East facing) computer room windows in the morning, but not in the afternoon.
And of course, even with identical ambient and operational environments, every model CPU is different too.
So, I very much bother paying attention to my temps. But I am not going to bother participating in the poll since (1) no option fits my scenario and (2) it really would not be informative to anyone, but me.
INSTG8R
7,975 (1.11/day)
Canuck in Norway
Mouse G502 Hero
Keyboard G19s
Well said I just know my temps are “safe” but I don‘t get any direct sun, but the current season means I use my PC to heat the room it can easily get like 16-18C in there in winter being a small room with the door closed when I’m not in there. Being a small room my PC at least in previous builds will easily warm the room to a more comfortable 20-21 with a decent gaming session.
Deleted member 185158
I can understand the lack of participation on this one.....
And I thought asking what your gear was worth is silly......
But my winter temps are much nicer than summer temps, that's for sure!
12,496 (1.91/day)
Nebraska, USA
Mouse Logitech M190
LOL I hear you on this. My problem is the HVAC thermostat is just on the other side of a common interior (uninsulated) wall from the computer room. So in the winter, after a couple hours using the computer, heat from the computer room tells the thermostat the house is warm and cozy. But its freezing! :rolleyes:
And in the summer, the heat from the computer room tells the thermostat the house is burning up - so it signals the AC to kick on, and stay on, freezing out the rest of the house! :rolleyes:
My next house will have zone heating and cooling, with the computer room its own zone.
92 (0.15/day)
Dhanbad, India
Option 2.
I too have 7900x undervolted to the limit just to keep it :cool: under idle as it would easily cross 52 degrees (at stock voltages) on idle on a hot summer day!
INSTG8R
7,975 (1.11/day)
Canuck in Norway
Mouse G502 Hero
Keyboard G19s
I have a heatpump in my living room/kitchen that is all I use the bedroom and PC room are opposite end down a hallway neither require heating The entire house has heated floors but I would never use them as they would just make my meter spin constantly...
1,524 (1.10/day)
Processor 5800X3D -30 CO
Motherboard MSI B550 Tomahawk
Cooling DeepCool Assassin III
Display(s) Dell S2721QS 4K60
A CPU temperature poll is an interesting idea, but given how many factors affect it, comparing different people's results is not much useful -- even with the same SKU.
For example, what kind of "full load" are we talking about here? Gaming load is pretty irrelevant, as it will rarely max out the CPU. With the dynamic nature of games, you won't ever get the same result unless testing the same specific scene under the same strict conditions. And even then the temperature may vary run to run.
OTOH, quoting CPU temperature in something like Linpack Xtreme is equally useless. Linpack may be helpful in finding the limits of your cooling solution, or verifying an overclock, but it does not resemble any kind of practical load. As such, it's irrelevant to 99.99% of users.
And of course CPU temps will vary with your ambients, type of cooling, case model and airflow, fan curve, the number of apps running in the background, power plan settings, whether the CPU is at stock or not, etc.
At the very least, we should specify the room temperature when the measurement was taken, the cooling solution used and CPU settings. For load temps, the software used to test them must be named.
FWIW, in a 25c room, my 5800X3D with -30 CO on all cores idles at 31-34c with a Deepcool Assassin III using stock fans. This was measured in HWinfo with a 1000ms polling interval, with Snapshot CPU Polling setting enabled. A third-party internet security app and MSI Afterburner polling every 1000ms were running in the background. Balanced power plan with power slider set to best energy savings was used.
In Cinebench R23 I top out at 76c with all fans running at maximum, under the same conditions.
10,506 (5.26/day)
Midlands, UK
System Name Holiday Season Budget Computer (HSBC)
Processor AMD Ryzen 7 7700X
Cooling be quiet! Dark Rock 4
Memory 2x 16 GB Corsair Vengeance EXPO DDR5-6000
Video Card(s) Sapphire Pulse Radeon RX 6500 XT 4 GB
Storage 2 TB Corsair MP600 GS, 2 TB Corsair MP600 R2, 4 + 8 TB Seagate Barracuda 3.5"
Mouse Logitech MX Master 2S
Keyboard Logitech G413 SE
Something must be wrong with your power saving settings. My 7700X idles at 35-36 °C with a be quiet! Silent Loop 2 280 mounted as intake in a Kolink Citadel Mesh.
freeagent
7,904 (3.73/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
Mine?
:laugh:
Just kidding. I cracked a window while I cleaned the litter boxes :D
886 (0.58/day)
System Name S.L.I + RTX research rig
Processor Ryzen 7 5800X 3D.
Motherboard MSI MEG ACE X570
Cooling Corsair H150i Cappellx
Memory Corsair Vengeance pro RGB 3200mhz 16Gbs
Video Card(s) 2x Dell RTX 2080 Ti in S.L.I
Storage Western digital Sata 6.0 SDD 500gb + fanxiang S660 4TB PCIe 4.0 NVMe M.2
Display(s) HP X24i
Case Corsair 7000D Airflow
Power Supply EVGA G+1600watts
Mouse Corsair Scimitar
Keyboard Cosair K55 Pro RGB
23.5c idle
max load in what ? Y-cruncher 84c-88c / prime95, small FFT's 82c, Lare FFT's 59c, Blend 65C/ coredamage 83c Intel burntest 72c /CinebenchR23 72c
92 (0.15/day)
Dhanbad, India
I have tried reseating the heatsink with arctic mx-5 paste but the temperatures during Summers are insane here ( 45 degrees + even in a hot October day). It's also the case with my laptop which frequently thermal throttles. But I will reseat the pump once again when I get the time.
My case airflow is fine btw.
337 (0.06/day)
India
System Name Home
Processor Ryzen 3600
Cooling Bykski Ryzen Waterblock + BlackIce Pro 360 radiator + D5 variable pump + Corsair HD120 x 4
Memory 16 GB G.Skill RIPJAWS @ 4000Mhz 18-22-22
Video Card(s) ASUS Strix 1080Ti with Bykski Waterblock
Storage 2x 970 EVO Plus 1tb + 960GB Sandisk Extreme Pro SSD + 4TB WD Black + 3 TB Other
Display(s) Samsung 40KU6300 UHD TV
Case CoolerMaster HAF-X
Audio Device(s) ASUS Xonar Essence STX + Audio-Technica ATH-M50x
Power Supply Corsair RM850
Mouse Logitech G304 + Razer Goliathus Speed mouse pad
Keyboard Razer BlackWidow Chroma RGB
VR HMD Oculus Rift CV1
Software Windows 10/High Sierra Dual Boot
My Ryzen 3600 stays at around 45c idle and goes up to 83c on custom water loop and that with thermal grizzly conductonaut.
92 (0.15/day)
Dhanbad, India
Yes you are right and I knew that there are various factors in play here but that's not the point here. It's just to know what cpu temperatures people are ready to tolerate and if they like to stay under or go over the so called Tjmax (Max junction temp) of their silicon. I am personally obsessed with temp and power limits of these modem chips.
Thanks for sharing your opinion btw.:peace:
10,506 (5.26/day)
Midlands, UK
Do you have C-states enabled in the BIOS? What are your windows power saving settings? What are your idle clocks and power usage?
196 (0.14/day)
Hungary
System Name Main rig
Processor AMD Ryzen 7 2700 @ 3.5 GHz/1.18750 V|SoC 0.9 V
Motherboard ASRock Fatal1ty B450 Gaming-ITX/ac |BIOS 3.80
Cooling Noctua NH-D9L
Memory 2 x 8 GB G.Skill Ripjaws V DDR4-3600 @ 3200/C18-18-18-36|1T /1.25 V
Video Card(s) EVGA GeForce GTX 950 SC+ ACX 2.0 2 GB GDDR5
Storage 500 GB Crucial MX500|1 TB Crucial MX500|250 GB Intel 510|128 GB Netac N600S|6+2 TB WD Purple
Display(s) 2 x LG 24GM77-B @ 144 Hz, DAS on, Motion 240 off | 1 x Icy Box VESA arm @ pivot
Case Fractal Design Define Nano S (no window, 1 x Noctua A14 PWM + 1 x Noctua NF-S12B redux-1200 PWM)
Audio Device(s) Edifier R1700 BTs
Power Supply Seasonic Prime Fanless PX-500
Mouse HSK|Hati S|Hati M Ace|Skoll SK-S|Pulsar Xlite|MM710|MM730|NP-01|Viper M.|Krait|MX300|MX500 etc
Keyboard Ducky One 3 TKL |One 3 SF|One 2 Horizon|Miya Pro|Akko 3068B Plus|Huntsman TE|K70 Pro Mini WL etc
VR HMD 3xShidenkai XS|Zero Classic XS|Hien XS|Raiden XS|P-51|Turbulence Teal SE|Talent L|2xAllsop XL etc
Software MS Windows 10 Home x64
Benchmark Scores over 9000
Idle is 52-54 °C for an AMD Ryzen 7 2700 @ 3.5 GHz / 1,875 V | SMT on | SoC 0,9 V, but it never really gets above 65 °C, and haven't done excessive full load testing. It has a Noctua NH-D9L on it with HT-01 thermal paste.
A Noctua NF-A14 PWM fan in the front, a Noctua NF-S12B Redux-1200PWM fan in the back, and every fan is doing 300-450 rpm. The case is a Fractal Design Define Nano S (w/o glass side), so it's not geared towards awesome temps.
Mind you, most of the time I know the PC is running, beacuse I can see that the power LED is active.
11,878 (2.27/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
Max 85°C most of the day, GPU at 45°c most of the day fully loaded but GPU down tuned with custom 2x360 rad.
1,064 (0.18/day)
FWIW, my R5 3600 is currently loading at about 72°C doing F@H in a room that's about 20°C ambient. Cooling is a Thermalright Silver Arrow T8.
It could be running cooler, but I sleep in the same room as my computer, so the fan isn't set to go super fast - just around 1200RPM.
Idle temperatures aren't something I pay close attention to, but iirc it's usually less than 45°C around the aforementioned ambient temperature.
