What does theses settings do in edit power plan in windows 10
94 (0.06/day)
Pacific Ocean
System Name Einstein Albert
Processor Ryzen 5 2600
Motherboard Asus B450-F gaming motherboard
Cooling AMD stock cooler
Memory 16 Gb DDR4 G skill 3600MHz
Video Card(s) MSI RTX 2060
Storage Samsung 970 evo plus 1 TB
Case Nzxt h510
Power Supply EVGA 650 watts
Software Windows 10 version 2004
In edit power plan there are two different commands that you can click on but
both of them are different the two settings are
(Restore default settings for this plan)
(Restore plan defaults)
what does both of theses do when I click on them and are
they both the samething?
is there a difference and what do they each do
9,340 (5.28/day)
Louisiana
Keyboard G710+x3
You can test your self
Change minimum processor state to 10-15% save and exit.
Go back and use the first restore default settings for this plan and see if it restores min processor state as well.
94 (0.06/day)
Pacific Ocean
Case Nzxt h510
There two restores plans to defaults and it seems to be that the restore default settings for this plan restore the whole plan to default including the power option advance
but when I click restore plan to default it only reset the power option advance settings back to normal
does clicking on restore default settings for this plan And restore plan defaults
reset it back to default so it revert any changes
I made back to normal
19,372 (3.54/day)
It does exactly what it says... resets the selected plan back to defaults.
Again, try it and see if you are confused.
9,340 (5.28/day)
Louisiana
Keyboard G710+x3
Default minimum processor state on a balanced power plan is 5%
Changing it to 10 or 15%...
will be reverted back to 5% if the first setting sets the advanced option you alter on your second screen shot with advanced options.
If it doesn't it only changes the turn off screen option and sleep option on your first screen shot.
I use a performance power plan and leave it at default settings.
