I check the Speed Shift option in that section and that is about it. The Speed Shit Min and Max variables give you control over the minimum and maximum CPU speed. The original Set Multiplier feature that Intel used since the beginning of time no longer does anything when Speed Shift is enabled within the processor. Speed Shift Min and Max took over from Set Multiplier.
Setting Power Limit 4 to 0 seems like a good idea. Doing this disables this limit so it does not interfere with maximum performance. Intel's documentation is a little fuzzy. It was originally a current limit but on more recent CPUs, intel calls this a power limit. Some documentation shows watts and some of their documentation shows amps so not sure if it is power or current that it controls. All I know is that this limit is not necessary.
Intel had some great ideas in theory when they first released the low power 3rd Gen U series CPUs. The TDP Level allowed a U series CPU to behave like three unique CPUs. I will use the Core i7-3667U for an example. This had a default TDP of 17W. When forced into low TDP mode it would drop down to 14W and in high TDP mode it could go up to 25W. Each TDP Level usually has a unique base frequency associated with it. This gave manufacturers some flexibility so they could change the TDP Level and easily limit the CPU to less power and less MHz when running on battery power or go up to full speed and full power when plugged in. Nice idea but it never seemed to really catch on.
TDP Level was not just for mobile CPUs. A 10 core 10850K continues to support TDP-down mode. I think the TDP is reduced from 125W down to 95W in this mode. The base frequency drops from 3600 MHz to 3300 MHz. This is kind of pointless. These CPUs use turbo boost and typically run at 5000 MHz or beyond. Most users should be setting the PL1 and PL2 power limits much, much higher to prevent any power limit throttling.
Not sure what Intel engineers are still working on the TDP Level project. They probably smile every year when they are cashing their pay checks. I am sure no one at Intel knows what this design team is really working on besides their table tennis skills.
Power Balance allows one to balance the power consumption of the CPU cores with the Intel GPU. Another great idea in theory. When you have a U series CPU with a limited power budget of 15W, there are some apps like games that can benefit if you allow the Intel GPU to use 10W and the Intel cores to 5W. There are probably some other apps where the opposite is true. In the real world, most users would just increase both the PL1 and PL2 power limits so there are plenty of watts available. This would allow both the CPU cores and the Intel GPU to run at full speed.
The PP0 Power and Turbo Time Limit only applies to the individual cores whereas the PL1 and PL2 power limits apply to the entire CPU package. There is the PP0 limit for the cores and there is also a PP1 power limit that applies only to the Intel GPU. I am not sure what Intel chips use both of these limits. My 10850K ignores any changes made to the PP0 limits. I leave this limit set to 0 and 0.0010 seconds for the time limit and I do not bother checking this. A long time ago, some manufacturers were using the PP1 power limit to reduce the power consumption of the Intel GPU which limited its maximum speed. ThrottleStop has a hidden feature so you can increase and lock this power limit if you need to. The demand to control the Intel GPU was minimal so I decided not to add control of PP1 to the ThrottleStop user interface.
Now you are ready for Jeopardy if the ThrottleStop subject ever comes up.
