What GPU would you recommend for a E8600 cpu?
2,358 (1.91/day)
UK
What GPU would you recommend for a E8600 CPU?This is it here the GT 420 spins but does not boot up,the Geforce 7600gt does not spin and gets very hot.And when i had it on the board i was half way getting Vista installed and the board shut down.I was thinking something like thE GTX660 TI or the 750. i am not sure of what Radeon cards i could use ,i understand they need a lot of power.I was thinking that there might be some dust in the PCIE slot.The 750 is the most i want to pay for one.
5,027 (3.81/day)
Colorado, U.S.A.
Software Windows 11 Home
I rather like my GT1030, but be sure to get the version with GDDR5 RAM; avoid the DDR4 version.
18,585 (2.70/day)
System Name AlderLake
HD4870 / GTX 260 of that era.
Or a GT1030 as Shrek mentioned.
6,485 (4.62/day)
São Paulo, Brazil
Motherboard ASUS ROG MAXIMUS Z790 APEX ENCORE
Display(s) 55-inch LG G3 OLED
Keyboard Generic PS/2
I own one, and I tried it with an R9 Fury X, ran Tetris Effect just fine :laugh:
If you mean a modern-ish card, I guess an RX 6400 will be enough
5,027 (3.81/day)
Colorado, U.S.A.
The HD4870 has a power rating of 150w i will leave that one out.And the GTX 260 182W that one is out to.Cards from that era needed a lot of power. o_O
The GT1030 is 30W
6,485 (4.62/day)
São Paulo, Brazil
I just wouldn't buy a 1030 because the RX 6400 exists, and RDNA 2 is tons better than Pascal. But price is also a consideration, and I mean, it's an E8600, and apparently one that is already slowed down on an older DDR2 motherboard.
IMO, even a GTX 750 Ti may be a good pick, after all that one should have good compatibility with Windows XP, if running older OSes and games is a consideration.
5,027 (3.81/day)
Colorado, U.S.A.
Fair enough; I just liked not having a fan.
Toothless
Tech, Games, and TPU!
9,565 (2.47/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x32 Corsair Dominator
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
You do understand that the PCI slot will max out at 75w, and the rest will pull from PCI power cables from the PSU right? Current cards use a lot of power too. Nothing has changed.
2,358 (1.91/day)
UK
es
The one you mentioned RX64OO is a recent card.I have just seen this
ASUS GeForce GTX 660 Direct Cu II 2 GB
£30 on eBay.
The GT1030 is 30W
That is a small form factor card,and out of my price range.
Yes i do. :)
6,485 (4.62/day)
São Paulo, Brazil
2,901 (4.74/day)
Russian Wild West
System Name DLSS / YOLO-PC
Processor i5-12400F / 10600KF
Motherboard Gigabyte B760M DS3H / Z490 Vision D
Cooling Laminar RM1 / Gammaxx 400
Memory 32 GB DDR4-3200 / 16 GB DDR4-3333
Video Card(s) RX 6700 XT / R9 380 2 GB
Storage A couple SSDs, m.2 NVMe included / 240 GB CX1 + 1 TB WD HDD
Display(s) Compit HA2704 / MSi G2712
Case Matrexx 55 / Junkyard special
Power Supply Thermaltake 1000 W / Corsair CX650M / DQ550ST [backup]
Software Windows 10 and 11
I'd go HD 7570 or something like that since your MB+CPU are extremely outdated and can't fuel video cards beyond that to make any difference.
GTX 660 is rather a no than a yes, Kepler GPUs don't last long. Will probably die this year.
6,485 (4.62/day)
São Paulo, Brazil
That 7570 is just as old. Both of them are terrible purchases if you're looking for longevity of any kind (as they're 10+ years old), they're both discontinued, terrible performers, etc.
NVIDIA's legacy driver support is much better and Kepler security updates are still being regularly published
FreedomEclipse
~Technological Technocrat~
23,976 (3.75/day)
London,UK
System Name DarnGosh Edition
Processor AMD 7800X3D
Memory G.Skill Trident Z5 NEO DDR5 6000 CL32-38-38-96
Storage WD SN770 1TB (Boot)| 2x 2TB WD SN770 (Gaming)| 2x 2TB Crucial BX500| 2x 3TB Toshiba DT01ACA300
Display(s) LG GP850-B
Mouse Logitech G502 X
Benchmark Scores ლ(ಠ益ಠ)ლ
If youre interested. I might have a very old MSI 660 ti twin frozr that has seen action in multiple builds up for grabs. Still works as a backup and on an old test bench that doesnt see much daylight anymore.
2,901 (4.74/day)
Russian Wild West
HD 7000 series low-end GPUs proved to last long. Very long. And GTX 600 and 700 series run into hardware issues one by one.
Whilst this is true this will stop to matter right when the GPU itself becomes broken. That's why I recommended a less software optimal AMD solution.
1,188 (0.20/day)
With cost and power envelope in mind, a GTX 750 or 750 Ti doesn't sound like a bad option to me if you don't mind something that's not era appropriate. See if you can get another stick of RAM for that system too. That single stick is lonely.
Toothless
9,565 (2.47/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
Dude you're saying Kepler GPUs will just timely die because whatever reason. That's not how it works. They don't say "oh look it's 2023 time to off myself" because again, that's not how it works. I have a GTX560 that I stuck back in service that works perfectly fine.
Don't spread misinformation.
6,485 (4.62/day)
São Paulo, Brazil
All of them, pardon my French, are "old junk" by now. Don't think either will "die more" because they're a brand or another, really, that's quite anecdotal. I have a Quadro FX 5600 (which is a fancy 1.5 GB 8800 GTX) that works perfectly well, it hasn't even been opened... it's a 17 year old GPU. I need to look up what kind of thermal pads reference 8800's use, so I can replace them.
2,358 (1.91/day)
UK
I have got a lot of Ram,so that,s no problem. :) What do you think about MSI 660 ti twin frozr ,a guy on here from London same as me, has one for sale.Depending on how much he wants for it.
Toothless
9,565 (2.47/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
It's a good basic display that can run older/low powered games. Just know driver support is gone.
1,783 (0.61/day)
BGD
System Name Minotaur
Processor Intel I9 7940X
Motherboard Asus Strix Rog Gaming E X299
Cooling BeQuiet/ double-Fan
Memory 192Gb of RAM DDR4 2400Mhz
Video Card(s) 1)RX 6900XT BIOSTAR 16Gb***2)MATROX M9120LP
Storage 2 x ssd-Kingston 240Gb A400 in RAID 0+ HDD 500Gb +Samsung 128gbSSD +SSD Kinston 480Gb
Case NZXT H5 Flow
Mouse Asus TUF-GAMING M3
VR HMD Oculus Rift DK2
Software Win 11
Benchmark Scores Fire Strike=23905,Cinebench R15=3167,Cinebench R20=7490.Passmark=30689,Geekbench4=32885
That's a Great card much faster then 660 and twin frozr is nice cooler.....I owned one of those remember was even using for my triple monitor setup back then and it was good experience......just FYI you will need some decent(450W-500W) PSU for that card .....
1,188 (0.20/day)
If your PSU is up for the task, I don't see a problem. Power draw is around 150W under load though. Just keeping your previous post in mind.
741 (0.11/day)
GA, USA
System Name Gamer
Cooling Apogee XL, MCR360, MCP655, Micro-rez
Video Card(s) Red Dragon RX 6800 XT
Case Rocketfish (Lian Li) e-ATX
Audio Device(s) Harman Kardon HK695 2.1
Power Supply Seasonic Focus GM-750
Mouse HP Gaming wired
Keyboard Logitech G110 wired
VR HMD HP WMR 1440^2
Software Win10 Pro 64bit
I ran various GPUs with my e8600 CPU.
I used an X1900 XT (and crossfire). 650w psu
I used an HD 3870 (and crossfire). 650w psu
I used an HD 4870 until I killed the GPU.
I used an HD 6950 modded to 6970.
I used a GTX 970.
They all paired well with the water cooled e8600 CPU running between 4.0 & 4.6GHz, so keep that in mind.
The GTX 660 Ti would be a really nice option for you. Also, the 760 or 960 would be nice too if you can find a good deal.
