TechRochetMan
- Oct 27, 2019
- 22 (0.01/day)
I was looking forward to build my own pc but I'm not too sure what kind of graphics card is best for me in an 300$ budget.
Processor | Intel core i9 13900ks sp117 direct die |
Motherboard | Asus Maximus Apex Z790 |
Cooling | Custom loop 3*360 45mm thick+ 3 x mo-ra3 420 +Dual D5 pump and dual ddc pump |
Memory | 2x24gb Gskill 8800c38 |
Video Card(s) | Asus RTX 4090 Strix |
Storage | 2 tb crucial t700, raid 0 samsung 970 pro 2tb |
Display(s) | Sammsung G7 32” |
Case | Dynamic XL |
Audio Device(s) | Creative Omni 5.1 usb sound card |
Power Supply | Corsair AX1600i |
Mouse | Model O- |
Keyboard | Hyper X Alloy Origin Core |
System Name | just ordinary potato system, but dont understimate potato.. |
Processor | ryzen raven ridge 2200g, ryzen 2600 upgrade:) |
Motherboard | msi b350 pc mate, biostars a320, asrock ab350m micro |
Cooling | x2 cheap china handmade, i got plenty aigo/fantech rgb fans now heh |
Memory | klevv dual channel 8gb 3000mhz, trident 16gb 3600mhz, random ddr2 stick |
Video Card(s) | back to square, using vega 56 now:D |
Storage | wd green ssd 240gb, 3tb seagate expnasion, random laptop hdd x4, 1tb 3.5 |
Display(s) | acer vgo 22inch fullhd 75hz |
Case | cheap segotep/dazumba mid atx, alcatroz mini atx |
Audio Device(s) | genius retro wood style, harman kardon stick iii |
Power Supply | be quite system power9, powerlogic standar, voltron 300fx, thermaltake smart 1200w |
Mouse | rexus, genius ps/2, powerlogic ps/2 ball tracking |
Keyboard | rexus, random china product x3 |
Software | talking abt best software, autodesk/unity3d/notepad yes notepad!! |
Benchmark Scores | theres nothing to brag abt potato, but it can run decent 30fps fullhd with good setting:) |
System Name | Indis the Fair (cursed edition) |
Processor | 11900k 5.1/4.9 undervolted. |
Motherboard | MSI Z590 Unify-X |
Cooling | Heatkiller VI Pro, VPP755 V.3, XSPC TX360 slim radiator, 3xA12x25, 4x Arctic P14 case fans |
Memory | G.Skill Ripjaws V 2x16GB 4000 16-19-19 (b-die@3600 14-14-14 1.45v) |
Video Card(s) | EVGA 2080 Super Hybrid (T30-120 fan) |
Storage | 970EVO 1TB, 660p 1TB, WD Blue 3D 1TB, Sandisk Ultra 3D 2TB |
Display(s) | BenQ XL2546K, Dell P2417H |
Case | FD Define 7 |
Audio Device(s) | DT770 Pro, Topping A50, Focusrite Scarlett 2i2, Røde VXLR+, Modmic 5 |
Power Supply | Seasonic 860w Platinum |
Mouse | Razer Viper Mini, Odin Infinity mousepad |
Keyboard | GMMK Fullsize v2 (Boba U4Ts) |
Software | Win10 x64/Win7 x64/Ubuntu |
Don't buy any GP104 if it's not very close to $200, they aren't worth anything near $300 nowadaysgtx1070/1070ti/1080 with that $300
System Name | Bruh |
Processor | 10700K 5.3Ghz 1.35v| i7 7920HQ 3.6Ghz -180Mv | |
Motherboard | Z490 TUF Wifi | Apple QMS180 | |
Cooling | EVGA 360MM | Laptop HS | |
Memory | DDR4 32GB 3600Mhz CL16 | LPDDR3 16GB 2133Mhz CL20 | |
Video Card(s) | Asus ROG Strix 3080 (2100Mhz/18Ghz)|Radeon Pro 560 (1150Mhz/1655Mhz)| |
Storage | Many SSDs, ~24TB HDD/8TB SSD |
Display(s) | S2719DGF, HP Z27i, Z24n| 1800P 15.4" + ZR30W + iPad Pro 10.5 2017 |
Case | NR600 | MBP 2017 15" Silver | MSI GE62VR | Elite 120 Advanced |
Audio Device(s) | Lol imagine caring about audio |
Power Supply | 850GQ | Apple 87W USB-C | |
Mouse | Whatever I have on hand + trackpads (Lanchead TE) |
Keyboard | HyperX Origins Alloy idk |
Software | W10 20H2|W10 1903 LTSC/MacOS 11 |
Benchmark Scores | No. |
If I buy a used one, will it work as good as if it was new or does time affect its functionality and how good it works?for used one you can go for gtx1070/1070ti/1080 with that $300, for brand newcard i think 1660/1660ti is the best choice, im afraid you cant pick amd new tech, it cost more than $300 for rx5700 just for blower type(mostly avoided), another optional probaly just pay for used rx580($60-100) , new rx590 retail($200), or used rx56/64 if you could found cheapest one
System Name | PCGOD |
Processor | AMD FX 8350@ 5.0GHz |
Motherboard | Asus TUF 990FX Sabertooth R2 2901 Bios |
Cooling | Scythe Ashura, 2×BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED |
Memory | 16 GB Gskill Ripjaws X 2133 (2400 OC, 10-10-12-20-20, 1T, 1.65V) |
Video Card(s) | AMD Radeon 290 Sapphire Vapor-X |
Storage | Samsung 840 Pro 256GB, WD Velociraptor 1TB |
Display(s) | NEC Multisync LCD 1700V (Display Port Adapter) |
Case | AeroCool Xpredator Evil Blue Edition |
Audio Device(s) | Creative Labs Sound Blaster ZxR |
Power Supply | Seasonic 1250 XM2 Series (XP3) |
Mouse | Roccat Kone XTD |
Keyboard | Roccat Ryos MK Pro |
Software | Windows 7 Pro 64 |
Depends if it went through a miner's abuse.If I buy a used one, will it work as good as if it was new or does time affect its functionality and how good it works?
System Name | Good enough |
Processor | AMD Ryzen R9 7900 - Alphacool Eisblock XPX Aurora Edge |
Motherboard | ASRock B650 Pro RS |
Cooling | 2x 360mm NexXxoS ST30 X-Flow, 1x 360mm NexXxoS ST30, 1x 240mm NexXxoS ST30 |
Memory | 32GB - FURY Beast RGB 5600 Mhz |
Video Card(s) | Sapphire RX 7900 XT - Alphacool Eisblock Aurora |
Storage | 1x Kingston KC3000 1TB 1x Kingston A2000 1TB, 1x Samsung 850 EVO 250GB , 1x Samsung 860 EVO 500GB |
Display(s) | LG UltraGear 32GN650-B + 4K Samsung TV |
Case | Phanteks NV7 |
Power Supply | GPS-750C |
System Name | PC on since Aug 2019, 1st CPU R5 3600 + ASUS ROG RX580 8GB >> MSI Gaming X RX5700XT (Jan 2020) |
Processor | Ryzen 9 5900X (July 2022), 200W PPT limit, 80C temp limit, CO -6-14, +50MHz (up to 5.0GHz) |
Motherboard | Gigabyte X570 Aorus Pro (Rev1.0), BIOS F39b, AGESA V2 1.2.0.C |
Cooling | Arctic Liquid Freezer II 420mm Rev7 (Jan 2024) with off-center mount for Ryzen, TIM: Kryonaut |
Memory | 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MT/s 1.38V CL16-16-16-16-32-48 1T, tRFC:280, B-die |
Video Card(s) | Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (382W current) PowerLimit, 1060mV, Adrenalin v24.12.1 |
Storage | Samsung NVMe: 980Pro 1TB(OS 2022), 970Pro 512GB(2019) / SATA-III: 850Pro 1TB(2015) 860Evo 1TB(2020) |
Display(s) | Dell Alienware AW3423DW 34" QD-OLED curved (1800R), 3440x1440 144Hz (max 175Hz) HDR400/1000, VRR on |
Case | None... naked on desk |
Audio Device(s) | Astro A50 headset |
Power Supply | Corsair HX750i, ATX v2.4, 80+ Platinum, 93% (250~700W), modular, single/dual rail (switch) |
Mouse | Logitech MX Master (Gen1) |
Keyboard | Logitech G15 (Gen2) w/ LCDSirReal applet |
Software | Windows 11 Home 64bit (v24H2, OSBuild 26100.2605), upgraded from Win10 to Win11 on Jan 2024 |
as airmain alr explain clear, i will just say a bit abt used card, ex mining card isnt rly bad, the only scary case is becouse they abusing to run 12hour aday, some even push it tu run nonstop for mining, it depend our luck maybe, as for me i dont have any issue buying ex miningcard, i think 4-5times i pay for ex miner card i forgot it, those card only dirty, i just need to clean em and everything worked like a charm, anyway i prefer pay for miner card instead maniac whom do abuse the card by extremly ocing it, and play like crazy one 10hour adayIf I buy a used one, will it work as good as if it was new or does time affect its functionality and how good it works?
Why would it be less powerful?Because for 300$ it's unlikely you'll find something better used, at best you're looking at a GTX 1080/Vega 64. Why buy something old, less powerful, less power efficient with no warranty just to spare about 50$.
If you do insist on getting something used then an RX 5700 is still the best choice for 300$.
ok thx, so thats pretty much the best one you can buy in an 300$ budget
My budget is in CAD Money so it makes that pruduct go over the price expectedok thx, so thats pretty much the best one you can buy in an 300$ budget
System Name | Aliens Ryzen Rig | 2nd Hand Omen |
Processor | Ryzen R5 5600 | Ryzen R5 3600 |
Motherboard | Gigabyte B450 Aorus Elite (F61 BIOS) | B450 matx |
Cooling | DeepCool Castle EX V2 240mm AIO| stock for now |
Memory | 8GB X 2 DDR4 3000mhz Team Group Vulcan | 16GB DDR4 |
Video Card(s) | Sapphire Pulse RX 5700 8GB | GTX 1650 4GB |
Storage | Adata XPG 8200 PRO 512GB SSD OS / 240 SSD + 2TB M.2 SSD Games / 1000 GB Data | SSD + HDD |
Display(s) | Acer Nitro x27OU 27" VA 165hz Freesync Premium|TCL 32" 1080P w/ HDR |
Case | NZXT H500 Black | HP Omen Obelisk |
Audio Device(s) | Onboard Realtek | Onboard Realtek |
Power Supply | EVGA SuperNOVA G3 650w 80+ Gold | 500w |
Mouse | Steelseries Rival 500 15 button mouse w/ Razor Goliathus Chroma XL mousemat | Logitech G502 |
Keyboard | Corsair K65 Mini w/ Cherry MX brown keys | Logitech G513 Carbon w/ Romer G tactile keys |
Software | Windows 10 Pro | Windows 10 Pro |
I hear you there, CAD pricing is terribleMy budget is in CAD Money so it makes that pruduct go over the price expected
Idk why bad pricing is funny @potato580+ ? Rx 5700 is over $400 CADI hear you there, CAD pricing is terrible
thats alr good yupwell that makes my budget go to 230 US, not my fault if all around hereis calculated in Cad. I was looking at the MSI GeForce GTX 1660 Ti 6 GB GAMING X Video Card which is straight in my price expentancy, is it good or could I get a better one for the same price
Case | Dynamic XL |
Mouse | Model O- |
yes 5700 model sky rocketing, but here xt model drop sightly, i think it becouse someone manage to flash xt performance with non xt, you should praise or maybe blaming the "person" whom make it work, its agood news for gamer, & bad news for sellerAt my local store Canada computers, the reference 5700 goes for $424 plus tax. AIB cards start at 479. Xt is more expensive at over 500 for AIB cards.
