What is going with this screen
862 (1.18/day)
System Name Asus G16
Processor i9 13980HX
Motherboard Asus motherboard
Cooling 2 fans
Memory 32gb 4800mhz
Video Card(s) 4080 laptop
Storage 16tb, x2 8tb SSD
Display(s) QHD+ 16in 16:10 (2560x1600, WQXGA) 240hz
Power Supply 330w psu
I keep getting this blurry screen, I try to reset cleartype but its not working. I have updated those the intel and Nvidia drivers.
It only clears up when I restart this laptop.
6,130 (2.85/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
Nothing wrong with this printscreen...
862 (1.18/day)
Cooling 2 fans
Memory 32gb 4800mhz
Keeps running like this
18,584 (2.68/day)
System Name AlderLake
2,993 (0.52/day)
MN
System Name Personal / HTPC
Looks like monitor hardware issues...
If you take a printscreen (screen capture) and then view the file and you see nothing wrong with it, I'd have to agree that the issue appears to be some sort of hardware issue.
It could be possible the laptop/video cable is failing. I know I've heard of laptops in the past that had video cables fail/break after years of opening and closing the laptop.
862 (1.18/day)
Cooling 2 fans
Memory 32gb 4800mhz
The screen goes back to normal after I restart it.
2,964 (2.06/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
does it look like this in safe mode? if yes it is pretty much hardware damage.
13,430 (1.99/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
And then how long does it stay cleared up? Does it seem like it might be associated with opening and closing the laptop's clamshell case (suggesting a loose connection or pinched cable)?
Connect an external monitor to the laptop and see if the problem appears there too. If it does, the problem is with the laptop's graphics solution. If the external monitor looks right while the laptop screen does not, the laptop display screen is the problem.
If it appears to be a loose connection or pinched cable to the laptop screen, it is an easy fix "IF" you feel comfortable disassembling the laptop. If you don't feel comfortable taking it apart (and re-assembling it without pinching - or re-pinching - cables or causing other collateral damage), take it to a shop. There is no shame in that.
862 (1.18/day)
Cooling 2 fans
Memory 32gb 4800mhz
Its hard to tell, its so random at times. I thought it was the cleartype when I post a few months back. It seems its getting worse and worse this week. I'm more than comfortable with taking this laptop apart.
Deleted member 185088
Maybe check the cable, it shouldn't be difficult to find and reseat.
13,430 (1.99/day)
Nebraska, USA
Mouse Logitech M190
Yeah, intermittent problems you cannot duplicate on demand are always the most difficult to troubleshoot.
That said, you didn't answer my first question. After you reboot and the problem goes away, how long does it stay cleared up? And when it does return, is it out of the blue while you are using the computer? Or is it upon booting? Or when you open the case?
862 (1.18/day)
Cooling 2 fans
Memory 32gb 4800mhz
After I reboot it, I left the laptop open, sometimes the issue is still around but as right now, its back to normal. It stays cleared up for a random amount of time, few hours to a few days, but it does seem to be picking up for the pass 2 weeks.
I opened up the laptop, checked all the cables leading to the screen. Everything seems to be normal, no bents on any cables I can see. I'll see if I can flip the motherboard over on to its other side.
