what is involved in getting set up to burn 8.5gb capacity?
2,817 (0.44/day)
louisiana
Processor Intel Core i5-12400F - Core i5 12th Gen Alder Lake 6-Core 2.5 GHz LGA 1700 65W
Motherboard GIGABYTE B760M--DS3H LGA 1700 DDR4
Cooling CPU - Thermalright Assassin King 120 SE / Case - cooler master 120mm rear case fan (Air cooling)
Memory CORSAIR Vengeance LPX 32GB (2 x 16GB) 288-Pin PC RAM DDR4 3200 (PC4 25600)
Video Card(s) GTX1060 6GB
Storage Samsung 1 TB 870 EVO SSD Main Drive / Samsung 500 GB 870 EVO SSD Backup Drive
Display(s) ASUS 23" LED Monitor
Case COOLER MASTER Centurion 5 (silver & black)
Power Supply CORSAIR RM-750X 750W Modular ATX
Software Windows 11 Pro 64bit Edition
as we all know, media has passed up the 4gb capacity of dvd and unless you want a pricey "special" burner and a special player to play it in, there just isn't any other option then dual layer burning.
lately I have been seeing 8.5 gb dvd that seam to be one sided disks (frosted on one side for labeling) so who out there knows about this stuff?
is there a basic simple universal media you can buy and burn or does it involve "special equipt only" to burn it and play it?
I burn my own dvd and cd all the time and I want to do the same with a few over capacity files without being forced to get special burners and players or having to keep them on flash drives or external hard drives
de.das.dude
Pro Indian Modder
8,826 (1.71/day)
Stuck in a PC. halp.
System Name Monke | Work Thinkpad| Old Monke
Case Ant Esports Tempered case | Thinkpad | Antec
Audio Device(s) Logitech Z333 | Jabra corpo stuff
Mouse Logitech G400 | nipple
VR HMD ;_;
i have had an asus one thats cheap. works, no issues.
436 (0.11/day)
Riga
System Name Pukeko
Processor Ryzen 5 3600
Motherboard MSI B450 Gaming Plus Max
Cooling Hyper 212 Black Edition
Memory Corsair Vengeance LPX 16GB 3000MHz DDR4 CL15
Video Card(s) Asus RX 5600 XT TUF Gaming X3 OC
Storage XPG SX8200 Pro 256GB, Crucial MX500 1TB
Display(s) 2x ASUS TUF Gaming VG249Q
Case NZXT, H510i, Matte Black/Red, Tempered Glass
Audio Device(s) TUF Gaming H3
Power Supply Seasonic PRIME Ultra 550W Gold
Mouse Touchpad + Logitech MX518
Keyboard Cooler Master, CK 350, Outemu Red
Benchmark Scores 7,42,69 and 666
There is no such thing as a 8.5Gb single layer DVD. Even if there was, you would need a special burner and reader for it.
The optical drive I have can write 8.7Gb to a standard DVD9, can google XGD3 on how to do it. Hint: Flashing. But I doubt it has any use for you.
newtekie1
Semi-Retired Folder
28,472 (4.16/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Most modern basic DVD burners will burn 8.5GB dual-layer DVDs, you just have to look at their specs and make sure it lists DVD DL. The down side is that they usually have lower burn speeds than single layer DVDs. This drive for example. It lists DL, so it will burn Dual Layer discs, but only at 8x. It can burn single layer discs up to 24x. So you're burning more data, at a slower rate, so expect burns to take a lot longer.
The other down side is the cost of the discs themselves. For a good brand name disc you are going to spend about $1 a disc compared to about 20¢ a disc for single layer.
This is why if you are going to burn more then 4.7GB on a regular basis, it is probably best to invest in a Blu-Ray burner. You can pick the drives up for $50-80, like this one, but you can get 50 packs of BD-R discs for $25.
2,817 (0.44/day)
louisiana
thanks, I had suspected if you burn double sided then you cant just use it in any random player, you need a dl burner or "special" dvd rom to play them in but I was hoping something had changed in that regard.
not sure if I'm ready yet to spend $60 on a blue ray DL burner just yet.
the $1 a disk cost isn't terrible, after all it wasnt long ago we paid 50 cents a disk for regular dvd media
2,817 (0.44/day)
louisiana
this is the dvd disk I was looking at and why i had to ask about it http://www.newegg.com/Product/Product.aspx?Item=9SIA6UM3AB0269&cm_re=8,5_gb_dvd-_-9SIA6UM3AB0269-_-Product
it clearly only has one reflective side. I thought you could only burn to the reflective side since the white side are not transparent so how can anything be written and read from them?
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.54/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
DL disks work in most DVD players.
Dual layer is literally dual layer. The lens focuses to read/write to two separate data layers on the disk. Bluray is capable of four layers.
I think you're thinking double-sided disks where data exists on both faces. There are no double-sided players out there. To gain access to the other side, the disk has to be removed from the player, flipped, and inserted.
I use Verbatim disks and write at the slowest possible speed (usually 2.4x). Writing dual layer disks at high speeds often result in failed burns.
467 (0.14/day)
South Africa ,Lions Everywhere..
System Name Ground Control
Processor Intel i5 2500k 4 Ghz
Motherboard MSI P67A-GD80 B3
Cooling Cooler Master Hyper 212x
Memory 2 x 4GB DDR3 1600mhz Apacer Black Panther
Video Card(s) Msi GTX 1060 OC 3Gb
Storage 2 x 250Gb WD Blue raid 0 + 1Tb Wd Green
Display(s) Samsung BX2450 24" Led
Case GMC X7 X-Station
Power Supply HEC Raptor 500watt
Mouse Logitech G9
Software Windows 8.1
Benchmark Scores Power Level over 9000
He's talking about "Dual layer single sided DVDs" 8.5 Gbs
Any dvd writer is capable of writing to this , and probably most dvd players as well
Install Nero \ Power DVD
Choose 8.5gb DVD DL (duel layer) bottom of both programs .
add your stuff
Burn Blaze and Go :roll:
Nothing too it
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.54/day)
IA, USA
System Name BY-2021
Exact capacities are:
DVD-R: 4,707,319,808 bytes
DVD+R: 4,700,372,992 bytes
DVD+R DL: 8,543,666,176 bytes
If it exceeds that amount, there will likely be issues with player/DVD compatibility.
You need dual layer burner, media, and software to create dual layer DVDs.
newtekie1
Semi-Retired Folder
28,472 (4.16/day)
Indiana, USA
The DL has been a standard from the beginning, and almost all DVD readers and writers can handle them. Anything from the last 5 years should have no problem. And almost all DVD movies are on Dual-Layer discs.
I wouldn't expect the costs to come down on DVD-DL discs, they've been at that price point for a long time, they aren't popular, so production is low. And they are being phased out and replaced by BD-R.
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.54/day)
IA, USA
System Name BY-2021
I concur. If anything, the price of DVD media will start going up. Dual layer disks are expensive to manufacture.
At the same time, BluRay never really caught on.
newtekie1
Semi-Retired Folder
28,472 (4.16/day)
Indiana, USA
Burning discs just isn't popular anymore. So blu-ray burning equipment and media hasn't really caught on. And it has definitely been slow to catch on as a movie delivery system, digital delivery is cutting into blu-ray's popularity.
2,817 (0.44/day)
louisiana
ok, I was indeed completely misunderstanding how it works as you said. I thought double layer meant copy and/or read to both sides
2,817 (0.44/day)
louisiana
add your stuff
Nothing too it
ok, this is what I was wondering about.
what is BD-R ???
de.das.dude
Pro Indian Modder
8,826 (1.71/day)
VR HMD ;_;
thats pretty much a myth. never had any problems.
newtekie1
Semi-Retired Folder
28,472 (4.16/day)
Indiana, USA
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.54/day)
IA, USA
System Name BY-2021
1,486 (0.33/day)
Anchorage Alaska
System Name Matter's / Helios 300 Predator
Processor Ryzen 7 2700 / i7 7700HQ
Motherboard B450 Tomahawk / Acer Helios 300 Predator
Cooling Arctic Freezer eSports Duo
Memory Patriot Viper ddr4 32gb / 32gb gskill ddr4
Video Card(s) MSI RTX 2080 Super Ventus OC / GTX 1060 6gb
Storage Patriot Viper nvme M2, crucial MX300 275gb, Samsung 860 qvo 1tb
Display(s) Acer 24" 1080p / 15.6 1080p HD
Case Antec 300 / Acer Helios 300 Predator
Audio Device(s) On Board - Steel Series Arctis Pro Wireless Cans
Power Supply Antec 850watt high current pro
Mouse Steel series Rival 600
Keyboard Corsair K70 / Acer Helios 300 Predator
Software Win 10 Pro / Win 10 Home
I have been getting away from both dvd and blue ray disc's. I have been going to usb thumb drives. I mainly carry around a 64gb and a 128gb in my back pack at all times. The 64gb is usb 3.0 and 128gb is 2.0. I have yet to find a computer that dislikes either and I do not have worry about getting the disc all scratched up. Another plus for usb is a lot of dvd and blue ray players have usb ports built in so you can play your media thru a thumb drive and not worry about burning a movie to a disc. I am not sure what the OP is intending to do with his media but it is the direction I am going for transporting media and such around.
2,817 (0.44/day)
louisiana
I'm looking to make windows install disks as well as put movies on disk,
1,486 (0.33/day)
Anchorage Alaska
I used to do that, my last 2 installs were from usb sticks/thumb drives and it went so much smoother and easier than I predicted. I was quite happy at the end of it. I found an older 64gb stick that I imaged my laptop too just in case I borked something later on. I have spindles full of dvds with movies on them. I am in the process of copying them over to a usb external hard drive. Easier to transport them too. My blue ray burner sits idle and empty any more, unless someone gives me a disc I do everything with usb.
Your Samsung dvd burner should do dual layer just fine. Maybe BestBuy or Walmart will have 5 or 10 packs available. If you go the blue ray route holler at me, I may have a couple blue ray disc's laying around. Just have to find them.... if they did not grow legs and wander off.
2,817 (0.44/day)
louisiana
having a disk copy as backup is so much more convenient and easy to store.
not to mention, flash drives are very convenient and easy to use but they work until they no longer work and then your screwed.
with disks they dont take much room and I can make 2 copies so I always have a safe backup version to go back to if the flash drive or dvd I use regularly gets messed up or corrupted somehow.
I suppose its just as easy to keep backup copies of the flash drives in case one fails.
wonder if they have bulk packs of flash drives? its like full circle coming back to floppy disks only flash drives are the new floppies lol.
1,486 (0.33/day)
Anchorage Alaska
True enough :)
2,817 (0.44/day)
louisiana
only question would be, whats the sweet spot of gb size to get a bunch of flash drives in?
too small you have storage issues, too big you have high failure rates in them (at least that's how it seams)
then they need to start selling labels and desktop flash drive organizer storage trays like they had for cd/dvds and floppy disks lol
and would flash cards be more reliable the drives or nor difference?
another thought is would flash cards be about as fast or much slower then usb for data transfer?
1,486 (0.33/day)
Anchorage Alaska
I have great luck with 32 to 128 sticks, I prefer 64 and 128. For me I find those 2 work best overall, at least for what I use them for.
hat
Enthusiast
21,735 (3.36/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
If you're thinking about doing this for movies, you may want to take this in a different direction. Many of us run Plex servers or some other type of media server which streams content from your HDD to other devices in your house (PS3, Xbox, Roku, etc). I'm in the process of building a library for Plex myself.
I wonder if there's any interest in a guide to running Plex... including DVD ripping, deinterlacing, encoding...
