What is "System Agent" voltage?
16 (0.01/day)
Hello people. Today i tried to undervolt my I5 1035G1 CPU. I can undervolt my Core, cache, iGPU to -40 MV. After that it gives me a BSoD. I saw a "System Agent" setting. What is that? Will it be harmful if i undervolt that? Sorry for broken english. I'm still studying some.
474 (0.31/day)
System Name Dusty
Processor 5900x
Motherboard MSI B550 Tomahawk
Memory Corsair Vengence LPX 32GB
Video Card(s) MSI RTX 3070 Gaming X
Storage yes
Case Fractal Design Define R6
Power Supply EVGA SuperNOVA 750w
VR HMD Oculus CV1
silentbogo
5,608 (1.37/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 5700X3D
Memory 64GB DDR4-3600(4x16)
Storage ADATA Legend 2TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
Back when intel decided to combine both North Bridge and South bridge into what's now known as Platform Hub(PCH), some of the functional parts migrated to CPU and became SA.
That's your memory controller, DMI, PCIe and other high-speed stuff. It has its own VRM(usually one smaller-looking phase right under the CPU VRM).
Basically on Intel you have separate power for CPU, SA and Graphics, while on AMD you only have Vcore and Vsoc(which powers both memory controller+interconnects along with iGPU).
I wouldn't mess with SA - it's the surest way to make your system even more unstable(especially a laptop). Also, what's the point of undervolting a low-power laptop CPU?
MxPhenom 216
ASIC Engineer
13,058 (2.48/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | LG 24" IPS 1440p
Mouse Razer Viper v2 Pro
If you are overclocking memory on desktop, adjusting SA voltage is crucial.
silentbogo
5,608 (1.37/day)
Kyiv, Ukraine
System Name WS#1337
Mouse Logitech G603
16 (0.01/day)
I'm trying to undervolt it cause it gives me a huge temp.
Idle : 80-90 C
Benchmark : Auto reboot caused by extreme cpu heat. (around 110 C)
silentbogo
5,608 (1.37/day)
Kyiv, Ukraine
System Name WS#1337
Mouse Logitech G603
Idle : 80-90 C
80-90C idle is in a ballpark of you living in Sahara desert inside a transparent tent, and your cooling system not working at all.
In simple words - it's crazy hot and I doubt it has anything to do with voltages. Or if part of your SoC dying a slow and painful death.
If it's under warranty - RMA. If not - at least take off the bottom case and at least check if your fan is spinning at all. I mean, c'mon. It's a 15W SoC.
752 (0.44/day)
System Name Main PC
Processor AMD Ryzen 9 5950X
Motherboard ASUS X570 Crosshair VIII Hero (Wi-Fi)
Cooling EKWB X570 VIII Hero Monoblock, 2x XD5, Heatkiller IV SB block for chipset,Alphacool 3090 Strix block
Memory 4x16GB 3200-14-14-14-34 G.Skill Trident RGB (OC: 3600-14-14-14-28)
Video Card(s) ASUS RTX 3090 Strix OC
Storage 500GB+500GB SSD RAID0, Fusion IoDrive2 1.2TB, Huawei HSSD 2TB, 11TB on server used for steam
Display(s) Dell LG CX48 (custom res: 3840x1620@120Hz) + Acer XB271HU 2560x1440@144Hz
Case Corsair 1000D
Audio Device(s) Sennheiser HD599, Blue Yeti
Power Supply Corsair RM1000i
Keyboard Corsair Strafe RGB MK2
Software Windows 10 Pro 20H2
Yeah I don't see why OP is even messing with this stuff considering this is a new-ish system.
This indicates a hardware problem, not a software problem. You don't fix a bad cooling system by underclocking an already underclocked chip. You return it because the manufacturer doesn't know what the F it's doing and the product is malfunctioning because of their incompetence.
16 (0.01/day)
I have 2 fans inside of my laptop and they are spinning on full speed. I still dont know how the heck my cpu can be this hot
silentbogo
5,608 (1.37/day)
Kyiv, Ukraine
System Name WS#1337
Mouse Logitech G603
No contact between die and HS or bent heatpipe(relatively common on low-end ultrathins), or dying SoC (quite common for ULP combines).
In either case - RMA ASAP.
201 (0.03/day)
Idle : 80-90 C
Idle 80-90C?
Can you take a hwinfo64 screenshot readout of these temps?
Are these CPU core die (DTS) temps or something else?
CPU Core temps of 80-90C idle only mean one of three things. (in order to most likely to almost impossible):
1) no contact between CPU and heatsink surfaces (bad to atrocious to completely nonexistent thermal paste job or terrible heatsink installation, broken screw or defect, badly warped heatsinks, etc).
--even fans not spinning on a properly repasted and mounted heatsink won't give you 80-90C idle.
2) (Water cooling/AIO's): pump not working.
3) Virus, malware, or rogue/buggy/crashed or completely messed up services or processes putting CPU cores at 100% usage at idle (even some DTS/Realtek/SS3 sound unbound drivers have been known to spread debauchery like this), and even that shouldn't be higher than 60C idle.
16 (0.01/day)
Idle 80-90C?
I reinstalled Windows 10. Then cleaned everything out of my laptop. Replaced thermal paste. Now it is idling on 55 C and when benchmark it is 82. I'm kinda worried about 82 C is that alright for a CPU?
825 (0.43/day)
Taiwan
Processor i5-9600K
Cooling Scythe Mugen 5S
Display(s) Gigabyte M32Q
Case Antec DF700 Flux
Audio Device(s) Edifier C3X
Mouse Razer Basilisk V2
Keyboard Ducky ONE 2 Horizon
That is fine, the problem should have been the thermal paste or cooler mount.
silentbogo
5,608 (1.37/day)
Kyiv, Ukraine
System Name WS#1337
Mouse Logitech G603
Those temps are normal. If you used MX4 or MX5 - it'll get a bit better in a week or so. Definitely better than what you had before.
45 (0.03/day)
System Name pc
Processor İ7 11700K
Motherboard ASUS ROG Z590-F
Cooling Lian Lİ Galahad 360
Memory Crucial Ballistix RGB 3200 MT/S tCL16
Video Card(s) ASUS ROG STRIX RX 6700XT OC
Storage 980 PRO 500GB+Crucail P5 500GB + WD BLUE 1TB HDD
Case Corsair 5000D Airflow
Power Supply Corsair RM850
Mouse Asus Pugio II
Keyboard XPG Summeoner Cherry MX Red
Software WINDOWS 10 PRO
Name given to things other than Processor Cores and Cache, IMC-QPI-DMI-PCIE-DISPLAY, VCCSA voltage in Intel
