What is the best long-term storage solution?
15,634 (6.82/day)
Midlands, UK
Processor AMD Ryzen 7 7800X3D @ 45 W TDP Eco Mode
Case Corsair Crystal 280X
Mouse Logitech MX Master 2S
Keyboard Logitech G413 SE
Hi all. :)
The question is simple: how do you store sensitive data (family photos, or anything irreplaceable) long-term, and what would you recommend to others? I've tried a few methods in the past with varying experiences:
1. Optical disks:
Advantage: Cannot be deleted, can be stored on a bookshelf or anywhere, relatively portable.
Disadvantage: Small size, home-written disks lose data over time, they can even become unreadable.
2. External hard drives (that's what I'm using now):
Advantage: Large storage capacity.
Disadvantage: Prone to mechanical failure.
3. Cloud storage:
Advantage: Safe.
Disadvantage: Requires internet connection, large amounts of data require monthly subscriptions.
4. Memory card:
Advantage: Extremely portable.
Disadvantage: Large capacities are expensive.
5. External SSD:
Advantage: Small size, fast read/write speeds.
Disadvantage: Data retention?
6. RAID 1 array HDDs/SSDs:
Advantage: If one drive fails, you still have all your data on the other one as backup.
Disadvantage: Requires a RAID controller, multiple drives take up space in your PC case, they consume relatively a lot of power and generate heat/noise.
Is there any other method that you have in mind? How do you store your sensitive data?
22,160 (3.43/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Case Thermaltake Core X31
M-DISC optical is specifically designed for longterm optical storage.
15,634 (6.82/day)
Midlands, UK
It's the first time I've heard about it. Does it work the same way as a normal DVD-R or BD-R?
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Umm, all of them?
If you want long term backups you'd be insane to keep them in one location on one medium.
Ahhzz
Super Moderator
9,188 (1.47/day)
System Name OrangeHaze / Silence
Processor i7-13700KF / i5-10400 /
Motherboard ROG STRIX Z690-E / MSI Z490 A-Pro Motherboard
Cooling Corsair H75 / TT ToughAir 510
Memory 64Gb GSkill Trident Z5 / 32GB Team Dark Za 3600
Video Card(s) Palit GeForce RTX 2070 / Sapphire R9 290 Vapor-X 4Gb
Storage Hynix Plat P41 2Tb\Samsung MZVL21 1Tb / Samsung 980 Pro 1Tb
Display(s) 22" Dell Wide/24" Asus
Case Lian Li PC-101 ATX custom mod / Antec Lanboy Air Black & Blue
Audio Device(s) SB Audigy 7.1
Power Supply Corsair Enthusiast TX750
Mouse Logitech G502 Lightspeed Wireless / Logitech G502 Proteus Spectrum
Keyboard K68 RGB — CHERRY® MX Red
Software Win10 Pro \ RIP:Win 7 Ult 64 bit
Yup. ^^ What he said. Multiple points of backup. Keep local copies for easy access, stored in a cloud solution (dropbox, onedrive, etc) for recovery, and local external backups (external drive, NAS) for redundancy. Also, make sure you're checking that local backup for failure. I've had more than one client at a loss because their local copy hadn't been checked in months, and had failed.
785 (0.22/day)
System Name Fat NCASE
Processor Ryzen R9 3900X
Motherboard ASUS TUF GAMING B550M ZAKU (WIFI) Edition
Cooling Scythe Fuma with 3 SCYTHE Wondersnail 2400RPM + Arctic MX2
Memory Corsair Vengeance 128GB @3200Mhz Cl16 (32GB X 4)
Video Card(s) Palit RTX 3060 StormX ITX 12GB
Storage MX500 4TB SATA + Toshiba MG08 16TB HDD
Display(s) LG 27UL500 4K monitor
Case Jonsbo W2 black
Audio Device(s) Onboard realtek 1200 & Soundblaster G3 usb
Power Supply ASUS ROG STRIX 850W Gundam Edition
Mouse Elecom wireless mouse :)
Keyboard RK100 Royal Kludge
Software Windows 10 HOME
Benchmark Scores Don't know any benchmark. It runs good enough for me.
M-disc works the same works the same as dvd-r and bluray. The only difference it between it and normal cds is their physical material properties layers which is designed for longterm to prevent degradation. According to mdisc they said 1000 years of readability . I hIghly doubt it but it should be able to last a century. It is the best archival offline storage currently we got. Unfortunately space for bluray have not really caught up even in bdxl variants of mdisc.
Edit : Not all opticals drives can write mdisc. Even if the mdisc format last 100 years the availability of optical tech that could read it is another question.
For longterm storage it is MDisc>Bluray>dvd>HDD. SSD I would not put SSD as longterm storage as the charges in it get lower over time. Regardless the storage medium use all media require longterm care to ensure their data are readable and shifting formats upon signs of media damaging. Data hoarding and preservation is a time consuming activity personally for me doing it.
680 (0.16/day)
UK
Objectively speaking, high grade optical has the longest static lifespan (as in it will last decades with no attached "mechanism", no silicon to fail and no magnetic / electric charge to gradually leak).
Realistically speaking, having multiple copies and the ability to easily port data from one old storage medium to a new one as storage technology changes / drives fail is necessary in practise. Eg, imagine someone created an indestructible high grade floppy disc in 1992 that was guaranteed to be read in 100 years by floppy drives in 2092 and immune to magnetic fading. 30 years on (2022), and it's clear that what's keeping old 80s'-90's DOS games alive in retro game communities is zip files + emulators stored on servers by "Abandonware" sites or home NAS's, not people actually inserting floppy disks to play. Same with old cartridge based consoles and emulators, or 8-bit cassette drives (C64 / ZX Spectrum) stored as .TAP files. Just some examples.
Bottom line - Don't make A backup, make several. Don't keep them all in the same place. And expect & accept that you'll probably be porting them to new storage mediums as the decades tick by.
Edit: Also, if you're backing up very old documents with old file formats, whilst many formats (.BMP, .GIF, .ISO, .JPG, .WAV, .ZIP, etc) are positively enduring and have aged very well for compatibility, many others have come and gone (eg, .ARJ, .DIVX, CorelDraw / Lotus 123 / Wordperfect for MS-DOS, .NRG (Nero ISO), .WMA, etc). If you have stuff like this, it may be worth considering you may not be able to open them in future on modern software, and you may need to either convert them to a more portable format now, or at least backup some older version of a software that could read them along with the data itself. Eg, I have a lot of zip files and in addition I backed up a copy of 7zip that was used to create them. I have a lot of DOS games, and in addition to the games I've backed up a "known good" version of DOSBox. It hardly takes up any extra space and when applied to lesser popular formats / software could save a lot of headaches down the line.
44,267 (6.80/day)
I do not trust "cloud".
I'd use an odd, SATA/USB SSD/HDD,/USB flash drive, Tape drive with a shielded fire and water proof case.
Or make hard copies of pictures.
Also a disadvangate is ESD for all but the ODD
11,880 (2.15/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
Two direct on used hardware copies, one backup hd ,one cold storage Hd and m disks , works for me.
I also use cloud backup for photos only though too.
108 (0.04/day)
Processor Intel® Core™ i9-13900K Processor
Motherboard ASUS ProArt Z790-CREATOR WIFI
Cooling EKWB EK-AIO 360 D-RGB
Memory Corsair VENGEANCE® RGB 32GB (2x16GB) DDR5 DRAM 6600MHz C32 Memory Kit — Black
Video Card(s) EVGA GeForce GTX 1070 FTW GAMING
Storage Samsung 1TB 990 PRO
Display(s) ASUS ROG Swift PG279Q x2
Case Lian Li O11 Dynamic EVO
Audio Device(s) Corsair VOID RGB Wireless Premium Gaming Headset
Power Supply Corsair RMi Series RM850i High-Performance ATX Power Supply
Mouse Corsair SCIMITAR RGB Optical MOBA/MMO Gaming Mouse
Keyboard Corsair STRAFE RGB Mechanical Gaming Keyboard — CHERRY® MX Silent
Software Microsoft Windows 11 PRO
What is the best long-term storage solution?​
When you answer this question as is, there is only one answer.
Magnetic tape data storage.
When you include budget, use point or any other derivatives; the answer will change.
For personal back up, it is best to use 3:2:1 back up rule.
3: Create one primary backup and two copies of your data.
2: Save your backups to two different types of media.
1: Keep at least one backup file offsite.
And RAID is NOT a back up option.
Mussels
58,412 (7.78/day)
Oystralia
Cloud saved my bacon
I had photos of my sons birth (well, directly before and after, not the gross in between bit) and the phone was stolen the day after (you get forgetful with a newborn)
The one copy on a portable 2.5" drive got erased because some dingbat stuck a fridge magnet onto it
Pretty sure it was pre-google photos so it would have been google drive, but i had uploaded copies for family to download, and they're the only remaining ones.
Since then, i've always kept critical documents locally, on my NAS, google drive/photos, and on mega.nz - with photos being kept on the phone and on google photos
