What is the point of two Ethernet ports on my motherboard?
Status
Not open for further replies.
Phusius
1,316 (0.29/day)
Processor i5-2500k @ 4.5
Motherboard Asus Z68 Deluxe
Cooling Noctua NH-D14
Memory 16GB DDR3 1600
Video Card(s) Sapphire 7950 @ 1200/1475 @ 1175v
Display(s) Dell 23" 2ms
Case Carbide 500r
Audio Device(s) Asus Xonar DG
If I hook two lines up from my router to both ports does that mean my internet and download speeds will be faster?
3,600 (0.68/day)
Portugal
No.
It means that if your motherboard (and your router) supports double-teaming for those ports, bandwidth will be almost doubled.
If not, it just means you have two ethernet ports on your motherboard which you can plug both to the router and have them that way.
At best you can specify what goes trough which port.
Phusius
1,316 (0.29/day)
Case Carbide 500r
How do I know if it supports double teaming. Can you help me?
My mother is the Asus Z68 Deluxe NON-gen3 version, and my router is the Belkin N600 DB, and I pay for a 24mbs fiber optic internet each month.
8,521 (1.38/day)
Kansas City
System Name The Dove Box Rev 3.0
Processor i7 8700k @ 4.7GHz
Motherboard Asus Maximus X APEX
Cooling Custom water loop
Memory 16GB 3600 MHz DDR4
Video Card(s) 2x MSI 780 Ti's in SLI
Storage 500GB Samsung 850 PCIe SSD, 4TB
Display(s) 27" Asus 144Hz
Case Enermax Fulmo GT
Audio Device(s) ON BOARD FTW
Power Supply Corsair 1200W
Keyboard Logitech G510
Software Win 10 64x
Surely your motherboard came with an owners manual, have you referenced there?
The manufacture may have details to benefits as to why they placed multiple ports on your board.
lindy
81 (0.02/day)
45° 59' 55.57” N 86° 09' 20.10” W
System Name Infernal Contraption
Processor AMD FX 8150
Motherboard Gigabyte 990XA-UD3
Cooling Antec Kuhler H20 620
Memory 16 gig. Corsair Vengance DDR3 1600 LP
Video Card(s) Galaxy/Nvidia GTX 560 2gb
Storage OCZ 60g. SSD/Seagate 2Tb. 7200rpm
Display(s) Asus
Case Lian Li PC-60FN
Audio Device(s) Onboard HD
Power Supply Seasonic X750
Software Win. 7 Ult. 64/ SUSE 12.1 64
Networking...
Nope...
And, yes I can be a real smart *** :D
5,687 (1.11/day)
System Name Space Station
Processor Intel 13700K
Motherboard ASRock Z790 PG Riptide
Memory Corsair Vengeance 6400 2x16GB @ CL34
Video Card(s) PNY RTX 4080
Storage SSDs - Nextorage 4TB, Samsung EVO 970 500GB, Plextor M5Pro 128GB, HDDs - WD Black 6TB, 2x 1TB
Display(s) LG C3 OLED 42"
Case Corsair 7000D Airflow
Audio Device(s) Yamaha RX-V371
Power Supply SeaSonic Vertex 1200w Gold
Mouse Razer Basilisk V3
Keyboard Bloody B840-LK
Software Windows 11 Pro 23H2
Dual LAN MBs are more often used for dual network connectivity and/or daisy chaining network connections, as per in an office or home office environment.
Your bandwidth is going to be limited by the ISP speed you have. Having a dual LAN MB can't really change that.
If none of the above applies to you, the only actual use you may get out of the 2nd LAN port is redundancy, meaning having a backup in case the first fails for some reason.
1,668 (0.33/day)
State College, PA, US
System Name My Surround PC
Processor AMD Ryzen 9 7950X3D
Motherboard ASUS STRIX X670E-F
Cooling Swiftech MCP35X / EK Quantum CPU / Alphacool GPU / XSPC 480mm w/ Corsair Fans
Memory 96GB (2 x 48 GB) G.Skill DDR5-6000 CL30
Video Card(s) MSI NVIDIA GeForce RTX 4090 Suprim X 24GB
Storage WD SN850 2TB, Samsung PM981a 1TB, 4 x 4TB + 1 x 10TB HGST NAS HDD for Windows Storage Spaces
Display(s) 2 x Viotek GFI27QXA 27" 4K 120Hz + LG UH850 4K 60Hz + HMD
Case NZXT Source 530
Audio Device(s) Sony MDR-7506 / Logitech Z-5500 5.1
Power Supply Corsair RM1000x 1 kW
Mouse Patriot Viper V560
VR HMD HP Reverb G2
Software Windows 11 Pro x64
Benchmark Scores Mellanox ConnectX-3 10 Gb/s Fiber Network Card
I learned this recently, but teaming does not exactly double bandwidth. You can transfer data at only 1 Gb/s to each IP address, but if you transfer to more than one IP address simultaneously, then the aggregate bandwidth can exceed 1Gb/s. This means it's great for servers that serve many clients simultaneously but is less useful for home users who usually only transfer to one client at a time.
Before you even do this, you need a router or switch that supports teaming. And it won't speed up your internet connectivity unless you have a fiber line to your residence that supports over 1000Mbps (most likely not).
3,600 (0.68/day)
Portugal
Eh, I was in doubt that it was something like that...wasn't too far off. And I should have said the doubled bandwidth was theoretical.
Still, his download speeds are still limited first by his ISP (in this case, 24Mbps) and second by the server from where he is downloading, be it either by rule or distance.
The fact that the motherboard has two ethernet ports won't improve that.
5,990 (1.27/day)
Hi! I'm from the Internet
System Name Agent Texas / Selene / Eve
Processor Ryzen7 5800x / Fx 8350 / Fx 8350
Motherboard Gigabyte B550 Aorus Elite Ax V2 / Gigabyte 990FXA-UD3 r4.0 / Msi 970a Krait
Cooling Msi Mag Core liquid / H100i / Cryo-pc Cooler
Memory 2 x32 GB Gskil Ripjaws v series / 4x 8gb G.Skill Snipers / 2x 8gb G.Skill Ripjaws
Video Card(s) Gigabyte Rx 6800xt / Msi RX580 / Gigabyte R9 290x
Storage 1tb M.2, 2tb wd / 500 gb ssd, 2x 2tb Wd Blacks/ 500 gb ssd, 1tb WD Black
Display(s) Dell Ultra Sharp 2408 WFp / Hp w2207 / Sanyo tv
Case Corsair 780t White / Raidmax Vampire / NZXT Phantom 240
Audio Device(s) Onboard Hd Audio / Onboard Hd Audio / Onboard Hd Audio
Power Supply Corsair Rm 850 watt / Corsair TX 850 watt / Corsair TX 750 watt
Mouse Logitech G502 Hero / Logitech G500s / Logitech wireless
Keyboard Corsair Strafe / Corsair k50 / Logitech wireless
Software Win 11 pro / Win 11 pro / Win 11 pro
Benchmark Scores What are benchmarks anyway?
Back in the day we used to put 2 Ethernet cards in one rig. We would hook the cable modem up to one and the other to a network switch. Fast easy router. Guess you can do the same and instead of hooking the modem to one nic you can hook it to the router and the other to a switch and share the net connection to allow access to more rigs.
AlienIsGOD
Vanguard Beta Tester
5,113 (0.86/day)
Kingston, Ontario Canada
System Name Aliens Ryzen Rig | 2nd Hand Omen
Processor Ryzen R5 5600 | Ryzen R5 3600
Motherboard Gigabyte B450 Aorus Elite (F61 BIOS) | B450 matx
Cooling DeepCool Castle EX V2 240mm AIO| stock for now
Memory 8GB X 2 DDR4 3000mhz Team Group Vulcan | 16GB DDR4
Video Card(s) Sapphire Pulse RX 5700 8GB | GTX 1650 4GB
Storage Adata XPG 8200 PRO 512GB SSD OS / 240 SSD + 2TB M.2 SSD Games / 1000 GB Data | SSD + HDD
Display(s) Acer ED273 27" VA 144hz Freesync |TCL 32" 1080P w/ HDR
Case NZXT H500 Black | HP Omen Obelisk
Audio Device(s) Onboard Realtek | Onboard Realtek
Power Supply EVGA SuperNOVA G3 650w 80+ Gold | 500w
Mouse Steelseries Rival 500 15 button mouse w/ Razor Goliathus Chroma XL mousemat | Logitech G502
Keyboard Corsair K65 Mini w/ Cherry MX brown keys | Logitech G513 Carbon w/ Romer G tactile keys
Software Windows 10 Pro | Windows 10 Pro
i knew having 2 ports on my old Gigabyte EP45 DS4P were pretty much useless for the regular user.
10,693 (1.72/day)
Austin Texas
System Name Planet Espresso
Processor 13700KF @ 5.5GHZ 1.285v - 235W cap
Motherboard MSI 690-I PRO
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Mouse Xlite V2
Keyboard 65% HE Keyboard
so that you can have two Ethernets. duh. :D
That's like asking why have two women in bed... don't ask - just stick your cable in there and envy your router for all of the action it's getting.
Mussels
Freshwater Moderator
58,413 (7.96/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
to keep it simple, your two network ports are for the use of connecting to two networks at the same time.
there is no purpose to them for 99.9% of home users.
329 (0.07/day)
Malaysia
System Name Elmo
Processor i9 7900x
Motherboard MSI x299 gaming pro ac
Cooling Noctua NH D-14
Memory 32GB DDR4 3600 Mhz
Video Card(s) Zotac AMP Extreme RTX 2070 Super
Storage 1TB Samsung 860 Evo, Samsung 970 Evo Plus 500GB, 1 & 2TB Barracuda, Hyperx 120GB, WD Green 500GB
Display(s) Samsung 23" led 1080p X 3
Case Nzxt Switch 810
Power Supply Corsair HX 750W
You can set one for upstream and the other for down stream or both to way. You can double your Lan throughput but you wont double your wan throughput
10,693 (1.72/day)
Austin Texas
Case Jonsbo Z20
Audio Device(s) Yes
Mouse Xlite V2
or you can double your mint.
brandonwh64
19,542 (3.53/day)
mussels has the main use for it. At work we use these to connect a PC to its own private network then the other would be for a VPN connection to allow third party venders to remote control and fix the machine in times of need.
1,668 (0.33/day)
VR HMD HP Reverb G2
The ports are already full duplex, so one of them can simultaneously transmit 1000Mbps up and 1000Mbps down; you don't need two to do that.
5,687 (1.11/day)
You will love it someday when one of them dies
Redundancy is the least plausible reason to go dual LAN by far. Chances are one port will outlive the life of the upgrade cycle. They don't easily die with heavy use like disc burners do.
10,487 (1.40/day)
Not relevant, your router is very unlikely to support it, and even if it does there is no reason to connect to your router faster.
12,314 (2.28/day)
Oregon
System Name Juliette // HTPC
Video Card(s) ASUS RTX4070 OC// GTX 1650
Mouse Cooler Master MM710 53G
Is it just me or is it obvious its for two networks. Two cat5 cables to a router is just not logical. You would have to have SSDs to use that speed at both ends. Besides routers are only 1000Mbs the same a one cat5, right?
2,190 (0.37/day)
Minnesota, USA
System Name TaichiTig
Processor i7 6800K
Motherboard ASRock X99 Taichi
Memory 32GB DDR4 3200
Video Card(s) RTX 4070
Storage SSD + Misc. HDDs in DrivePool
Display(s) BenQ PD3200U, Samsung C32HG70
Case Antec Twelve Hundred
Audio Device(s) Behringer UMC404HD, LSR308, Shure SRH840, AKG K612, Etymotic HF5
Power Supply Corsair 750TX
Keyboard Deck Legend Ice Tactile
Software Win10
True, however I was just saved by having two ethernet ports when one on my one of my servers failed. This is not statistically significant but it's true that if it does, you'll be glad to have two.
Aquinus
Resident Wat-man
13,162 (2.82/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
At work I use two NICs. One is on the internal network which is where some of our servers are, the other goes right to the internet using a static ip for testing. That external IP is setup so I can test and develop SAML 2.0 SSO with Google without impacting anyone else (netmasking on just that ip) and so I can tell if a slowdown is actually our network and not the ISP. The internal IP gives me access to everything without having to use tunnels or use web traffic when I could be working locally.
5,687 (1.11/day)
Already been said in so many words, but that's just one of the normal uses. Daisy chaining would be another common one.
baggpipes
163 (0.03/day)
System Name R2D2
Processor AMD FX-4100
Motherboard MSI 970 G45
Cooling Stock
Memory Kingston T1 8GB 1600 DDR3 @ 1800mHz
Video Card(s) AMD Sapphire 6850
Storage RAID 0 WD Caviar Blue 1TB total
Display(s) Acer 19" widescreen and Sony 32" Bravia 1080p 60hz
Case NZXT Gamma Series
Power Supply 700w OCZ Mod Stream Pro
Software Windows 7 Professional
Benchmark Scores hit 4.5ghz stock cooler....
Easy manual loopback test? :troll:
4,113 (0.68/day)
Iowa, USA
System Name THE CUBE 2.0
Processor Intel i5 13600k
Motherboard MSI MPG Z690 EDGE DDR4
Cooling Phanteks PH-TC14PE BK 2x T30-120 Fan mod mount
Memory G.Skill TridentZ 3200 MT/s C15 32GB 2x16GB
Video Card(s) Gigabyte Aorus 1080 Ti 11GB OC: Core 2GHz, Mem 5.7GHz
Storage WD SN770 250GB / 3x WD SN850X 2TB / Toshiba X300 4TB / 2x RAID1 Toshiba P300 3TB
Display(s) Samsung 49" Odyssey OLED G95SC 240Hz 5120 x 1440
Audio Device(s) Beyerdynamic DT 880
Power Supply Corsair RM1000X
Mouse Logitech G700
Keyboard Logitech G910
I always thought you could have one from router to PC then other port go to something like an xbox.
Status
