Whats a good thermal paste for a GPU like rtx3080?
230 (0.04/day)
North of Iran
System Name Main system
Processor Intel Core-i7 4790K @4.5
Motherboard Asus Z97-Pro Gamer
Cooling Cooler Master Hyper 212 EVO
Memory 32 Gig (16 GigADATA XPG V2 DDR3 2400 + 16 Gig Geil Evo Veloce DDR3 1600 CL11)
Video Card(s) Gigabyte GTX1080 G1 Gaming
Storage Western Digital Blue Cavier 500 and 1 Terabyte + 1 Terabyte Green Cavier + Samsung SSD 860 EVO 500G
Display(s) ASUS ML238 LED Monitor
Case Green Viper X3
Audio Device(s) Onboard-Realtek
Power Supply Green 700watt (Its a rebranded psu from highpower/kolink I guess)
Software Windows 10 /Ubuntu 16.04
Hello everyone,
Hope you are doing great.
I'm planning on reapplying thermal pads on my RTX3080, so I am looking for a decent thermal paste as well.
Could you kindly suggest a decent thermal paste that works well on GPUs as well. I've heard there's a (slight) difference when it comes to GPUs
I did a bit of research and Arctic 5 seems to have a good reputation. is it suitable for this task or should I go for a better one, if the latter, whats your suggestion and why
Thanks a lot in advance
really appreciate your kind help in this.
1,302 (1.09/day)
Thailand
System Name Shoebox
Processor 3600x
Motherboard Msi b550m Mortar +WiFi
Cooling Cryorig m9
Memory Crucial Ballistix c16 B-die 2x8gb
Video Card(s) Powercolor rx570 4gb
Storage WD black sn750 256gb (OS), crucial mx500 1tb(storage),Hitatchi ?? 7200rpm 500gb(Temp files)
Display(s) Samsung 65" TU7100
Case Zzaw b3
Audio Device(s) Yamaha rx-v363
Power Supply Corsair sf750
Mouse Logitech g300s
Keyboard Custom Skyloong sk64s
Software Windows 11Pro
Hello everyone,
Mx5 or kryonaut and gelid pads tend to be my preference.
2,961 (0.52/day)
MN
System Name Personal / HTPC
Any GPUs I've repasted I've used Arctic Silver 5 and it's done the job well. I used it on a GTX 280, GTX 570s and my old GTX 980Ti, never had any issues.
1,212 (0.64/day)
Canada
System Name New compy
Processor AMD Ryzen 5800x3D
Case Thermaltake Core v71
I went with mastergel pro v2 and dropped my gpu temps by 5 degrees over stock paste.
1,302 (1.09/day)
Thailand
System Name Shoebox
Processor 3600x
Cooling Cryorig m9
Case Zzaw b3
I think alot of stock pastes and pads are primarily made of custard so it's no great shock your temps drop a few degrees
wolf
Better Than Native
8,178 (1.27/day)
System Name MightyX
Processor Ryzen 9800X3D
Motherboard Gigabyte X650I AX
Cooling Scythe Fuma 2
Memory 32GB DDR5 6000 CL30
Video Card(s) Asus TUF RTX3080 Deshrouded
Storage WD Black SN850X 2TB
Display(s) LG 42C2 4K OLED
Case Coolermaster NR200P
VR HMD Meta Quest 3
I've used Thermal Grizzly Kryonaut and Thermalright Oddesey 12.8w/mk pads on mine.
EDIT for more context.
Asus TUF 3080 (non OC, non-LHR original day 1 batch). It came with decent pads and paste already, opening it fairly much didn't change anything but piece of mind, till I found there was an extra spot to add some 2mm pad to increase contact and memory temps dropped 10c (~90-94c mining ETH), no core temp drop at all, but by lowering mem temps, I believe this has shunted extra heat to the main heatsink, so it's admirable that it didn't result in a core temp increase, and that could be at least in part due to the Kryonaut too.
Latest iteration is the stock pads between the card and backplate, full front of the card (plus extra spot) is the Thermalright Oddesey pads, ecept the memory chips themselves, I now use 1.5mm thick copper shims and the Thermal Grizzly Kryonaut on those too (used nail polish all around the chips to protect PCB and components), and get memory temps mining more like 80-84c under similar conditions.
225 (0.05/day)
System Name Mixed Bag of OC
Processor AMD Ryzen 5800X3D
Motherboard Maxsun MS-iCraft B550M WIFI
Cooling CPU+GPU on Water with 3 X 420 Rad´s
Memory 32GB Patriot Viper RGB @ 3800 Mhz CL14
Video Card(s) XFX Merc 310 RX 7900 XTX
Storage 2TB Kingston Fury + 2TB Samsung PCIe 4 NVME
Display(s) Philips 48OLED806
Case Selfmade Huuuuuge *Case* :)
Audio Device(s) ifi Zen DAC + Monoprice M1060C & Burmester Replica AMP + Selfmade Huuuuuge Speakers :)
Power Supply Seasonic PRIME TX-750
Mouse Kensington Slimblade (main device) + Razer Basilisk V3 (for FPS)
Keyboard Sharkoon PureWriter RGB, Kailh Blue switches
VR HMD None
Benchmark Scores do not matter, my PC is fast :)
i would not use Arctic Silver on a GPU because this paste is electrically conductive, you got to be careful like with liquid metal!
my paste Tip would be Alphacool Subzero if you can get it from somewhere, it´s an extremly good paste for GPU Die application.
2,191 (1.13/day)
LV-426
System Name Custom
Processor i9 9900k
Cooling corsair h150i
Memory 4x8 3200mhz corsair
Display(s) MSi MAG341CQ
Case Lian Li Pc-011 Dynamic
Mouse Logitech G403
Keyboard Logitech G110
Ah, this brings back memories on 8800GT 512MB, in 2010 i was playing the game Aliens vs Predator with my friends
my pc would keep shutting down and i couldn't figure out what was wrong... and later i opened up the case and my gpu was ultra hot...
my mate had some arctic silver 5 lying around and upon opening up the gpu, the thermal paste was completely disintegrated and maybe only few specks remaining around the edges..
repasted my gpu and bam! temps dropped from 100 to 65 during gaming loads...
230 (0.04/day)
North of Iran
Case Green Viper X3
Thank you everyone. really appreciate all of your kind suggestions.
Concerning reducing the chances of short circuiting using electrically conductive pastes, can I use nail polish around the gpus and call it a day?
would nail polish have an adverse effect on the GPU temp in any way?
I mean these small things around the GPU die:
wolf
Better Than Native
8,178 (1.27/day)
System Name MightyX
VR HMD Meta Quest 3
I used clear nail polish as you say, to cover the area broadly shown how I've colored in here, and it would protect the area you coloured too. It's the poor mans equivalent of conformal coating(?), so it should stop anything conductive shorting little components out, but it won't be necessary at all if you just use memory pads, and more a piece of mind precaution for non-conductive thermal paste like Kryonaut. I'm not quite game to use conductonaut (conductive thermal paste/material)
188 (0.12/day)
Brazil
Processor AMD Ryzen 5 5600X
Motherboard Asus TUF Gaming B550-Plus
Cooling Thermalright Frost Commander 140
Memory 2x16 3200@3733 Crucial Ballistix
Video Card(s) Gigabyte RX 5600 XT WindForce OC 6G (GV-R56XTWF2OC)
Storage Some
Display(s) Acer XV280K
Case Cooler Master HAF XB EVO
Power Supply Cooler Master MWE 650 Bronze
Mouse Logitech G502SE
Keyboard Ajazz AK35i with AKKO CS Rose Red Switches and white YMDK PBT keys
Nail polish is ok.
The best paste for GPU is Thermalright TFX because of its performance and
mainly because of its compound/viscosity it has less pump out effect.
It is very durable and can stand high temperatures well.
1,302 (1.09/day)
Thailand
System Name Shoebox
Processor 3600x
Cooling Cryorig m9
Case Zzaw b3
Is nailpolish cheaper than solder mask I wonder, also the added benefit of getting high as a kite using it.
42,222 (6.64/day)
Its capacitive, also never had a problem using it on anything
