bohica_34613
- Nov 4, 2007
- 31 (0.00/day)
- Brooksville Fl, just north of Tampa
System Name | IT , that thing |
Processor | Intel Core 2 Duo E6600 @3.2 29c @ 1.28v |
Motherboard | ASUS P5K3 DELUXE |
Cooling | Arctic Freezer Pro 7 |
Memory | 2Gb OCZ DDR3 |
Video Card(s) | Sapphire HD3850 512 |
Storage | WD Raptor 74gb 10,000 SATA/WD 250 Gb SATA |
Display(s) | Acer X203W |
Case | Coolermaster |
Audio Device(s) | Onboard sound |
Power Supply | Thermaltake 600w |
Software | XP PRO SP2 |
I don't know what to believe
I changed things again and I pumped the fsb up to 440 and changed the multi to 7 but in BIOS it says I'm running at 3ghz and it says I'm running at 3962mhz in Everest, Hot CPU tester and SISoft Sandra Lite.
The cpu is only a E6600 and I read it'll max-out at 3.8 but in those programs I had it running at over 4.3ghz before I backed it down for stability and thinking it'll last a little longer.
It seems to be running fast opening and real smooth playing HellGate and Dungeon Siege 2
I'm at a complete loss as to what it's running at
Does anyone have any ideas about which is the real speed I'm running at ?
