whats the difference between 8+2 vs 5+3 power/ what is a com debug port
554 (1.20/day)
I have no idea what the 2 numbers mean. clueless. one is 10 the other 8
any simple dumbed down article for anyone to understand the mb phase power designs?
and whats better between these 2?
and what is a com debug port used for?
1,492 (3.67/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) Some LED 1080P TV
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
8 cpu phases and 2 PCI-E phases. 8+2. 10 total.
5 cpu and 3 PCI-E phases. 8 VRMs total package.
Com port is external diagnostics. Similar to the com port in your vehicle.
138 (0.08/day)
In my world for a X+Y design the X stands for CPU power supply, and the Y for RAM power supply. At least that's how it was years ago.
A higher number of phases does not necessarily make it the better overall solution. The quality and selection of components, cooling etc. do add their part to the mix.
But yes, typically: The more the better.
776 (0.13/day)
Pacific Coast
System Name Z77 Rev. 1
Processor Intel Core i7 3770K
Motherboard ASRock Z77 Extreme4
Cooling Water Cooling
Memory 2x G.Skill F3-2400C10D-16GTX
Video Card(s) EVGA GTX 1080
Storage Samsung 850 Pro
Display(s) Samsung 28" UE590 UHD
Case Silverstone TJ07
Power Supply Seasonic PRIME 600W Titanium
Mouse EVGA TORQ X10
Keyboard Leopold Tenkeyless
Benchmark Scores 3DMark Time Spy: 7695
You're question can't be answered because there is too little context.
These are buck converters. Below I will compare 4 vs 8, but it applies to 6 vs 12 or any other combination.
1) In general, more phases are better because they will produce less ripple. But, all buck converters produce ripple and the final result depends on componemt quality and filtering. So, 4 phases filtered well could have less ripple than 8 phases filtered poorly.
2) Companies lie about the number of phases. It is quite common to use doublers, use 4 phases, and call it 8 phase. It's simply a lie, but common. This makes the ripple assumption completely wrong. Doublers double the current capability, but don't halve the ripple as expected. They produce a signal which has only half the number of advertised phases. So, if you go by their advertising alone, you have no idea which one is truly the best option. Dig into the details.
3) The other reason you may want more phases is for higher current capability. Again, this is only an assumption, because 4 phases with better components could handle more current than 8 cheap phases.
TLDR: the advertised number of phases is marketing and means absolutely nothing on its own. If you want recommendations, give some product options to compare. You can only compare apples to apples, and if you provide no details, everyone is wasting their time guessing.
