What's this small tube for?
341 (0.12/day)
System Name Core p90
Processor I7 9700k
Motherboard ASRock Z390 Phantom Gaming 4
Cooling Ek supremacy evo cpu block/nexxxos ut60 rad 480mm/D5 vario pump 310mm reservoir combo.
Memory Trident gskill 16gb 3000mhz
Video Card(s) Nvidia Founders edition rtx 3080 10gb
Storage M.2 Intel 660p 1024gb, 4tb 7200 rpm black Western Digital hdd
Display(s) Acer x34 predator 3440x1440p 120hz g-sync ultrawide 21:9 monitor
Case Thermaltake Core P90 tempered glass edition
Audio Device(s) On board
Power Supply Thermaltake smart m1200w
Mouse Logitech G600
Keyboard Logitech G910
Software Windows 10 64bit
Take a look at this picture. What's the small tube in the reservoir for???
1,901 (0.32/day)
Processor 5930K
Motherboard MSI X99 SLI
Cooling WATER
Memory 16GB DDR4 2132
Video Card(s) EVGAY 2070 SUPER
Storage SEVERAL SSD"S
Display(s) Catleap/Yamakasi 2560X1440
Case D Frame MINI drilled out
Power Supply Corsair TX750
Mouse DEATH ADDER
Keyboard Razer Black Widow Tournament
Software W10HB
Benchmark Scores PhIlLyChEeSeStEaK
Incase you remove all the system air, the tube keeps a few bubbles for feedback, just shake the bubbles free. Also helps to calm the bubbles.
theonedub
habe fidem
8,027 (1.40/day)
Northern CA, USA
System Name Erakith || AsRock NUCS
Processor AMD ThreadRipper 2990WX ES (32c/64t 3.5ghz@1.02v) || Intel i7 1360P Raptor Lake-P
Motherboard MSI X399 MEG Creation || AsRock OE
Cooling EK Supremacy TR4 Full Nickel, D5 w/ EK Top, 2X EK-CoolStream XTX 360 & Photon 270 Res || OE
Memory 32GB (4x8GB) Corsair Vengeance PRO RGB DDR4 3000|| 2x16GB Corsair DDR4
Video Card(s) Vega 64 EK FC|| Intel Iris Xe
Storage 250gb WD Black NVMe & (2) 2TB Intel 660p NVMe || 2TB Corsair MP600 Pro
Display(s) 34" Dell Ultrasharp U3415W
Power Supply Corsair HX1000
Software Windows 10 Pro x64 || WIndows 11 Pro x64
I always thought that was to limit any air/bubbles getting into the loop if you're using the top port for your return.
341 (0.12/day)
Processor I7 9700k
Mouse Logitech G600
My reservoir is a pump res combo. The pump is underneath pulling the water into the pump so...
Does that mean the tube would be helpful to me or should I remove it?
theonedub
habe fidem
8,027 (1.40/day)
Northern CA, USA
I could be 100% wrong on its intended use, but if you plan on having coolant enter back into the res from the top port- I'd leave it.
341 (0.12/day)
Processor I7 9700k
Mouse Logitech G600
I'm trying to figure out which ports are inlets or outlets? Here is where I got the combo (res pump)
And here is the link to the sensor I bought. Honestly I accidentally purchased the sensor. Wasn't intentional, but now that I have it, I'm thinking I might as well use it. I just don't know how to display the temperature this thing reads on a small display unit
Link https://www.dazmode.com/store/product/short-coolant_temperature_sensor_stop_fitting_chrome/
https://www.dazmode.com/store/produ...r-top-combo-black-pump-installation-optional/
2,012 (0.35/day)
Heart of Eutopia!
System Name ibuytheusedstuff
Processor 5960x
Motherboard x99 sabertooth
Cooling old socket775 cooler
Memory 32 Viper
Storage raptors+ssd
Display(s) acer 120hz
Case open bench
Audio Device(s) onb
Mouse mx 518
Keyboard roccat arvo
and no leave the tube there its not hindering performance or any
and the side with the tube is the inlet
2nd link not working for me
1,025 (0.33/day)
Croatistan
System Name 1.21 gigawatts!
Processor Intel Core i7 6700K
Motherboard MSI Z170A Krait Gaming 3X
Cooling Be Quiet! Shadow Rock Slim with Arctic MX-4
Memory 16GB G.Skill Ripjaws V DDR4 3000 MHz
Video Card(s) Palit GTX 1080 Game Rock
Storage Mushkin Triactor 240GB + Toshiba X300 4TB + Team L3 EVO 480GB
Display(s) Philips 237E7QDSB/00 23" FHD AH-IPS
Case Aerocool Aero-1000 white + 4 Arctic F12 PWM Rev.2 fans
Audio Device(s) Onboard Audio Boost 3 with Nahimic Audio Enhancer
Power Supply FSP Hydro G 650W
Mouse Cougar 700M eSports white
Keyboard E-Blue Cobra II
Software Windows 8.1 Pro x64
Benchmark Scores Cinebench R15: 948 (stock) / 1044 (4,7 GHz) FarCry 5 1080p Ultra: min 100, avg 116, max 133 FPS
For sucking the air out of the tube which looks like a... well... This is a hardware site. :D
It looks like some inlet for cooling liquid circulation, but I could be wrong.
5,047 (0.93/day)
Iberian Peninsula
Simply for you to be able to open the top (to fill water or evacuate aire...) while it's being used with a hose attached on top.
341 (0.12/day)
Processor I7 9700k
Mouse Logitech G600
I fixed the second link, my bad, apologies
You should be able to see it. Let me know which you think is inlet and outlet for the top 2 ports and the bottom 2 ports
qubit
Overclocked quantum bit
17,865 (2.86/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
What do the instructions say it's for?
1,012 (0.14/day)
Processor 2500K @ 4.5GHz 1.28V
Motherboard ASUS P8P67 Deluxe
Cooling Corsair A70
Memory 8GB (2x4GB) Corsair Vengeance 1600 9-9-9-24 1T
Video Card(s) eVGA GTX 470
Storage Crucial m4 128GB + Seagate RAID 1 (1TB x 2)
Display(s) Dell 22" 1680x1050 nothing special
Case Antec 300
Power Supply PC Power & Cooling 750W
Software Windows 7 64bit Pro
Not having searched or looked at any instructions, the common sense answer is that it is the inlet. Why? Imagine you have any air in the res (which normally happens). If the inlet is on the top of the res and the outlet on the bottom (so no air gets sucked into the loop), there will be a small gap between the top / inlet of the res and the coolant level. If there is no tube, the inlet coolant will essentially splash into the coolant in the res and it will cause bubbles (in fact, very small bubbles that will then get sucked into the loop). With the tube, the entering coolant is mixed below the "water line" so no splashing occurs. == profit.
341 (0.12/day)
Processor I7 9700k
Mouse Logitech G600
That's the thing, there were no instructions at all coming with the item. It was ordered from dazmode.com
So if I got this right. I would use the top port that has the small tube underneath for inlet and the bottom left most port for outlet?
Or the right one?
I know these must be dumb questions but this is my first water loop and the res pump combo came with zero instructions
1,609 (0.35/day)
Northamptonshire, UK
System Name Main / HTPC
Processor Ryzen 7 7800X3D / Ryzen 7 2700
Motherboard Aorus B650M Elite AX/ B450i Aorus Pro Wifi
Cooling Lian-Li Galahad 360 / Wraith Spire
Memory Corsair Vengeance 2x16 6000MHz CL30 / HyperX Predator 2x8GB 3200MHz
Video Card(s) RTX 3080 FE / ARC A380
Storage WD Black SN770 1TB / Sabrent Rocket 256GB
Display(s) Aorus FO32U2P / 39" Panasonic HDTV
Case Fractal Arc XL / Cougar QBX
Audio Device(s) Denon AVR-X2800H / Realtek ALC1220
Power Supply Corsair RM850 / BeQuiet SFX Power 2 450W
Mouse Logitech G903
Keyboard Drop Sense75 with WQ Studio Morandi's
VR HMD Rift S
Software Win 11 Pro 64Bit
Are there 2 holes at the top? How many holes at the bottom?
qubit
17,865 (2.86/day)
Quantum Well UK
Keyboard Yes
Or the right one?
I'm sorry, I don't know what it's for. I suggest emailing / calling Dazmode about it and see if they can answer your question.
341 (0.12/day)
Processor I7 9700k
Mouse Logitech G600
Here are more pictures. Hopefully you guys will see better and we'll know which port is which (especially the bottom ones)
341 (0.12/day)
Processor I7 9700k
Mouse Logitech G600
Well I ended up finding the answer.
Here's a picture Daz Sent me for the bottom part
Well it's a good thing I'm the kind of guy who always makes sure to understand everything before making my move. If I had just went with instinct I would probably have mixed up the inlets and outlets...
D5 barrel reservoir pump combo D5 install
(I type this in in case someone googles for this combo's install instructions like I did)
1,609 (0.35/day)
Mouse Logitech G903
VR HMD Rift S
Ah, that's better. Top center hole can be used for topping up the water, the one with the tube can be either used as an inlet or just to get rid of the accumulated air and bubbles in the res, and the ones on the bottom are inlet and outlet. It will all depend on the position of the res in your system. At least you can have options.
1,080 (0.15/day)
Look behind you!!
System Name NEW
Processor Intel 4770 non-K
Motherboard Gigabyte H81M-DS2V
Cooling CM Hyper 212 plus
Memory 16gb Muskin
Video Card(s) XFX 380X 4gb
Storage Sandisk 120gb plus WD blue 1tb
Display(s) AOC 23.5 LED bl
Case XIGMATEK
Audio Device(s) motherboard
Power Supply Cooler Master 500
That's what she said. Sorry I had too :p
8,099 (1.34/day)
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
Audio Device(s) on board
(I have zero experience with W/C'ing, unless you count the 6 years I spent in the Navy)
If you used one of the top ports for the return and simply let the liquid fall into reservoir, that would tend to encapsulate air into the liquid. I think the tube is to be used to discharge the return into the reservoir below the level of the liquid, therefore avoiding the aeration of the liquid. The tube needs to be long enough to get below the level of the liquid, but not too long as to basically feed the return right to the pump.
12,328 (2.25/day)
Oregon
Keyboard EVGA / Logitech K400
1,288 (0.20/day)
System Name Firebird
Processor Intel i7 2600K @5.0'ish 24/7 stock core Voltage {5.2 w/102 bCLK}
Motherboard Intel Extreme DZ68BC SkullTrail Z68 Cougerpoint, Excellent MCH !
Cooling Scythe NINJA PLUS Rev.B[skt478] Modded to 1155 Scythe SH12 fan
Memory Samsung 32nm 16Gb 4x4 (@19xxmhz} low profile[ better than 2133 banwidth]
Video Card(s) Gigabyte Aurosus 1080Ti
Storage Intel 512 SSD,Samsung 9701Tb, Toshiba 3Tbx2,Hitachi 320,1TBx2,'Cuda 400 7200.10, WD1TBUSB,to SATA
Display(s) Acer K272HUL 1440 27" WQHD, Samsung 226W, Vizio M60C3 4K 60",Vizio XVT3D554SV
Case CoolerMaster HAF 932
Audio Device(s) Intel 10ch[9+1] HD Audio X540> Pioneer VSX39TX[copper chasis,Rosewood sides 5x6LCD remote
Power Supply Seasonic X750 @ 24/7
Mouse Logictech G300s
Keyboard Saitek Cyborg v7
Software Windows 7 ROG E3 X64 by Neuropass/tweakscene
Benchmark Scores 4642@665/1600 220/GAT F1 4544 220/667strap 2.5/3/2/6 Bliss 650/1500 6490 Q6700 Bliss 690/1500
Strange only the pic in #17 show...........
If I copy the url from properties I can see it in new tab o_O
Maybe some cross link issue from imgur??
