What's wrong with my PSU???
Rickson Surya
13 (0.00/day)
Processor INTEL E7200
Motherboard GIGABYTE EX38-DS4
Memory KINGSTON DDR2 800 4GB (@ 2GB)
Video Card(s) HIS ICEQ3 HD 3870 512MB DDR4
Storage SEAGATE SATAII 1TB
Audio Device(s) CREATIVE AUDIGY SB VALUE 7.1
Power Supply GIGABYTE GT550W
Bro and Sis, anyone please help me...
<BR>
see that Red indicator?
what's going on with my PSU (on the 3rd Rail) ?
2,555 (0.39/day)
Illinois
Processor i7 2600k@4.6ghz
Motherboard MSI z68ma-ed55
Cooling Silentx Extreem 120mm
Memory 2x4gb XMS 7-8-7-20 1600
Video Card(s) HD6870
Storage 2x128gb Kingston Hyper-X (Raid0), 2x750gb RE3 (RAID1), 2x750gb RE3 (RAID1)
Display(s) Soyo 24", Gateway 22"
Case Fractal Design Arc Mini 6x120mm fans.
Power Supply Zalman 750w
Software Windows 7
Use a volt meter not software.
Rickson Surya
13 (0.00/day)
Rickson Surya
13 (0.00/day)
@Lazzer408
I don't have volt meter, but i will find one for testing.
2,555 (0.39/day)
Illinois
Software Windows 7
You are only .07v out of ATX2.0 spec. I highly doubt your motherboard, cpu, or gpu would be damaged because they have their own regulation. I had a psu pop a harddrive once but it was caused by a piece of metal that got into the supply. The output rails of a psu typically have a coupled output inductor that is used to inductively couple the 5v and 12v rails. What this means is if the 5v is close to where it should be the 12v isn't far behind.
Motherboard-based voltage monitoring has a/d converters to sample the voltages and convert it to a digital value to be read by software. I find them highly inaccurate in almost all cases. A voltmeter will give you your answer.
Specs.
+5 VDC ±5% (±0.25 V)
−5 VDC ±10% (±0.50 V)
+12 VDC ±5% (±0.60 V)
−12 VDC ±10% (±1.2 V)
+3.3 VDC ±5% (±0.165 V)
+5 VSB ±5% (±0.25 V)
13,791 (1.86/day)
Distribute the load on power cables better. Hooking up all the power hungry components on one cable (on one that is coming from the PSU directly) is not a good idea.
Auto power distribution should work among different rails, but i don't trust that all that much.
4,936 (0.74/day)
Hong Kong
Processor Core i7-12700k
Motherboard Z690 Aero G D4
Storage Plextor M10P 2TB
Display(s) InnoCN 27M2V
Case Thermaltake Level 20 XT
Nothing looks wrong with your PSU, but the way you connect your components.
Looks like the +12V3 has no load.
Rickson Surya
13 (0.00/day)
@shevanel
Intel E7200
Mobo Gigabyte EX38-DS4
DDR2 800 Kingston 4GB (2 2GB)
VGA HIS IceQ3 3870 512MB
HDD Seagate 1TB
2disc drives
1soundcard creative audigy value
1 Wireless LAN
That's all i have.
@Lazzer408
Thanks for the information. I check the voltage from BIOS , +12V is arround 11.98 , Maybe that's the software problem hehe....
@RejZoR
Thanks for the suggestion. I do distribute all the components.
Rickson Surya
13 (0.00/day)
@Zubasa
According to the spec, the +12V3 is connected to mainboard. i think it has load.
in early time, the P-Tuner doesn't give such a surprise indicator.
Rickson Surya
13 (0.00/day)
@shevanel
I'm Kind a confuse right know :confused:
anyway, if it really doesn't have load, could it damage my hardware (psu, mobo, ext.) in long term?
shevanel
3,464 (0.61/day)
Leesburg, FL
If I were you I'd just check voltages in bios. if they read fine then go on with your life. If youre really worried, borrow a psu from a colleague or get a volt meter and check true voltages.
Rickson Surya
13 (0.00/day)
@shevanel
i've check the voltage from BIOS, everything looks just fine.
so bad i don't have a volt meter :(
but i think the information from BIOS will be more accurate than the software, right?
