whats wrong with my ram?
44 (0.02/day)
hi all,
i got hyperx savage 2133mhz cl 13 overclock to 2666mhz cl14 and this is my result in aida64 memory test
83ns memory latency?? am i dreaming or what?
im on asus prime X370pro with ryzen 1700
ram is KHX2133C13D4/8GX and aida64 tell me manufacturer is SK hynix???
anyway i start thinking my ram suck hard should be like 34 ns or what ...
can some one help?
thanks
6,881 (1.46/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
Higher timings increases latency.
7,570 (1.77/day)
hi all,
can some one help?
thanks
You won't get 34ns even with the latest & greatest OCing monster in 8700k, not at 2666 MHz & CAS 14. What you're seeing is right & fairly accurate, if you want lower latency then you'll have to increase the ram speed (with the same timings) or tighten the current timings @2666 MHz.
7,570 (1.77/day)
but im already at 2666mhz in cl 14-13-13-36 which are very short timing right? i always think 80 ns is high latency dont you?
No it's not, IIRC Ryzen works fairly well with CAS14 @3200MHz, of course it's usually Samsung B die.
Like I said, for that RAM speed & CAS14 it's not. There's two ways to reduce latency, increase your mem speed with the same/similar timings or tighten the timings.
EDIT: just look this link https://www.memorybenchmark.net/ram.php?ram=Kingston+KHX2133C13D4/8GX+8GB&id=7968 it show my ram score comapred to other
WTF??!! the Kingston KHX2133C14D4/8G 8GB wich is cl14 is only 24ns im not understanding anymore
Why are you comparing passmark with AIDA64 :wtf:
44 (0.02/day)
just look my link .... 82ns in cl13 and 32ns for cl14 ... dont understand
6,881 (1.46/day)
Florida
Storage Various
test without 100 programs running in the background.
44 (0.02/day)
anyway you can see the difference of NS latency on my link, mine got 82 and all other like 32 its not about program in background whicj i already shut down,
its about the bench result on my link, u can clearly see my model got higher latency than the other
the Kingston KHX2133C14D4/8G 8GB which is exactly the same than me exept it got LONGER timings (cl14) instead CL13 for me got 32NS while my model is bench at 82NS.
i cant be more clear, i think my model is a bad model heve got a X the end of model number think thjis is what change
4,374 (0.94/day)
St. Paul, MN
System Name Bay2- Lowerbay/ HP 3770/T3500-2+T3500-3+T3500-4/ Opti-Con/Orange/White/Grey
Processor i3 2120's/ i7 3770/ x5670's/ i5 2400/Ryzen 2700/Ryzen 2700/R7 3700x
Motherboard HP UltraSlim's/ HP mid size/ Dell T3500 workstation's/ Dell 390/B450 AorusM/B450 AorusM/B550 AorusM
Cooling All stock coolers/Grey has an H-60
Memory 2GB/ 4GB/ 12 GB 3 chan/ 4GB sammy/T-Force 16GB 3200/XPG 16GB 3000/Ballistic 3600 16GB
Video Card(s) HD2000's/ HD 2000/ 1 MSI GT710,2x MSI R7 240's/ HD4000/ Red Dragon 580/Sapphire 580/Sapphire 580
Storage ?HDD's/ 500 GB-er's/ 500 GB/2.5 Samsung 500GB HDD+WD Black 1TB/ WD Black 500GB M.2/Corsair MP600 M.2
Display(s) 1920x1080/ ViewSonic VX24568 between the rest/1080p TV-Grey
Case HP 8200 UltraSlim's/ HP 8200 mid tower/Dell T3500's/ Dell 390/SilverStone Kublai KL06/NZXT H510 W x2
Audio Device(s) Sonic Master/ onboard's/ Beeper's!
Power Supply 19.5 volt bricks/ Dell PSU/ 525W sumptin/ same/Seasonic 750 80+Gold/EVGA 500 80+/Antec 650 80+Gold
Mouse cheap GigaWire930, CMStorm Havoc + Logitech M510 wireless/iGear usb x2/MX 900 wireless kit 4 Grey
Keyboard Dynex, 2 no name, SYX and a Logitech. All full sized and USB. MX900 kit for Grey
Software Mint 18 Sylvia/ Opti-Con Mint KDE/ T3500's on Kubuntu/HP 3770 is Win 10/Win 10 Pro/Win 10 Pro/Win10
Benchmark Scores World Community Grid is my benchmark!!
nan·o·sec·ond
ˈnanōˌsekənd/
noun
noun: nano-second
  1. one billionth of a second.
And you are worried about 50 of them?
:kookoo:
42,821 (6.70/day)
Placebo effect dude. You wouldn't be able to tell the difference in real world. Not happy with 'em? Send 'em back and spend moar!
11,878 (2.20/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
https://www.memorybenchmark.net/latency_ddr4_amd.html
Thats the list WITH Amd cpus as a comparison , and even there, lower speed, lower latency, higher speed = higher latency, those are guided by the laws of physics and the processes used to design and produce chips , only a next gen tech is budging that from our reality, ie massive bandwidth architectures like HBM.
Crazy overclocking can reduce it marginally.
44 (0.02/day)
youre right, one billionth of a second seems nothing. and after some search its seems have no impact on performance.
im just worried to see, than gta 5 run less good on r7 1700 3.8ghz than with my i5 6600k @4.5ghz, intel win the game this time, so i was lookin for any issues who can resolve my fps drop than i havnt before.
thanks for the link its all clear now, all 2133 got this latence, it seems cpu or platform imposed this , next step will be the b-die 3200mhz :p
42,821 (6.70/day)
Try to get 4.0 from the 1700.
42,821 (6.70/day)
44 (0.02/day)
it look nice with 12 pipe, my pure rock only have 8, thats why i wont go over 1.375 on this ventirad.
