https://www.reddit.com/r/sffpc/comments/12ne6d7
I want an ITX / low length/single fan RTX 4070 with 16GB VRAM. (Or rather something like the 1080Ti mini for the 4070Ti (Super/16GB VRAM))
It's ~200W just like the numerous ITX 1080/2070(S)/3060Ti, all ~1 "Liter" in size, so ~200 "Watt per Liter"
We should be getting better/more efficient/smaller cooler designs over time, not larger
What's so so sad is that individual people are modding their 4070/Tis to ~1 Liter. so so sad how companies with 100s of (paid) ppl don't want to / cannot make a product that already kinda used to exist 6-7 years ago but 1 unpaid passionate person can
Basically if you ignore watercooling (which kinda just moves the cooler elsewhere/most waterblocks aren't single slot) or modded cards like linked in the thread you can't get what existed years ago
Best case you buy one of those workstation cards (A4000 successors) for well over $1000 to get the same performance as you would for <$500, but not at even close to 1/2 the power consumption or size
I should add here that technically there is already a "<=175W 4080/4070", the Laptop 4090/4080 lol
Which in turn is kind of sad because there used to be a 200W 2080 desktop/laptop that didn't need this awful segmentation/naming/power limiting/scamming
More efficient GPUs to just run them at idiotic power levels and larger coolers at idiotic prices with idiotic memory setups with idiotic naming schemes/segmentation lol
AMD dGPUs are seemingly non existent in laptops, which is kinda funny because there's little reason to buy a non AMD CPU laptop other than supply/them existing (Intel = bad battery / bad iGPU until MTL, it's fine in larger laptops I guess). RDNA3 is significantly less efficient than RTX4xxx/Ada Lovelace anyways
I was hoping for an ITX 7600+/7700 but...
Maybe never mind since even the 7600 at 165W only has double fan GPUs ("at least" they're 200mm 2 slot)
So sad even the Powercolor 5700 ITX is more space efficient at 175mm 2 slot while 180W
I don't understand how over many years we get worse cooling/space efficiency
I am only asking for >200W/L like we had 6-7 years ago, surely you would think over that time we would get even better cooling performance like we do better computing performance
I can fit 2 GPUs in my case (more if watercooled or ITX lol) with minor modding, I don't require this, but it's sad to not get something we had many years ago, forget getting something better.
(The MSI Ventus 4070Ti Super is close, all the 4080/90 cards are too big for their power draw, or they require watercooling while already being big...sad. )
Watercooling exists but when the PCBs for the GPUs are >200mm to begin with, you can't get a <200mm card.
Or they make all 4070 PCB <200mm but then make no <200mm cards lol I don't understand (If you were going to watercool it would be 99% silly to watercool a 4070/Ti instead of a 4080/90).
There also needs to be waterblocks accordingly (idk not much demand for <200mm single slot waterblock lol)
Edit: Inno3D's 4070TiS is "good" at 230 W/L
