Where can i find a 220mm case fan
xu^
1,140 (0.18/day)
Lancs,UK
System Name Mr_average ( hoping 1 day to upgrade to Mr_above_average )
Processor AMD Ryzen 7 7700x
Motherboard Asrock B650 Steel Legend Wi-fi
Cooling Deepcool AS-500 Plus - White | 6 Lian Li ST120mm case fans - White
Memory 32gb Corsair Vengeance RGB 2x16gb 6000mhz DDR5 - White
Video Card(s) Asus Dual GeForce RTX 4070 12GB OC
Storage 512gb Sabrent Nvme | 4tb Samsung SSD | 2tb WD Blue SSD| 1tb Crucial P3 Nvme| 1tb WD Blue HDD = 8.5tb
Display(s) D1: LG Ultragear GL850-B 27" 1440p 144hz | D2: Asus Tuf - VG249 24" 1080p 144hz
Case Lian Li Lancool 2 Mesh RGB - White
Audio Device(s) Creative Gigaworks T20 Series II | Steelseries Arctis 3 Headset - White
Power Supply Corsair TX650M Semi Modular 80+ Gold
Mouse Razer Basilisk V3
Keyboard Razer Huntsman V2
hi all having a hard time locating a 220mm fan for my case, to replace the 1 in it, i usually have to push start it for last week or 2.
The problem is I can't seem to find 1 online to buy, eBay/amazon most UK PC component sellers, none have any, can anybody help? case is a Thermaltake Armour.
2,141 (0.52/day)
Serbia
Processor Ryzen 5600
Motherboard X570 I Aorus Pro
Cooling Deepcool AG400
Display(s) 24G2U
Case NR200P
Power Supply Ion SFX 650
Mouse G703 (TTC Gold 60M)
Software W10
You should check if they send to UK (because of the whole covid situation).
220 is not a standard size. If you can and are willing to, get a 200mm and getto mod it. Those are available everywhere
Example:
834 (0.46/day)
Maryland, USA
Processor Ryzen 5 5600X
Motherboard MSI MPG X570S Carbon Max Wifi
Cooling CPU: bequiet! Dark Rock 4. Case fans: 2x bequiet Silent Wings 3 140s, 2x Silent Wings 3 120s
Memory 2 x 8 GB Patriot Viper Steel DDR4-4400 C19
Video Card(s) Sapphire NITRO+ RX 5700 XT
Storage 2TB Mushkin Pilot-E M.2, 1 TB SK Hynix P31 M.2, 1 TB Inland Professional, 500 GB Samsung 860 Evo
Display(s) MSI Optix MAG271CQR 1440p 144Hz, MSI Optix MAG241C 1080p 144Hz
Case Lian Li Lancool III
Audio Device(s) Philips SHP9500, V-Moda BoomPro, Sybasonic Better Connectivity USB DAC/Amp
Power Supply EVGA SuperNOVA G3 80+ Gold 750W
Mouse Glorious Model D Wireless
Keyboard Custom Qwertykeys Navy QK80: Sarokeys Strawberry Wine switches, GMK CYL DMG3 keycaps
Alternatively, you could try contacting Thermaltake directly and see if they can provide you with a replacement.
xu^
1,140 (0.18/day)
Lancs,UK
have messaged Thermaltake, but not really hopeful, they will no doubt just say its discontinued and they done sell spares :)
The one on newegg would do the job, but wow at that price plus shipping!!!
Looks like i might either have to try a mod(botch) a smaller fan or just leave it without :(
2,963 (0.83/day)
Long Island
I source 25mm - 360mm here... ya got a similar source over in UK perhaps ?
200mm
230mm
Tatty_Two
Gone Fishing
25,952 (3.74/day)
Worcestershire, UK
Software Win 11 Home x64
I have a big fan in the garage as good as new, I had it in a Coolermaster HAF case that I only used for about 4 months (the case, just didn't get on with it, fan came with it), not sure what size it is but will measure it in the morning and let you know unless you find something in the next few hours, if it's any good you can have it for the price of postage.
Edit: I just quickly checked Coolermasters website and the HAF932 comes with a 230mm, I am guessing that will be the size of mine although I bought the case in 2010 I think.
Edit 2: I think it may be 200mm will confirm in morning, think I have found specs for it online, it appears to be a 200mm fan but the outer bracket makes it 230mm x 200mm.
