Where can I find GPUs idle power consumption specification? (my country electricity cost is one of the highest)
iulil
2 (1.00/day)
I searched for datasheets with Gpu power consumption at idle and I haven't found anything. How is it possible? I think that is an important data to know. Where should I look to have an official source or very reliable for this data? For example for the Rtx 2080 Ti or Rtx 3060 Ti.
Thank you
625 (0.39/day)
Greece
System Name Office / HP Prodesk 490 G3 MT (ex-office)
Processor Intel 13700 (90° limit) / Intel i7-6700
Motherboard Asus TUF Gaming H770 Pro / HP 805F H170
Cooling Noctua NH-U14S / Stock
Memory G. Skill Trident XMP 2x16gb DDR5 6400MHz cl32 / Samsung 2x8gb 2133MHz DDR4
Video Card(s) Asus RTX 3060 Ti Dual OC GDDR6X / Zotac GTX 1650 GDDR6 OC
Storage Samsung 2tb 980 PRO MZ / Samsung SSD 1TB 860 EVO + WD blue HDD 1TB (WD10EZEX)
Display(s) Eizo FlexScan EV2455 - 1920x1200 / Panasonic TX-32LS490E 32'' LED 1920x1080
Case Nanoxia Deep Silence 8 Pro / HP microtower
Audio Device(s) On board
Power Supply Seasonic Prime PX750 / OEM 300W bronze
Mouse MS cheap wired / Logitech cheap wired m90
Keyboard MS cheap wired / HP cheap wired
Software W11 / W7 Pro ->10 Pro
Officially I don’t think so, but TPU’s reviews are very enlightening.
1,711 (1.07/day)
Processor 5800X3D -30 CO
Motherboard MSI B550 Tomahawk
Cooling DeepCool Assassin III
Display(s) Dell S2721QS 4K60
3,889 (1.33/day)
Case Thermaltake Core P5
Keyboard Corsair K100 RGB
VR HMD HTC Vive Cosmos
Lets start with what is idle?
Monitors off? Monitors on? Which monitors? 1080p probably works no matter what. Multiple monitors or something like 2160p at 120hz might need higher clocks to properly show the picture. Run 3 high resolution monitors at different frequencies and you will get higher clocks and consumption.
Apps open? Browser open? Something moves on the monitors? Do you have video playback somewhere? Depending on what does playback even in background may matter plus browsers tend to use a bunch of resources. There are other applications with hardware acceleration that are or have raised GPU clocks. Skype comes to mind, some older version of iCUE did, monitoring software often as well.
Plus, settings for both GPU and other bits. For example there are power settings where you can set to to High Performance and it will naturally keep clocks higher.
Basically there is no idle specification and probably cannot really be.
Best bet as previous posters say is rely on reviews with similar scenarios as yours being tested. Even then it is worth noting that manufacturers sometimes/often enough do fix some of the excessive power usage at idle if possible.
3,482 (4.93/day)
Russian Wild West
System Name DLSS / YOLO-PC / FULLRETARD
Processor i5-12400F / 10600KF / C2D E6750
Motherboard Gigabyte B760M DS3H / Z490 Vision D / P5GC-MX/1333
Cooling Laminar RM1 / Gammaxx 400 / 775 Box cooler
Memory 32 GB DDR4-3200 / 16 GB DDR4-3333 / 3 GB DDR2-700
Video Card(s) RX 6700 XT / R9 380 2 GB / 9600 GT
Storage A couple SSDs, m.2 NVMe included / 240 GB CX1 / 500 GB HDD
Display(s) Compit HA2704 / MSi G2712 / non-existent
Case Matrexx 55 / Junkyard special / non-existent
Power Supply Thermaltake 1000 W / Corsair CX650M / non-existent
Software Windows 11 / 10 / 8
TL;DR usually the best GPU in this regard is the lowest tier current gen NVIDIA card. Today it's 4060/Ti. Tomorrow, must be 5060/Ti. AMD GPUs aren't far behind but that still might prove a couple kW annual difference. Intel GPUs are currently to avoid. Might become better with Celestial, who knows.
I wouldn't bother anyway. Idle and light load power consumption is so miniscule it's easy to compensate for it by working a couple additional days this year. That is if one kW is about $1 expensive and you work shit job that pays 6 dollars an hour after taxes.
Worst case scenario: 40 W difference, PC turned on 24/7, 350 kWh annual difference. Noticeable but usually the difference is about five to seven times less pronounced.
3,889 (1.33/day)
My 4070TI Super has a power consumption of about 3.5 watts when monitors are turned off.
The ~30W at idle from 7800X3D absolutely eclipses that :D
9,686 (3.46/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
The absolute best DGPU I have seen at idle would be the 6500XT. 3 Watts at idle. I am not kidding. Not that it is a GPU for anything more than 1080P Gaming though. Before you jump remember it blows away the 8700G in Gaming so you could get away with it. I would not pay more than $100 for one of those though.
3,482 (4.93/day)
Russian Wild West
Kinda odd to recommend that to a person already looking at the likes of 2080 Ti and 3070, doncha think so? 6500 XT is furiously bad at PCI-e 3.0 and is even worse if the OP rocks a non-pedestrian resolution display and wants to have positive framerates. If we REALLY insist on going AMD then plain RX 7600 is the most reasonable thing. Alas, 4060 is a tad faster, supports DLSS and has better efficiency under load. All that for just a couple dozen USD premium.
4,139 (0.94/day)
System Name Skunkworks 3.0
Processor 5800x3d
Motherboard x570 unify
Cooling Noctua NH-U12A
Memory 32GB 3600 mhz
Display(s) Asus 1440p144 27"
Mouse *squeak*
Software Manjaro
It's kinda odd to be worried about the idle power draw on a $400+ GPU in the first place, so /shrug
3,482 (4.93/day)
Russian Wild West
Not every1 is as lucky as us seven-centers. In some countries, it's cheaper to go more perf/W than it is to go more perf/$. Imagine paying a dollar for a kW. This translates into, say, if we have 20 W difference on average, 175 annual dollars savings on electricity alone (PC runs non-stop). Since number a people use GPUs for several years it makes to own a 3080 almost a thousand dollars more expensive than it is to own a 4070 despite it being 100ish dollars cheaper on the used market.
4,139 (0.94/day)
Processor 5800x3d
Mouse *squeak*
Software Manjaro
If you leave your PC on 24/7, and you are not making money with it, you are stupid. No if ands or buts about it. Seriously, WHY would you do that? Especially if you have such expensive electricity.....
And if $175 is a lot of money to you, you cant afford a $400 GPU. Period. If it's that much of an issue, you buy an APU and use that. If you're making money from it, then the electric usage shouldnt be a problem.
Also, it wont be $175. The highest rate for electricity int he world is Bermuda, at $0.458 per kWh
So that's $80.24 per year, if you idle it for 24 hours a day.
If $80 per year is a dealbreaker, you should not be buying $400 GPUs and leaving them on 24/7 for no reason. The "muh power use" argument has frankly NEVER made sense.
If you're worried about power use, go work one(1) extra shift ac McDonalds per year. There you go, cost covered.
1,088 (0.73/day)
Processor E5-4627 v4
Motherboard VEINEDA X99
Memory 32 GB
Video Card(s) 2080 Ti
Storage NE-512
Display(s) G27Q
Case DAOTECH X9
Power Supply SF450
If you're in possession of said cards why not run Gpuz or hwinfo.
But with a 15 W GPU you're still looking at 50 W at the wall with 50% PSU efficiency, lost as heat.
3,776 (1.91/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 200W PPT limit, 80C temp limit, CO -6-14, +50MHz (up to 5.0GHz)
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MT/s 1.38V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (382W current) PowerLimit, 1060mV, Adrenalin v24.12.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.2605), upgraded from Win10 to Win11 on Jan 2024
Thank you
No way for any GPU maker/designer to able to get that on a datasheet.
Every system will work differently depending on the monitor, how many monitors, what is loaded on the background, what quality settings windows are using, refresh rates and sync functions, what settings apps using and so on and on...
No one will test a vast variety of configurations just to measure idle/low load power and tell you that this is it with this configuration, only for a user later to find that his GPU is not "idling" at 20W but at 30W for example because the settings are 2% different.
A modern PSU even at 8~10% load "start" its efficiency at no less than 85%
So a 750W Gold PSU at 70~80W output will be well above 80% efficiency, close to 85% actually.
If CPU+GPU+rest of system are consuming about 70W then at the wall will be around 85W (70+20% heat)
For example
iulil
2 (1.00/day)
The graph shows that American power outlet are less efficient than European ones?
3,776 (1.91/day)
All PSUs have the ability to be plugged to 110~240V socket.
European power grid and most of the world is at 230V and when is that the case, PSU efficiency is 2-3% better than when the same PSU is plugged to 110-115V power grid.
BTW that graph is from a Gold rated PSU.
