drpeppercan
- Dec 10, 2020
- 6 (0.00/day)
- Montreal
Oh yeah, I see the connectors. Now, which one is it? Left or Right? And, top row, or bottom row?A seen in section 1-1 "Motherboard overview" (page 10) , the 2 x USB_HEADER are located on the bottom, they bear the number 12.
edit : if i'm not mistaken, the usb pinout is here to provide bluetooth connectivity, while the wifi card depends only from the PCI-E slot it is plugged in.
Benchmark Scores | Faster than yours... I'd bet on it. :) |
??????Oh yeah, I see the connectors. Now, which one is it? Left or Right? And, top row, or bottom row?
Unless I missed it, I don't see a USB 2.0 header. No idea about adapaters.Hello,
I came cross a similar problem. I bought a Gigabyte GC-Wbax200 2x2 802.11Ax Dual Band WiFi + Bluetooth 5 PCIe Expansion Card and hope to use both WiFi and Bluetooth. The WiFi is working but the Bluetooth isn't because I cannot see any F-USB connection on the HP-Elitedesk-800-G2-SFF-Desktop motherboard. All I can see are USB-C (6-pin) and Front USB (12-pin) , Front USB 3.0 marked on the motherboard.
Should I use USB-C port instead? Is there a cable available (USB-A header to USB-C port)? Can I use the other normal USB-A on the Expansion Card to connect to USB-A outside the computer case?
Any advice will be appreciated it.
Ahh, the wonders of proprietary connections... thanks OEMs!Thank EarthDog for answering my query.
Luckily today I found a post at https://forums.lenovo.com/ and followed the instructions written by psuturtle, Lenovo Staff:
(1) connecting USB header to 3-12 pins
(2) putting a jumper between 1+2 pins
Now the Bluetooth is working perfectly
