Where to find PTM7950 paste?
Kucing
8 (1.14/day)
A lot of people saying that there are many fake PTM7950s. I am looking for the paste not the pads so it's even harder to find anything. I found this on ebay but no reviews of the item (just of seller) and come from china. So,anyone can suggest me a source to buy legit ptm7950 paste ?
3,097 (6.51/day)
System Name The Workhorse
Processor AMD Ryzen R9 5900X
Storage Adata SX8200Pro
Display(s) LG 32GK850G
Software Windows 11 Pro (24H2)
44,062 (6.81/day)
I believe honeywell is the only legit maker of it, Amazon it even
445 (0.37/day)
Denmark
Processor AMD Ryzen 7 3800X
Motherboard ASUS Prime X470-Pro
Cooling bequiet! Dark Rock Slim
Memory 64 GB ECC DDR4 2666 MHz (Samsung M391A2K43BB1-CTD)
Video Card(s) eVGA GTX 1080 SC Gaming, 8 GB
Storage 1 TB Samsung 970 EVO Plus, 1 TB Samsung 850 EVO, 4 TB Lexar NM790, 12 TB WD HDDs
Case Corsair Obsidian 550D
Audio Device(s) Creative X-Fi Fatal1ty
Power Supply Seasonic X-Series 560W
Keyboard Glorious GMMK
According to Igor's Lab the pad is a lot better than the paste.
2,640 (1.22/day)
Olympia, WA
System Name Sleepy Painter
Processor AMD Ryzen 5 3600
Video Card(s) MSI RX580 8GB
Case NZXT Gamma Classic Black
Audio Device(s) Asus Xonar D1
Mouse Logitech MX518 Legend
Keyboard Red Dragon K552
Engrish translation aside:
Basically, the paste version is not as good (likely from cold viscosity limiting bondline thinness)
and (being PTM) quasi-solidifies into something glue-like, regarding removal. [The thin sheet PTM seems to limit the mechanical bonding strength, better]
Personally, I'd imagine setting the (sealed) tube of PTM paste into some hot/near-boiling water, allowing it to 'heatsoak'
might make the application easier, and with a thinner bondline (improving performance).
I wouldn't consider doing this with 'traditional' pastes, as they're a suspension. PTM is a Phase Change Material, it *shouldn't* separate, short of active chemical attack.
Regardless, Igor mentioned it's easier to apply and more-useful for especially topographically-mismatched thermal bonds.
Kucing
8 (1.14/day)
Wow, good to know. I thought that pads are always worse than paste. Is this just an exception?
21,962 (3.42/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Case Thermaltake Core X31
Software Gentoo Linux x64
Heard good things about buying from here:
Should be fine. It’s a respectable shop from what I know.
I bought from there and did indeed get the genuine stuff. Shipping is a bit harsh to the USA, but YMMV. I just threw some other articles in there to make it "worthwhile."
2,640 (1.22/day)
Olympia, WA
Have you done many applications with it? How 'bad' is it to apply? Does warming it up help?
I'm (usually) too unsteady to apply cut PTM patches. A paste ver. of the stuff is very attractive.
21,962 (3.42/day)
Olympia, WA
System Name Pioneer
I didn't buy the paste version. For the pad version though its the opposite, 15 mins in the freezer massively aids in making the application doable.
It is very sticky clingy and prone to breakage, unlike normal thermal pads. The freezer seems to lessen this enough to make it "average" difficulty. Without that trick I might even call the application "hard."
I've done three applications total (once on my cpu and 2x gpus, a 6900 XT and a 7900XTX).
I can relate as I'm fairly disabled in one arm (nerve issues from a bad bone break cause random spasms). But I manage it if I do the freezer trick so it must not be awful.
2,640 (1.22/day)
Olympia, WA
I've done this 'trick' the 3 or 4 times I've (attempted to) apply the stuff. It certainly 'helps' but if you're not quick and/or you have high ambients, the 'help' is EXTREMELY short-lived.
Unironically, encouraging. :)
Next time I try to use the sheet, I'll leave it in longer, and try to prop the sheet atop a cold pack (to give me a little working time to coordinate myself :laugh:)
21,962 (3.42/day)
Olympia, WA
System Name Pioneer
To be fair my freezer is known to be on the cold side. It seems to be well below what most normally operate at for some reason so maybe add some minutes yeah. :)
2,640 (1.22/day)
Olympia, WA
Also, TBF
That sub-mm sheet is purposefully thermally conductive and of near-zilch thermal mass :laugh:
325 (0.41/day)
Processor AMD Ryzen 7 7800X3D (4.2Ghz base, 5.0Ghz boost, -30 PBO offset)
Video Card(s) PowerColor Radeon RX 7900 XTX Red Devil OC 24GB (2.39Ghz base, 2.99Ghz boost, -30 core offset)
Mouse Logitech G502 X LIGHTSPEED Wireless Gaming Mouse
Keyboard Keychron K4 Wireless Mechanical Keyboard
Software Arch Linux
And 80x40 pad from MODDIY to Australia cost me $27USD plus $10USD. How does that compare to the US?
593 (2.18/day)
System Name XPS, Lenovo and HP Laptops, HP Xeon Mobile Workstation, HP Servers, Dell Desktops
Processor Everything from Turion to 13900kf
Motherboard MSI - they own the OEM market
Cooling Air on laptops, lots of air on servers, AIO on desktops
Memory I think one of the laptops is 2GB, to 64GB on gamer, to 128GB on ZFS Filer
Video Card(s) A pile up to my knee, with a RTX 4090 teetering on top
Storage Rust in the closet, solid state everywhere else
Display(s) Laptop crap, LG UltraGear of various vintages
Case OEM and a 42U rack
Audio Device(s) Headphones
Power Supply Whole home UPS w/Generac Standby Generator
Software ZFS, UniFi Network Application, Entra, AWS IoT Core, Splunk
Benchmark Scores 1.21 GigaBungholioMarks
3,097 (6.51/day)
I can only advise here, if we talk CPU usage, to try going for Thermalright Heilos pads. Those are ones that I can vouch for and have good reviews (ie they perform on par with HW PTM) and the benefit there is that they come pre-cut in the correct size for either AMD or Intel, depending on the SKU.
23,514 (6.13/day)
2,188 (0.47/day)
Netherlands
System Name TheDeeGee's PC
Processor Intel Core i7-11700
Cooling Noctua NH-D15S
Display(s) EIZO CX240
Mouse Logitech G500S
Keyboard Keychron Q6
If you're from the EU i recommend a Thermal Grizzly Kryoaheet, easy to get and cheaper than importing a TPM.
Using a Kryosheet on both my 4070 Ti and Intel NUC.
Just make sure you have some kapton tape as well to cover SMD's, i did that on my 4070 Ti.
