Which case mounting holes are for this case
70 (0.03/day)
Croatia
System Name Level 3 mage
Processor Xeon e3-1225v3
Motherboard Asus Maximus Hero VII
Cooling Huh Stock intel Cooler
Memory HyperX Fury 1866 2x8GB
Video Card(s) R9 280 w/ R7 250
Storage 1TB Toshiba P300, PM981 OEM HP M.2, SA400 Kingston 480GB
Display(s) Some random Acer, Asus VW228N
Case Ehh steel?
Audio Device(s) Logitech S200
Power Supply VS550
Mouse Speedlink LEDOS
Keyboard Genius
Software Windows 10?
Benchmark Scores 1050Ti superposition unofficial world record https://ibb.co/fkQhhc
Hello again...
I wonder which case size is this?
Thank you, very,very much!
newtekie1
Semi-Retired Folder
28,472 (4.17/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
It looks like it is Micro-ATX.
sneekypeet
Retired Super Moderator
29,426 (4.41/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
Agreed with newtekie, I recall there were motherboards not as wide as the typical M-ATX, but still classified as such.
66 (0.01/day)
System Name Ragnars Rig
Processor AMD Ryzen 7 5800X 3D
Motherboard ASUS Pro WS X570-ACE
Cooling 3x140 Copper Rad, Koolance CPU-380I Waterblock, XSPC X20 750 Pump/Reservoir, EKWB GPU Waterblock
Memory G.SKILL TridentZ RGB Series 16GB (2 x 8GB) DDR4 3600MHz
Video Card(s) EVGA RTX 2080 Ti FTW3 ULTRA GAMING
Storage Samsung OEM 500GB PCIe NVME, Samsung EVO 500GB SATA SSD, 2TB WD Black, 4TB WD Black
Display(s) DELL S2716DG 27" 144hz, Vizio D50U-D1 4K 50" 60hz,
Case Fractal Design R5 Black w/Window
Audio Device(s) Logitech G533 7.1 Wireless Headphones
Power Supply Seasonic SSR-1200PD 1200W PLATINUM
Keyboard Corsair Strafe w/ Cherry MX Reds
Software Windows 10 Education x64
70 (0.03/day)
Croatia
Case Ehh steel?
Power Supply VS550
Keyboard Genius
Soo thats yes for H81M-DGS R2.0?
dorsetknob
9,106 (1.29/day)
M-ATX four expansion slots :) and Crap Airflow Dremel time.
edit having just spotted the AT power input M-ATX or M-AT
70 (0.03/day)
Croatia
Case Ehh steel?
Power Supply VS550
Keyboard Genius
Does this give you better idea?
(Note TOP LEFT
(Note TOP LEFT)
dorsetknob
9,106 (1.29/day)
No model number on case you can google ?
70 (0.03/day)
Croatia
Case Ehh steel?
Power Supply VS550
Keyboard Genius
No, but Im going to ask for more detailed.
There it is... He said he has no clue what was in it... Since he is not soo techy.
590 (0.26/day)
40,803 (6.55/day)
Cooling Scythe Ashura, 2Ă—BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED
590 (0.26/day)
lay out the hole placements from the ATX specs you show above on a cardboard template if you don't have a motherboard to try, but looks like the links I gave above shows the spec's yopu needed
''UP to M-atx '' now what fits in the ''UP TO '' ????
13,626 (3.82/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
If you are thinking of buying that case be wary of the PSU, it looks like a sff unit that may be proprietary and installed remotely inside.
70 (0.03/day)
Croatia
Case Ehh steel?
Power Supply VS550
Keyboard Genius
Phsyically, hard, its 400km away from me, But the thing that the middle bottom has 2 and that indicates for micro atx.
Im going to buy it and pray that it fits, cause im sick of my case.
And probably mod it to fit antec H2o 1250.
Im just gonna fit the diy way with watercooling aio.
Thanks everyone for help.
590 (0.26/day)
if you list what cases your interested in and go look up there specs they shpuld have supported form factors plainly listed
Motherboard Compatibility ... ATX, uATX, mITX, (E-ATX* - up to 285mm wide) like with that pretty much one case fits most all boards , so its pretty flexible on any board up grade you may want to do
like on the cheap and new
Motherboard Compatibility ... Micro ATX / ATX / Mini ITX / E-ATX
https://www.newegg.com/Product/Prod...853064&cm_re=eATX_case-_-11-853-064-_-Product
2,851 (0.51/day)
MN
System Name Personal / HTPC
70 (0.03/day)
Croatia
Case Ehh steel?
Power Supply VS550
Keyboard Genius
590 (0.26/day)
if you can make it fit why I said it looks to be a proprietary PSU .
https://hardforum.com/threads/antec-aria-psu-replacements.929928/
few more asking on that
but if your handy with a hammer and hacksaw I guess anything can be modded in place its not like you got the room as if it was a mid/ full tower case to play around with either.
its you project and only you got the plan on what you want and end up with
887 (0.15/day)
Processor Intel Core i3-8100
Motherboard ASRock H370 Pro4
Cooling Cryorig M9i
Memory 16GB G.Skill Aegis DDR4-2400
Video Card(s) Gigabyte GeForce GTX 1060 WindForce OC 3GB
Storage Crucial MX500 512GB SSD
Display(s) Dell S2316M LCD
Case Fractal Design Define R4 Black Pearl
Power Supply Corsair CX600M
Mouse Logitech M500
Keyboard Lenovo KB1021 USB
The power supply in the Antec Aria case is very proprietary:
887 (0.15/day)
Cooling Cryorig M9i
Mouse Logitech M500
590 (0.26/day)
if me I would just get a sheet of alum or steel plate / sheet metal and build a wall hanger cut the sheet for the board ,psu ,drives, radiator/ fan , ect... drill it out and mount all I wanted to it and hang it like a picture then let the big dog eat
70 (0.03/day)
Croatia
Case Ehh steel?
Power Supply VS550
Keyboard Genius
Hahahahahaha
