- Jun 3, 2012
- 1,981 (0.43/day)
- Denmark
Processor | Ryzen 5 7600 |
Motherboard | Asrock B650 PG LIgtning |
Cooling | arctic freezer 36 |
Memory | 2 x Team Group T-Create Expert DDR5-6000 - 32GB - CL30 (64gb) |
Video Card(s) | ASUS Dual GeForce RTX 4070 EVO |
Storage | 1x2tb KC3000 & 2tb samsung 970 evo plus, 2 x 2 tb external usb harddrives |
Display(s) | LG 32GP850, IIyama G2470HSU-B1 |
Case | Corsair 5000D airflow tg |
Audio Device(s) | Yamaha R-N800A Syatem audio signature 5 |
Power Supply | Corsair RM850X White |
Mouse | Asus Rog Gladius III Wireless Aimpoint |
Keyboard | Corsair K70 RGB TKL Champion |
Software | Windows 11 64 bit, Free Avira Security |
I do have a 240mm aio although it's the cheapest cooler master it does a good job with my ryzen 3600 at 4.3ghz on all cores and 1.200 volt and 2x Arctic P12 pwm fans (under 80c in aida64 cpu + fpu)
For some reason i do get the slightest hum (stille considered silent) i don't think is from my gpu but my aio
Im therefore considering an air cooler but which cooler
Noctua NH-D15 is hawing a slightly hum but can can be bought in a am4 version
Noctau NH-D15S doesn't come with am4 mounting brackets or weak hum
Be Quiet Dark Rock 4 (alternative to a NH-D15S) if i had to clean the tower it can be difficult to thake the fans of som say the pro4 is hard to mount
Deepcool Assassin III big and expensive and not better than a Noctua NH-D15
Than theres Scythe:
Mugen 5 PCGH I have had one it's very silent but might not cool as good in stress test,max load do to 800 rpm fan, the Scythe Kaze Flex are even better than the Arctic P12 fans, cheap.
Fuma 2 2x 1200rpm Kaze Flexz fans, more expensive than the Mugen 5 PCGH
Scythe Ninja 5 big and more expensive than the Mugen 5 PCGH and it comes with the same fan
Which scythe cooler is the best ?
Than theres Scythe:
