Which do I use? i7TurboGT? RealTemp? Or RealTempGT
Daniel Jackson
2 (0.00/day)
The title makes the question obvious. I have a core i7 Surface Pro 3... I'm currently using the standard RealTemp to see my temps as the GT one is slightly different in minimum and maximum temp values. But the i7 is the core that I have yet I don't see how to understand the data being displayed in the temps so I am not sure if that's what I am actually supposed to use.
Any advisement is appreciated. Thanks all.
unclewebb
7,940 (1.32/day)
RealTemp GT is for the 6 core CPUs. The Core i7 in your Surface Pro 3 only has 2 cores so the regular RealTemp.exe is for you.
There is also an updated version of RealTemp available. It has a few more features for the newer Core i7 CPUs like you have.
RealTemp T|I Edition
https://drive.google.com/open?id=0B0dpSo9k93jDZlpmbHNzeFlpcWc
A difference of a degree or two between different temperature apps is normal. Most of these programs only update once or twice every second. CPU core temperatures can change much faster than that so slight differences in reported temperatures are normal.
For temperature testing, you can use Prime95 - Small FFTs for testing. It equally loads all cores of a CPU so the temperatures reported from various monitoring programs should be almost exactly the same. Most other testing programs do not equally load the cores like Small FFTs does.
What data do you not understand? Post a picture or a specific question.
The best monitoring program for a Surface Pro 3 is ThrottleStop. It has a lot more features to get the most out of these devices but is intended for advanced users. I wrote both of these programs so these downloads are 100% safe.
ThrottleStop 8.00
https://drive.google.com/open?id=0B0dpSo9k93jDTE1fcHNtbUMwdGc
Daniel Jackson
2 (0.00/day)
ThrottleStop 8.00
Picture on page "Untitled page" (Web view)
I took a screenshot with the surface pen and linked it so I don't know if the link works or not, this is the first time using it.. I've never used these before so the data in the i7 program is all new to me. But, I don't really have to understand it because I will use the program you suggested for the Surface Pro 3.
Great help man thank you so much for your response and help I very much appreciate it!
13,791 (1.87/day)
ThrottleStop 8.00
Too bad the updated version has no GT version to support 6 core CPU's. Just switched to 5820K :p The old one works fine, but I'm kinda obsessed with having software updated. If it's not updated for a year or two, it just feels weird to me lol
unclewebb
7,940 (1.32/day)
unclewebb
7,940 (1.32/day)
It's a work in progress. Maybe it will be ready someday.
7,530 (1.47/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
Bo$$
Lab Extraordinaire
5,656 (1.00/day)
London, UK
System Name Desktop | Server
Processor Intel i7 2700k @ 4.6GHZ | AMD 5350 @ 2500MHZ
Motherboard Asus P7Z77-V Pro | Asus AM1I-A
Cooling Corsair H60v2 | Stock Air
Memory Crucial Ballistix 2x8GB CL8 1600MHZ | Corsair Vengence 2x4GB CL9 1600MHZ
Video Card(s) EVGA GTX 1060 6GB | PNY GTX 750Ti
Storage Samsung 840 EVO 250GB + 4TB WD Red | 2x Seagate Barracuda 2TB
Display(s) Samsung S27D390H + Asus VE276Q | Headless
Case Fractal Design R5 | CM Elite 110
Audio Device(s) Asus Xonar D1 w/Otone Stilo 5.1 and Creative Fatal1ty headset
Power Supply EVGA Supernova 850 G2| Corsair CX430M
Mouse Razer Imperator 2012
Keyboard Corsair K90
Software Windows 7 SP1 X64 | Ubuntu 16.04LTS
whats the difference between GT version and the regular one?
Bo$$
Lab Extraordinaire
5,656 (1.00/day)
London, UK
389 (0.08/day)
Processor AMD Ryzen 9 5900X
Motherboard Gigabyte B550 Aorus Pro
Cooling Wraith Prism
Memory Crucial Ballistix 3600Mhz 16GB (4x8GB)
Video Card(s) -
Storage Samsung 850 Evo, 860 Evo, 980 and Crucial MX500
Display(s) Samsung Neo G9 Odyssey
Case Corsair 7000D
Power Supply -
VR HMD Quest 2
What does i7TurboGT do?
19,371 (3.56/day)
Hopefully! Thanks for making it and working on it as long as you have already. Its STILL my go to pure temp app to this day... even with Haswell-E.
The only thing that doesn't appear to work right with Haswell-E (maybe haswell?) is the load % being pegged near 100% all the time.
unclewebb
7,940 (1.32/day)
i7 Turbo GT is a unique tool that gives you a look at what each thread of your CPU is doing. I wrote it for testing purposes and just tossed it in the download in case someone needed to do some testing or found it interesting.
Development of i7 Turbo GT ended but the code morphed into a new project called ThrottleStop which is popular in the laptop community. ThrottleStop is still being developed and has 101 more features compared to i7 Turbo GT.
ThrottleStop 8.00 beta 7
https://www.sendspace.com/file/i84h7g
It includes CPU voltage control on the 4th, 5th and 6th Gen Core i CPUs so in the wrong hands, it might be considered dangerous. If you crank up the nanny settings in Avast it might complain and I heard recently that Windows Defender thinks this download is suspicious. I have been running this version since I released it and my computer is still running just fine. No complaints from users.
Some users might wonder, why do we need to know if a CPU is throttling. All Intel CPUs use Turbo Boost so they can run at their maximum speed. On a desktop motherboard, there are usually options in the bios so you can crank up the Turbo power limits and run your CPU at full speed without any problems. Laptops and tablets have much lower power ratings and usually no control of these limits in the bios. Throttling is inevitable. Being able to accurately monitor and adjust these CPUs is just as important today as it was during the original Gulftown era.
Here is an example of my 4700MQ throttling.
When 4 cores are active, the 4700MQ should be using the full 34..00 multiplier when it is overclocked. In the picture above, the core power limit is set too low so all 8 threads are reporting that the multiplier is averaging about 30.86. When CPUs throttle, the multiplier is rapidly changing hundreds of times per second to keep the CPU just under the turbo power limits. Using high performance timers within the CPU provides an accurate look at what a CPU is really doing. Far more precise compared to any other tools. ThrottleStop also shows that TDP Throttle is the cause of this throttling and the more precise tool Limit Reasons by Dufus shows exactly what the problem is.
i7 Turbo GT was useful in its day but it has been replaced by ThrottleStop.
ThrottleStop has many similar features to Intel XTU plus a few very useful features that no other software gives you access to. Highly recommended for anyone that wants more control or wants to know more about what their CPU is really doing.
Wade Hayworth
2 (0.00/day)
hey UncleWebb, I am testing some processors and I started getting this error.
Is there a way to test this processor with Realtemp? I was using 3.70 then I tried your newer Realtemp T|I.
Thanks for any help you may provide
Solaris17
Super Dainty Moderator
26,925 (3.83/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
7,256 (1.03/day)
Video Card(s) Asus GeForce RTX™ 4070 Dual OC (Waiting on RX 8800 XT) | Intel® Iris® Xe Graphics
. View attachment 72648
AMD isn't good enough that's why u get this error message :roll:
Wade Hayworth
2 (0.00/day)
I have had it work on other AMD processors. this is why I asked the question. Thank you for the information though.
unclewebb
7,940 (1.32/day)
RealTemp has never supported any AMD CPUs. Core Temp recently released an update so it might work on your AMD CPU.
