Which Fan Configuration is more Sensible?
979 (0.53/day)
Turkey
System Name MSI-MEG
Processor AMD Ryzen 9 3900X
Motherboard MSI MEG X570S ACE MAX
Cooling AMD Wraith Prism + Thermal Grizzly
Memory 32 GB
Video Card(s) MSI Suprim X RTX 3080
Storage 500 GB MSI Spatium nvme + 500 GB WD nvme + 2 TB Seagate HDD + 2 TB Seagate HDD
Display(s) 27" LG 144HZ 2K ULTRAGEAR
Case MSI MPG Velox Airflow 100P
Audio Device(s) Altec Lansing
Power Supply Seasonic 750W 80+ Gold
Mouse HP OMEN REACTOR
Keyboard Corsair K68
Software Windows10 LTSC 64 bit
I'm thinking about modifying the front fan intake config. Which type of alignment is more feasible in your opinion. the one with smaller but large numbers, or bigger fans with smaller number? Noise is not my concern. Sample pictures are attached:
7,654 (3.26/day)
California
System Name His & Hers
Storage lots of SSD.
Lmao that's an interesting configuration. How's the noise on those small fans
Edit... oh those aren't your pc.
18,584 (2.66/day)
System Name AlderLake
Depends on the fans you are using.
If you want massive airflow look at server fans, Delta or alike, but they are very noisy.....
11,880 (2.18/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
Go with 2 x 140, best fan you can afford.
979 (0.53/day)
Turkey
System Name MSI-MEG
Memory 32 GB
I wish I could help you but I only have only one 40mm Noctua fan and it is running very quiet even at 5000 rpm. The sound is barely noticeable.
7,654 (3.26/day)
California
I think two larger fans are probably the better configuration.
979 (0.53/day)
Turkey
System Name MSI-MEG
Memory 32 GB
Also there is a brand called "ebm papst" which have been claimed to be the number one. Although I've never seen them in the pc market yet.
18,584 (2.66/day)
"More sensible" I'd go for the larger fans though.
AsRock
TPU addict
19,175 (2.98/day)
UK\USA
Cooling D15
Well all fans make noise, delta are like 2600 RPM or so yeah they can be very noisy but the silent fans typically don't go that high.
Personally like Pana\Delta or even the SilverStone FHP141 fans just run them at a lower RPM if their too much, and on top of that they are commonly 140x38mm too and not 25mm.
All so depends on your cooling needs too like if it's hot like now here i know i have that extra cooling power when needed.
I'd go 140mm when ever possible.
18,584 (2.66/day)
979 (0.53/day)
Turkey
System Name MSI-MEG
Memory 32 GB
7,654 (3.26/day)
California
There are lots of debate about noctua versus be quiet! and I have to ask to you as well.. Which one would you choose if they are both the same price?
In the 140mm size I'd go with the bequiet.... In the 120mm size it's a toss up between them and the NF-A12x25 but I would still lean silent wing pro 4.
I personally use the T30s from phanteks they are awesome but 30mm thick.
18,584 (2.66/day)
Well I replaced my 3 Noctuas with 3 Be Quiet ones, but only because I had compatibility issues, they would stop spinning after starting up my system.
I needed fans without 0rpm option. If my motherboard was good with the noctuas I wouldn't replace them. However black is nicer then brown imo..
These are 120mm fans I was talking about.
3,398 (1.68/day)
Power Supply Corsair RM750x
Mouse Logitech M575
One option not mentioned is a box fan with a very large reducer.
11,880 (2.18/day)
Manchester uk
VR HMD Oculus rift
I've used them they're usually mental and not to be used at home, for servers ,lab equipment etc.
Some of them will claim ignorant fingers they're that mental.
979 (0.53/day)
Turkey
System Name MSI-MEG
Memory 32 GB
Too noisy or pricey?
At the industrial sector, it looks like they have no competitor, including Delta.
11,880 (2.18/day)
Manchester uk
VR HMD Oculus rift
Noisy they're performance without compromise, literally in most cases ,avoid.
979 (0.53/day)
Turkey
System Name MSI-MEG
Memory 32 GB
freeagent
9,704 (4.15/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
I have seen Papst fans on all kinds of CNC machines. Metal or plastic.. they are pretty rowdy..
I like my T30s.
Ruru
S.T.A.R.S.
13,335 (3.00/day)
Jyväskylä, Finland
VR HMD Oculus Rift CV1
I have two Corsair AirGuide 120mm (bundled with case) as intake, one ML120 Pro as exhaust, two ML120 in radiator on the top of the case and 2x be quiet! Pure Wings on the GPU cooler. On desktop usage, I can only hear the pump as I run it at full speed. Temps are more than fine and the PC is quiet even in demanding games.
Though I'll probably get something else for intake as these aren't PWM controlled.
1,223 (0.65/day)
Loose in space
System Name "The black one in the dining room" / "The Latest One"
Processor Intel Xeon E5 2699 V4 22c/44t / i9 14900K @5.8GHz
Motherboard Asus X99 Deluxe / ASRock Z790 Taichi
Cooling Arctic Liquid Freezer II 240 w/4 Silverstone FM121 fans / Arctic LF II 280 w Silverstone FHP141's
Memory 64GB G.Skill Ripjaws V DDR4 2400 (8x8) / 96GB G.Skill Trident Z5 DDR5 6800
Video Card(s) EVGA RTX 1080 Ti FTW3 / Asus Tuff OC 4090 24GB
Storage Samsung 970 Evo Plus, 1TB Samsung 860, 4 Western Digital 2TB / 2TB Solidigm P44 Pro & more.
Display(s) 43" Samsung 8000 series 4K / 65" Hisense U8N 4K
Case Modded Corsair Carbide 500R / Modded Corsair Graphite 780 T
Audio Device(s) Asus Xonar Essence STX/ Asus Xonar Essence STX II
Mouse Logitech Performance MX, Microsoft Intellimouse Explorer 3.0
Keyboard Logitech K750 Solar, Logitech K800
Software Win 10 Enterprise LTSC 2021 IoT / Win 11 Enterprise IoT LTSC 24H2
Benchmark Scores https://www.passmark.com/baselines/V11/display.php?id=202122048229
SilverStone has a new version of of FHP141 V2 out. The labels on it are black and it draws slightly more power in Performance mode. I got one delivered Saturday in the botched Amazon fiasco (ordered two FHP141 V2's, one was the new one with the black labeling and the other that arrived was obviously used and all of the usual included hardware was missing) and the replacement for the used one showed up this afternoon. I was very happy to see it's another new one with the black labeling and everything was in the unopened box. I haven't tried either of them out yet.
AsRock
TPU addict
19,175 (2.98/day)
UK\USA
Cooling D15
With using Fan Control i do not need to use the switch on them, mine are V2 as well and use them on the bottom of the case.
i thought i got mine on a good deal $22 each fan for a 140mm x 38mm which replaced 2 of the 3 140mm fans under the video card, they push plenty of air a lot more than my Fractal Design ones which do pretty well but with the ambient getting up in the 32c+.
Not needed them to go any higher than 1300RPM and don't find that bad how ever over that and you really start to hear them but dam they push a lot of air.
8,720 (3.99/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
What case is that, and how restrictive is the ventilation with the panels in place?
Hard to recommend a fan when we don't know what the air path is - restrictive grilles work better with smaller, higher RPM fans of a static-pressure design. Free-flowing cases are usually better served by larger, airflow-focused fans at a lower RPM.
350 (0.14/day)
U.S.A.
System Name Dell T3500
Processor Xeon X5687
Motherboard Dell - 9KPNV
Cooling Dell U016F
Memory 12gb ECC 1333
Video Card(s) MSI rx480 gaming X
Storage 1tb WD blue
Case Dell T3500
Two larger fans woild be my choice. Highly suggest you do some real world testing. I place tiny thermometers at key places inside the case. Well as the thermal probe on my DMM. Hardware makers are good at perpetuating mindset that more is always better. For obvious reasons.
979 (0.53/day)
Turkey
System Name MSI-MEG
Memory 32 GB
Thank you I'll go for the bigger fans with less numbers
