Which HDMI cable for 4k@120hz gaming?
49 (0.11/day)
Hi guys, I need to connect the PC to the TV with HDMI at a distance of about 8 meters. My use is mainly gaming in 4k@120hz. In another thread they told me I need an active optical cable, I honestly don't know what it is.
What do you think? Thank you.
158 (0.08/day)
for that resolution the max length i can recommend for "normal" HDMI are 3m.
for 8m search for active HDMI cable
16,752 (2.33/day)
Optical no, but you do need an active cable. Then again, optical cables aren't really that expensive these days.
The difference is that there's a chip in each end of the cable that helps boost the signal over a longer distance.
Note that active cables are directional.
Also make sure it's a 48 Gbps capable cable.
Standard lengths appear to be 7.5 and 10 meters.
49 (0.11/day)
Perfect.
Just to be careful (I don't want to say nonsense) but are there active cables for 8k@120hz?
476 (0.69/day)
System Name Firestarter
Processor 7950X
Motherboard X670E Steel Legend
Cooling LF 2 420
Memory 4x16 G.Skill X5 6000@CL36
Video Card(s) RTX Gigabutt 4090 Gaming OC
Storage SSDS: OS: 2TB P41 Plat, 4TB SN850X, 1TB SN770. Raid 5 HDDS: 4x4TB WD Red Nas 2.0 HDDs, 1TB ext HDD.
Display(s) 42C3PUA, some dinky TN 10.1 inch display.
Case Fractal Torrent
Audio Device(s) PC38X
Power Supply GF3 TT Premium 850W
Mouse Razer Basilisk V3 Pro
Keyboard Steel Series Apex Pro
VR HMD Pimax Crystal with Index controllers
Is 8k@120hz the best on the market?
It should be fine. I would get a decent HDMI 2.1@48Gbps cable which should suit your needs.
16,752 (2.33/day)
HDMI 2.1b is the most recent spec and it doesn't go beyond 8K 60 Hz, but with DSC enabled it can do 8K 120 Hz.
1,210 (0.69/day)
Canada
System Name New compy
Processor AMD Ryzen 5800x3D
Case Thermaltake Core v71
MAKE SURE it has Ultra Certified logo, like this. If it doesn't have that logo it isn't a 48gbps cable.
16,752 (2.33/day)
Thanks but...forgive me, why do you tell me 2.1a and then link 2.1b?
Blah, brain fart. Fixed. There's no significant difference in your use case anyhow.
The HDMI Forum has published Version 2.1b of the HDMI® Specification which is available to HDMI 2.x Adopters. This includes a general clean up, clarifications to improve interoperability, and incorporation of errata.
That's not entirely true though, as it's possible to comply without the logo, just like you can make a compliant USB cable without going through the logo certification process.
That said, it is a peace of mind thing, as you know the cable should've been tested to comply with the spec. However, some companies use fake stickers so...
5,826 (1.48/day)
In the abyss, where all I can see is...nuthin !
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
Benchmark Scores PDQ
^^THIS^^
Also make sure it's made by a reputable mfgr (Anker, uGreen, CableMatters, Monoprice) and sold by a reputable vendor (B&H, daZon), not some no-name shop from some place nobody's ever heard of :D
49 (0.11/day)
If I understand correctly, there are simple active cables and active OPTICAL cables, right? But I don't think there is a significant price difference, in fact, the 10 meter cables I see are all optical. At this point which one should I choose? I would go for the optical one.
Si noti che i cavi attivi sono direzionali.
Can you explain to me what that means exactly, please.
PS: In the quick response field, the boxes for inserting emoticons and other functions are obscured, why? They worked the other day. Meh!
16,752 (2.33/day)
Doesn't matter, functionally there's no difference, so go with what fits your budget.
The cables only function in one direction, unlike passive cables which you can use either way around.
The connectors are marked with input and output.
49 (0.11/day)
Last questions. Can I be sure that any quality HDMI 2.1 48Gbps can be passed into the wall system?
Does it also supports the latest versions of available technologies? I'm talking about digital audio formats, HDR10+, VRR, ALLM and anything else you can think of.
8,319 (3.19/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
To solve any doubts just get a Cable that is rated at 8K 60Hz.
21,008 (3.40/day)
System Name Pioneer
Processor Ryzen R9 7950X
Case Thermaltake Core X31
Ok, the important thing is that I can place it on the wall.
Most cables will do fine in a wall but I believe there are special "wall-rated" cables if you want to be extra certain.
ir_cow
4,046 (0.70/day)
USA
If your going over 10ft for 4K@120. It pretty much needs to be optical. That or paying $70 for a proper shielded beefy cable.
5,367 (4.12/day)
São Paulo, Brazil
System Name Cocogoat
Motherboard ASUS ROG MAXIMUS Z790 APEX ENCORE
Cooling Noctua NH-D15S w/ Honeywell PTM7950 TIM and additional NF-F12 industrialPPC-3000 fan
Memory 32 GB G.SKILL Trident Z5 RGB F5-6800J3445G16GX2-TZ5RK @ 7600 MT/s 36-44-44-52-96 1.425V
Display(s) 55-inch LG G3 OLED
Keyboard Galax Stealth STL-03
You'll want an HDMI Ultra speed certified cable, they have that sticker on the packaging like @oobymach mentioned. I use this Club3D cable with my LG G3 OLED and RTX 4080, works great:
It's $30 on Amazon usually but I think it's on sale for $19 right now. It's VESA certified, high quality, no BS marketing "features" and shouldn't give you any trouble. For longer cables you'll probably want to go with a more exotic solution, though, such as an optical cable. Be prepared to drop a stack on that, though...
ir_cow
4,046 (0.70/day)
USA
Ohh I didn't see 8 meters. I read that as 8ft. So 26 ft for us dumb americans. Optical is the only option. No copper HDMI cable do that much distance.
I would buy whatever brand in that video :) The HDTVTest guy knows a lot about TVs.
49 (0.11/day)
Hi guys, after a long search I found these 3 products. In your opinion which is the best? Thank you.
5,367 (4.12/day)
São Paulo, Brazil
Both KabelDirekt and Cable Matters are known to sell very high quality, certified cables and I never heard any complaints from either of these brands. Either way you go will be great, so pick the one that is more convenient to you. If I had both in front of me I think I'd pick the KabelDirekt one though, just because it looks cooler to me :toast:
49 (0.11/day)
Thanks, yes I was thinking about KabelDirekt too. I also added another link that was previously wrong. The Maxonar is also "in wall" certified and that would be my use case. Is this certification important?
