Which is the proper way to apply thermal paste for a Quad core?
5,393 (0.93/day)
Carrollton, GA
System Name ODIN
Processor AMD Ryzen 7 5800X
Motherboard Gigabyte B550 Aorus Elite AX V2
Cooling Dark Rock 4
Memory G Skill RipjawsV F4 3600 Mhz C16
Video Card(s) MSI GeForce RTX 3080 Ventus 3X OC LHR
Storage Crucial 2 TB M.2 SSD :: WD Blue M.2 1TB SSD :: 1 TB WD Black VelociRaptor
Case Fractal Meshify C
Audio Device(s) Onboard Audio
Mouse Corsair M65
Keyboard Corsair K70 RGB Lux
I use evenly across the entire surface for all applications.
970 (0.17/day)
Granby, Qc. Canada
System Name Loose nuts & bolts
Processor FX-8350 - EK Supreme HF full nickel
Motherboard ASUS Sabertooth 990FX R2.0
Cooling Water EK goodness all around 2xBlack Ice X-280
Memory 2 x8G HyperX Fury 1600 @ 9-9-9-24-1T
Video Card(s) 2 x XFX RX 480 w/EK-FC RX 480 nickel+Acetal
Storage Samsung 850 Evo + 2xWD Black 500GB in RAID0
Display(s) Crossover 27" 2560x1440 110Hz OC
Case Cooler Master HAF XB EVO
Audio Device(s) on board
Power Supply Corsair HX850
Software Win 10 Enterprise x64
Both methods are good but personally I always use the spread thin and evenly method
Wrigleyvillain
PTFO or GTFO
7,702 (1.20/day)
Chicago
System Name DarkStar
Processor i5 3570K 4.4Ghz
Motherboard Asrock Z77 Extreme 3
Cooling Apogee HD White/XSPC Razer blocks
Memory 8GB Samsung Green 1600
Video Card(s) 2 x GTX 670 4GB
Storage 2 x 120GB Samsung 830
Display(s) 27" QNIX
Case Enthoo Pro
Power Supply Seasonic Platinum 760
Mouse Steelseries Sensei
Keyboard Ducky Pro MX Black
Software Windows 8.1 x64
Well some people just do a thin layer across the whole surface (not me though; what a pain) but I remember at least one prominent manufacturer had directions showing to use a thin line of paste but from right to left as opposed to from up to down depending on whether or not you had a dual or quad (based on the physical placement of the cores inside the chip). I'll see if I can find it.
But honestly the difference you will see if any will probably be nominal. Though certainly can't hurt to try and do it the best way possible, of course. Ideally you should trial and error test but that's a major PITA.
Edit: First 2 Links
4,267 (0.66/day)
Sanford, FL, USA
Processor Intel i5-6600
Motherboard ASRock H170M-ITX
Cooling Cooler Master Geminii S524
Memory G.Skill DDR4-2133 16GB (8GB x 2)
Video Card(s) Gigabyte R9-380X 4GB
Storage Samsung 950 EVO 250GB (mSATA)
Display(s) LG 29UM69G-B 2560x1080 IPS
Case Lian Li PC-Q25
Power Supply Seasonic SS-460FL2
Mouse Logitech G700s
Keyboard Logitech G110
I do thin spread with AS5, but "line" style with MX-2.
newtekie1
Semi-Retired Folder
28,473 (4.02/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Put a small spot in the middle and put the heatsink on. If you are putting enough thermal paste on to allow you to spread a thin layer on the entire IHS, you are using way too much TIM and are likely hurting performance.
5,393 (0.93/day)
Carrollton, GA
System Name ODIN
Cooling Dark Rock 4
Mouse Corsair M65
Well some people just do a thin layer across the whole surface (not me though; what a pain) but I remember at least one prominent manufacturer had directions saying use a thin line but from right to left as opposed to from up to down depending on whether or not you had a dual or quad based on the physical placement of the cores inside the chip. I'll see if I can find it.
See that is silly to me because it implies only the cores need to be cooled off. There is a lot of components in a chip and they all need to be cooled even if they are the primary source of the heat. Second, thermal paste is there to fill in any small imperfection that you can't see with the naked eye on the surface of the chip and cooler plate. Thus the ultimate goal is to get a even, thin layer covering the entire surface of the chip.
the least messy is the sandwich bag trick. You put a small amount in the center of the chip, cover it with a sandwich bag, and spread it evenly using either your finger or a razor blade. Trust me, the crap is hard to get off your fingers.
newtekie1
Semi-Retired Folder
28,473 (4.02/day)
Indiana, USA
The pressure from the heatsink spreads out the TIM. And the only parts of the CPU that touch the IHS, and hence the only parts of the CPU that recieve any cooling from the heatsink are the cores. None of the other components touch the IHS, so they aren't coolers, no matter how you apply the TIM.
Wrigleyvillain
PTFO or GTFO
7,702 (1.20/day)
Chicago
Display(s) 27" QNIX
Case Enthoo Pro
This is what I end up doing these days. Its easy to use too much still as well even just trying to do a "dot". The cores on a quad are essentially right there in the general center anyway. LaughingMan makes a great point too though, especially as those instructions are for Core 2.
Again, trial and error testing would be best. In other words, try every method and see which if any gives lowest load temps.
I see SPY!
334 (0.06/day)
Porto, Portugal
System Name ಠ_ಠ SERIOUS BOX ಠ_ಠ
Processor C2D e7200 @ 3.2Ghz
Motherboard Asus P5Q-Pro
Cooling Intel stock cooling
Memory 2x2Gb Exceleram(1066mhz, 1.8V)
Video Card(s) Sapphire 4850 512mb
Storage SATA2 WD Caviar Blue 500gb
Display(s) Asus VW222U (22")
Case generic case
Audio Device(s) on-board
Power Supply Corsair TX-650W
Software Windows 7 64
That's exactly how I do ;)
Also, I remember reading this article a while ago after having the same doubt:
linky
Another one from www.overclockers.com:
727 (0.12/day)
O'fallon Mo.
Processor Intel I7 4820k EK Supremacy Nickel Waterblock
Motherboard Asus Rasmpage IV Extreme
Cooling Alphacool UT60 560 Radiator
Memory Kingston Hyper X 16gb 2400
Video Card(s) MSI GTX 580 Heatkiller Waterblock - EK Backplate
Storage SanDisk Ultra Plus 256GB
Display(s) LG 24" Flatron
Case Silerstone TJ11
Audio Device(s) Sound Blaster Recon 3Di
Power Supply XFX Pro 1000 Platimum
Software Windows 7 Ultimate 64
if you do the pea size dot in the middle it spreads as you put on heatsink pushing air out and therfore removing air bubles
4,686 (0.75/day)
System Name Obelisc
Processor i7 3770k @ 4.8 GHz
Motherboard Asus P8Z77-V
Cooling H110
Video Card(s) GTX 780 Ti
Case T81
Software Win10 64bit
The dot will work well if you wriggle and press, but on occasion it can end up lopsided so I switched to the X method. Remember with HDT heatsinks it's totally different. You apply to the heatsink along the center dividers between the heatpipes for roughly half the length of the divider.
1,539 (0.27/day)
Canada/Québec/Montreal
System Name Main PC
Processor PII 925 x4 @3.724GHz (266x14) 1.525v NB 2660 1.425v
Motherboard Gigabyte AM3 GA-890XA-UD3 (790x+SB850)
Cooling Scythe Mugen 2 rev.B
Memory Hyperx 8GB (2x4) 1600@1418 8-7-7-20-27-1t
Video Card(s) GTX 680
Storage 256GB SSD / 2TB HDD
Display(s) LCD Samsung 24" 16:9
Case Cooler Master HAF 912
Audio Device(s) On-Board HD
Power Supply CM 750w GX |3.3v@25a|5v@25a|12v@60a
Software Kubuntu dual boot /Windows 7 Ultimate 64bit
Benchmark Scores later...
johnspack
Here For Good!
6,069 (0.95/day)
Nelson B.C. Canada
System Name System2 Blacknet , System1 Blacknet2
Processor System2 Threadripper 1920x, System1 2699 v3
Motherboard System2 Asrock Fatality x399 Professional Gaming, System1 Asus X99-A
Cooling System2 Noctua NH-U14 TR4-SP3 Dual 140mm fans, System1 AIO
Memory System2 64GBS DDR4 3000, System1 32gbs DDR4 2400
Video Card(s) System2 GTX 980Ti System1 GTX 970
Storage System2 4x SSDs + NVme= 2.250TB 2xStorage Drives=8TB System1 3x SSDs=2TB
Display(s) 1x27" 1440 display 1x 24" 1080 display
Case System2 Some Nzxt case with soundproofing...
Audio Device(s) Asus Xonar U7 MKII
Power Supply System2 EVGA 750 Watt, System1 XFX XTR 750 Watt
Mouse Logitech G900 Chaos Spectrum
Keyboard Ducky
Software Archlinux, Manjaro, Win11 Ent 24h2
Benchmark Scores It's linux baby!
First tin it with a small amount, then a horizontal line for a quad. Works very well.
5,393 (0.93/day)
Carrollton, GA
System Name ODIN
Cooling Dark Rock 4
Mouse Corsair M65
While true. The entire ihs is going to get really hot.
qubit
Overclocked quantum bit
17,865 (2.82/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
I spread the TIM evenly over the whole surface of the CPU heatspreader.
727 (0.12/day)
O'fallon Mo.
9,922 (1.80/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
yap small drop on the center of processor
but if you use direct touch hsf i usually put the paste on it on line pattern across the heatpipe
266 (0.05/day)
Processor i7 3930K 3.2 stock @ ~4.0
Motherboard Asus P9x79 DELUXE
Cooling Phanteks CPU cooler
Memory 6 x 4 Gb Kingston HyperX RAM triple channel 24GB total
Video Card(s) Gigabyte GeForce GTX 980 G1 4GB x2 SLI
Storage 1 ADATA 512Gb (primary OS) 2 X 64GB Agility 2 SSD in RAID0
Display(s) Benq XL2420T, 24" LED Gaming Monitor
Case Corsair Obsidian 800D
Audio Device(s) Onboard 5.1
Power Supply Cooler Master Silent Power 1000W
Software Win 8.1 Enterprise x64
Benchmark Scores They're good!!!
From a physics point of view it's all about surface area contact. If the heatsink surface covers the entire CPU plate then you should apply enough TIM to cover the entire plate. This way heat is being transferred and dissipated from CPU to heatsink over a greater surface area. To me a thin even layer on the CPU makes more sense than a pea dot or a line. Don't forget that our arms, hands and fingers aren't precision robotic machines so it's more likely that you won't rest the heatsink onto the CPU evenly thereby screwing up the proper spread of the paste.
I'd go thin even layer FTW
2,348 (0.43/day)
Processor Intel i7 970 // Intel i7 2600K
Motherboard Asus Rampage III Formula // Asus P8P67 Deluxe
Cooling Zalman CNPS9900MaxB // Zalman CNPS11X
Memory GSkill 2133 12GB // Corsair V 2400 32GB
Video Card(s) ASUS GTX1080 // MSI GTX1070
Storage Samsung 870EVO // Samsung 840P
Display(s) HP w2207h
Case CoolerMaster Stacker 830se // Lian Li PC-9F
Power Supply Seasonic X 850w Gold // EVGA 850w G2
Mouse Logitech G502SE HERO, G9
Keyboard Dell
Software W10 Pro 22H2
this will create air bubbles.
I don't understand. When you purchase a heatsink with thermal paste pre applied it is a thin layer, evenly applied (no bubbles).
They don't put a dot in the middle.
2,644 (0.45/day)
System Name MRCOMP!
Processor 5800X3D
Motherboard MSI Gaming Plus
Cooling Corsair 280 AIO
Memory 64GB 3600mhz
Video Card(s) GTX3060
Storage 1TB SSD
Display(s) Samsung Neo
Case No Case... just sitting on cardboard :D
Power Supply Antec 650w
herm...... who are you buying from that gives you a THIN layer of TIM? have you seen under the heat sink of Nvidia / AMD GPU's?
often they will use Thermal Pads not paste. the last 2 CPU's i bought, a 1055T and 1090T had a thick layer of TIM on the Heat Sink.
i have also never seen a higher end heat sink come with thermal paste pre applied.
168 (0.03/day)
Slovenia
System Name Sata Buster
Processor i5 6600K@4.6GHz 1.250Vcore
Motherboard MSI Z170A-M3
Memory Kingston HyperX Fury 2x4GB DDR4 2133MHz
Video Card(s) MSI GTX 980Ti OC TwinFrozr
Storage Intel 330 240GB SSD + WD 1TB RE4
Display(s) Asus P279q
Case Fractal R3
Audio Device(s) Int. Realtek - Yamaha RXV596 - Sennheiser HD280
Power Supply CoolerMaster V850
Software Win7 64bit
Small drop, then let to force do its job by putting heatsink on.
newtekie1
Semi-Retired Folder
28,473 (4.02/day)
Indiana, USA
Not it isn't, the small dot spreads out to cover almost the entire IHS, or actually does cover the entire IHS. If it doesn't then your mounting system isn't applying enough pressure. And the IHS isn't going to get any hotter than the CPU cores themselves, so as long as your cores are cool, the IHS isn't going to get super hot. If the cores are getting hot, then you've applied the thermal paste wrong or your cooling solution isn't good enough.
5,393 (0.93/day)
Carrollton, GA
System Name ODIN
Cooling Dark Rock 4
Mouse Corsair M65
Wow. What I said had nothing to do with any particular technique or cooling solution.
If you do not put any form of thermal control on the CPU, the nature of metal and heat transference dictates more than the spot where the cores touch will get hot. Heat does not move in strait ....nevermind.
Dude, follow the instructions provided with your TIM. If you didn't get any, follow the ones with the cooler.
I am using pre-made pads of cooling solution from now on.
3,668 (0.67/day)
Portugal
For me it depends on the situation. If it's directly on the die, a small dot (pea-like, whatever) of TIM in the center. If it still has the heat-spreader, I spread the TIM, covering all the surface with a thin layer, using a plastic card. I do that on the cooler too. My cooler is a HDT type and temps don't go over 40ºC (65W CPU, stock clocks, room temp ~18ºC), feels right.
