Which RAM is best for my motherboard?
Ohyti
9 (0.03/day)
Hello guys, I thought these RAM's could be good options that are compatible with my motherboard and offer "EXPO" support. Which one do you think I should prefer, or do you have any other recommendations? Thank you.
MOTHERBOARD:Gigabyte B650 M K REV:1.1
CPU:Ryzen 5 7600
KF560C36BBEAK2-32 Kingston 16x2 6000mhz CL36​
F5-6000J3238F16GX2-TZ5NR Gskill 16x2 6000mhz CL32​
CMK32GX5M2B6000Z30 Corsair 16x2 6000mhz CL30
9,340 (5.56/day)
Louisiana
Keyboard G710+x3
I'd go for the gskill personally even though the corsair has a little better cl.
Ohyti
9 (0.03/day)
Thanks, buddy, some of my friends mention Kingston, and it's really confusing me about the RAM situation
29 (0.09/day)
System Name Home workhorse-gaming
Processor Intel 13600KF @ 5400/4200
Motherboard Asus ROG Strix Z790A Gaming WiFi
Cooling Arctic Freezer 2 rev.7 360mm
Memory 2x16 Kingston Fury Renegade Silver RGB DDR6400@XMP settings - 32-39-39-80
Video Card(s) Palit GamePro 3080Ti with Alphacool Eiswolf 2 360 mm
Storage NVME, WD 550 Blue 1 TB (gen.3), Samsung 980 1 TB (gen.3), Kingston KC3000 2 TB (gen.4)
Display(s) Samsung Odyssey G5 LS27AG500NUXEN (IPS, flat), @120Hz, 10 bit color (165Hz@8 bit)
Case Corsair 5000D Airflow, 4xArctic Bionix P120
Audio Device(s) Creative Sound BlasterX AE5 Plus, Creative T580 boxes, Soundheiser HD569
Power Supply Seasonic Focus GX 850W Gold
Mouse Razer Basilisk V3 Chroma
Keyboard Asus TUF Gaming K3
VR HMD none
Software W11 pro
Benchmark Scores https://hwbot.org/xtu2/analyze/5404795?recalculate=true
All kind of filters there.
For Ryzen 7600 I'd go with 6000 with tightest timings that don't break your budget.
I'm a Kingston user for more than 15 years, didn't had any issues with them so far.
My 2c.
520 (0.14/day)
Midwest USA
System Name Core
Processor Intel 12700k @ 5.2/4.0
Motherboard ASRock z690 Steel Legend
Cooling Artic Cooling Freezer 420 AiO
Memory GSkill 64GB 3200 cas 14 b die
Video Card(s) ASRock Intel ARC a750
Storage Optane 900p x2, SK Hynix p41 Pro, p31 Pro
Display(s) ACER 250hz 1080p 25" IPS display/AOC 22" display
Case Phanteks p500a with all Arctic/Thermaltake fans
Audio Device(s) Focusrite interface, Presonus Studio Monitors and Subwoofer
Power Supply Seasonic 850w plat with cable mod cables
Keyboard Corsair mech k65
Software Win 11 Pro
Ive RMA'd 4 kits of Gskill in the last six months. (DDR4) Just sayin.
761 (1.55/day)
System Name Naboo (2019)
Processor AMD 3800x
Motherboard Gigabyte Aorus Master V1 (X470)
Cooling individual EKWB/Heatkiller loop
Memory 4*8 GB 3600 Corsair Vengeance
Video Card(s) Sapphire Pulse 5700XT
Storage SSD 1TB PCIe 4.0x4, 2 TB PCIe 3.0
Display(s) 2*WQHD
Case Lian Li O11 Rog
Audio Device(s) Hifiman, Topping DAC/KHV
Power Supply Seasonic 850W Gold
Mouse Logitech MX2, Logitech MX Ergo Trackball
Keyboard Cherry Stream Wireless, Logitech MX Keys
Software Linux Mint "Vera" Cinnamon
I would take a look at the RAM-QVl of the mainboard and select according to them. With that one can be sure that the RAM works with the given speed and timings on the board.
Ohyti
9 (0.03/day)
I made my choice based on that list, but I still had some doubts, and saying that eased my mind thx. I think I'll go with G.Skill.Gskill Even though the CL value is 2 higher, they have RGB lights :D
9,340 (5.56/day)
Louisiana
Keyboard G710+x3
Gskill make it easy to find their qvl list they've tested boards on that's why I love gskill to :cool:
RMA wise I've never had any issues I own 3 sets 4000c16/ 3600c16/ 3200c14 ddr4.
17,146 (2.36/day)
I'd suggest Team Group. They have quality stuff at decent prices.
Ohyti
9 (0.03/day)
"My friend,Gskill didn't check my motherboard version unfortunately.It says it's compatible on Gigabyte's own website. Will there be any issue?"
Deleted member 229121
If the G.Skill kit is listed on your motherboard's QVL you should be fine.
That Corsair one does have the tightest timings of the bunch though...
If it's on the QVL too it's certainly an option (no idea what the prices are for you).
Ohyti
9 (0.03/day)
The cheapest one is Corsair, then there's a +$10 difference with G.Skill,(My country price). Since Corsair doesn't have RGB, I thought I'd go for G.Skill. :D
3,185 (1.06/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Storage Too much
Case Thermaltake Core X9
Mouse G305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
The corsair kit is also running at 1.4V vs the G.Skill at 1.35V so I'm not sure if those sticks are actually better or if they are just pushing the voltage more.
Nothing wrong with kingston, just in this case among the kits you linked it's the slowest. CL36 was bottom of the barrel for DDR5 6000 kits even at Ryzen 7000 series launch.
Honestly if that's the pricing situation either is fine. I personally lean towards G.Skill just because I've never had an issue with them and they are great overclockers (for me at least, can't speak for others).
Ohyti
9 (0.03/day)
Thanks for your answers.I'm going to buy G.Skill in a little while.To be honest, I've been wanting the G.Skill from the beginning. :D
My friends.Apart from that changing profiles,are there any other BIOS settings I need to adjust after installing these MEMORY?
3,185 (1.06/day)
Storage Too much
Mouse G305
VR HMD Valve Index
Software Win 10
All you have to do is enabled the EXPO profile, everything else will be automatically set like timings and voltage. Your motherboard will also adjust other memory related settings (like FCLK, SOC Voltage, IOD voltage, ect) when you enable your EXPO profile as well.
ir_cow
4,235 (0.72/day)
USA
Close. The FLCK won't change and stays at 2000 Mhz unless you manually set it.
9,340 (5.56/day)
Louisiana
Keyboard G710+x3
Gigabyte site would be fine.
Dark team is a good suggestion I'm not sure what type of qvl they have or if gigabyte site shows it ?
Ohyti
9 (0.03/day)
Hi guys.AM5 BIOS: Low Latency Support, XMP/EXPO High Bandwidth Support? What's this?Does anyone know this
Thanks, buddy. I've sorted it out, installed it, and didn't encounter any issues.
9,340 (5.56/day)
Louisiana
Keyboard G710+x3
Just xmp profile options for a bit better performance.
Ever... touched base on it earlier maybe he can add more context.
ir_cow is very versed in memory :cool:
11,559 (5.55/day)
Midlands, UK
System Name Nebulon B
Cooling be quiet! Dark Rock 4
Storage 2 TB Corsair MP600 GS, 2 TB Corsair MP600 R2, 4 + 8 TB Seagate Barracuda 3.5"
Mouse Logitech MX Master 2S
Keyboard Logitech G413 SE
If they're at the same price, go with the one with lower latency. Otherwise, it doesn't matter, in my opinion.
3,185 (1.06/day)
Storage Too much
Mouse G305
VR HMD Valve Index
Software Win 10
I never said it would change the FCLK, I said it would set it. My X670e Taichi sets the FCLK to 2000 when I enabled EXPO while the default is auto. Regardless of whether auto ends up being the same 2000 or not, the BIOS is still setting that when EXPO is enabled which is precicely what I said it would do. Not all motherboards will adjust all the same values of course. It is not an uncommon practice to set values even if they are the same as auto in order to eliminate variables.
These are just more aggressive memory settings offered on Gigabyte AM5 motherboards. All the big motherboard vendors have their own variation under different names. Low latency support will lower memory subtimings while high bandwidth support will push up the memory speed.
Just note that those features are considered overclocking outside the parameters of your EXPO / XMP profile and therefore are not guaranteed to work. I'd recommend sticking with just EXPO enabled unless you want to dip your toes into overclocking memory.
ir_cow
4,235 (0.72/day)
USA
It's always "set" to 2000 regardless if EXPO/XMP is enabled unless you manually change it. ALL AM5 motherboard will have this at 2000. Some MBs don't even say auto anymore and instead says 2000 because that is default.
3,185 (1.06/day)
Storage Too much
Mouse G305
VR HMD Valve Index
Software Win 10
Yes my point was that some motherboards, like mine, will set FCLK to 2000 in addition to other things. I'm well aware the default is 2000, that doesn't change the fact that the motherboard is still changing it from auto to 2000 as displayed in the BIOS. At this point you are essentially gatekeeping what defines "setting", which is not productive and doesn't help the OP.
ir_cow
4,235 (0.72/day)
USA
No I'm trying not to confuse the OP as FLCK is not defined by the EXPO/XMP data. Neither is the SoC voltage for that matter. But it doesn't matter really. You explained it well enough
