Which RAM to choose for AMD 7950X3D and keep a 1:1 ratio
curtisdodo
8 (0.02/day)
Hello,
I bought my configuration :
Noctua NH-D15
RYZEN 9 7950X3D
X670E-F GAMING ASUS STRIX
RTX 4090
I'm looking for 64GB of the best performing RAM in low profile (for the NH-D15), in two sticks so 2x32.
Ideally non-RGB and EXPO certified.
But it is important to have a 1:1 ratio between the Memory Controller (UCLK) and the Memory Clock (MCLK).
In my country (France) very few dealers have 6000Mhz CL30.
I have seen these references:
KF560C36BBEK2-64 - 36-38-38
CMK64GX5M2B6000Z40 - 40 40 40 77
I read a comment that if you go from 2x16 to 6000 you have to go to 2x32 5600 to keep 1:1, is this true?
Please help me.
dgianstefani
TPU Proofreader
4,691 (1.96/day)
Swansea, Wales
System Name Silent
Processor Ryzen 7800X3D @ 5.15ghz BCLK OC, TG AM5 High Performance Heatspreader
Motherboard ASUS ROG Strix X670E-I, chipset fans removed
Cooling Optimus Block, HWLABS Copper 240/40 + 240/30, D5/Res, 4x Noctua A12x25, 2x A4x10, Mayhems Ultra Pure
Memory 32 GB Dominator Platinum 6150 MT 26-36-36-48, 56.6ns AIDA, 2050 FCLK, 160 ns tRFC, active cooled
Display(s) 32" 240 Hz 1440p Samsung G7, 31.5" 165 Hz 1440p LG NanoIPS Ultragear
Case Sliger SM570 CNC Aluminium 13-Litre, 3D printed feet, custom front panel pump/res combo
Audio Device(s) Audeze Maxwell Ultraviolet, Razer Nommo Pro
Power Supply SF750 Plat, full transparent custom cables, Sentinel Pro 1500 Online Double Conversion UPS w/Noctua
Mouse Razer Viper Pro V2 8 KHz Mercury White w/Tiger Ice Skates & Pulsar Supergrip tape
Keyboard Wooting 60HE+ module, TOFU Redux Burgundy w/brass weight, Prismcaps White, Jellykey, lubed/modded
Software Windows 10 IoT Enterprise LTSC 19044.4046
Benchmark Scores Legendary
You can't do 1:1.
Get 6000 EXPO, the rest doesn't matter.
2,789 (2.21/day)
Germany
System Name Sunk Cost Fallacy
Cooling Thermalright Phantom Spirit 120
Storage WD Black SN850X 1TB + 2x 2TB, 2x 4TB Crucial MX500, 4TB Samsung 870 Evo.
Display(s) Alienware AW2723DF, LG 27GR93U, LG 27GN950-B
Case Streacom BC1 V2
VR HMD Oculus Rift S
6000 is the new 3600.
a small handful of chips can do 6200 on a decent board.
if you want 64GB you often can get away with looser timings at 6000.
dgianstefani
TPU Proofreader
4,691 (1.96/day)
Swansea, Wales
System Name Silent
CL36 is slightly faster, but AMD latency is bad anyway due to chiplets so it won't really make a difference.
curtisdodo
8 (0.02/day)
In your opinion, is it better to have 2x16GB in 6000Mhz CL30 (30 38 38 96) or 2x32GB in 6000Mhz CL36 38 38?
18,405 (2.72/day)
Memory 32GB DDR5 Corsair Dominator Platinum RGB 6000MT/s CL36 / 8GB DDR4 HyperX CL13
Depends on the price I guess, or if you really need 64GB.
21,012 (3.40/day)
System Name Pioneer
Processor Ryzen R9 7950X
Case Thermaltake Core X31
You can't do 1:1.
I'm doing 1:1 with my kit, but at 5600. Can't say it's bothered me much.
Edit: Not x3d though.
7,662 (3.87/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
Asus board + X3D cpu + EXPO. This has all the makings of a great thread ^^
Heheh, yeah.
I'd be aiming for 5600 kits, myself. Getting 64GB stable at 6000 isn't impossible, but it will probably give you a headache trying RAM timings.
Just because something says EXPO and is AMD-certified doesn't mean your particular board/processor can handle it. Anything above DDR5-5200 is overclocking and down to the silicon lottery.
2x32GB @ 5600 has good odds of working with the EXPO presets. I don't have enough experience with AM5 yet, but 64GB of 6000 at stock timings seems unlikely.
curtisdodo
8 (0.02/day)
So for the record, I've been looking into the kit I want, which is : F5-6000J3040G32GX2-RS5K is DDR5 6000, CL 30 2X32Gb XMP.
Several things are bothering me.
Firstly I see that all the B650 or X670 from MSI they support this F5-6000J3040G32GX2-RS5K RAM with XMP profile so why not my ASUS?
Then I notice one thing. On the list of RAMs compatible with my motherboard I see that an exactly similar version (same chip, same voltage, same timing, same frequency) is compatible but RGB and it is labelled EXPO. So why wouldn't the RAM I chose be compatible?
On the screens, the first one the RAM I want, compatible with a motherboard taken at random in B650 MSI.
On the second screen, an identical model but EXPO certified.
tabascosauz
7,885 (2.38/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
Because different boards have different memory topologies that result in different memory performance and general capability when it comes to max achievable freq?
QVL doesn't mean everything - they only put on the list what they test. Maybe they just didn't have that exact kit on their hands. There's a smorgasbord of Hynix A/M kits at 6000 from various vendors; if your QVL already lists support for numerous other comparable Hynix kits, then I don't see what's stopping you from getting the CL30 Hynix kit.
Generally on AM5 neither your board nor Hynix kit is going to be the limiting factor to the max speed you can run auto:1:1 - your CPU will be, specifically, getting UCLK (mem controller freq) above 3000.
QVL also doesn't say anything about whether the kit is doable at 1:1 or 1:2. Technically, running it 1500MHz UCLK would still be "supporting" the 6000CL30 kit.............I'm not familiar whether if Raphael's memory controller suffers from dual rank to the point where a 2x32GB kit can't do 6000 1:1. Hence why AM4 boards all advertise support for the ultra high end Micron/Hynix 5100/5333 kits - no way you would run them as a daily, but they do "work" at half UMC speed.
curtisdodo
8 (0.02/day)
I have confirmation that with two 2x32 sticks you have to use gear2. so 2:1
I am hesitating between the F5-5600J2834F32GX2-RS5K or the F5-6000J3038F16GX2-FX5
So 2x16 6000CL30 or 2x32 5600CL28.
Both Hynix chips
What do you recommend?
tabascosauz
7,885 (2.38/day)
Western Canada
System Name ab┃ob
Both Hynix chips
Depends on how hungry you are for more RAM. If you need 64GB, no 32GB kit will do the job no matter how fast it is.
Sub-6000 on AM5 isn't a big deal if you are willing to put in the work.
ir_cow
4,047 (0.70/day)
USA
2x32GB DDR5-6000 @ FCLK 2000MHz : 1 : 1 works for me on all MBs so far. A lot default to 2:1 and some need to up the SoC voltage if you want 1:1 to work.
1,664 (0.34/day)
State College, PA, US
System Name My Surround PC
Processor AMD Ryzen 9 7950X3D
Motherboard ASUS STRIX X670E-F
Cooling Swiftech MCP35X / EK Quantum CPU / Alphacool GPU / XSPC 480mm w/ Corsair Fans
Memory 96GB (2 x 48 GB) G.Skill DDR5-6000 CL30
Video Card(s) MSI NVIDIA GeForce RTX 4090 Suprim X 24GB
Storage WD SN850 2TB, 2 x 512GB Samsung PM981a, 4 x 4TB HGST NAS HDD for Windows Storage Spaces
Display(s) 2 x Viotek GFI27QXA 27" 4K 120Hz + LG UH850 4K 60Hz + HMD
Case NZXT Source 530
Audio Device(s) Sony MDR-7506 / Logitech Z-5500 5.1
Power Supply Corsair RM1000x 1 kW
Mouse Patriot Viper V560
VR HMD HP Reverb G2
Software Windows 11 Pro x64
Benchmark Scores Mellanox ConnectX-3 10 Gb/s Fiber Network Card
Heheh, yeah.
I got my 64GB kit working on my 7950X3D at DDR5-6000 CL30, but I spent a lot of time getting this stable, and this is the tightest I can get despite having a DDR5-6400 memory kit. DDR5-6200 will not boot no matter how much voltage or how loose of timings I use. In contrast, DDR5-5600 was a piece of cake to get working and works fine at stock voltages. An EXPO kit for DDR5-6000 is probably the best solution, but I didn't buy one because the latencies of the EXPO kits were a lot higher than the Intel kits and I was willing to put in the extra effort.
curtisdodo
8 (0.02/day)
That's the problem, I don't want to fix the tensions myself, I just want to activate the ready-made profile and make it work.
In 64GB, there is hardly any kit in DDR5 with latencies below 36. Otherwise it's all XMP.
ir_cow
4,047 (0.70/day)
USA
I've been having a hard time getting dual-rank kits to boot below CAS36. Idk what that is about. Probably just a CPU IMC thing. Single-rank works down to CAS 28 (lowest I've tried).
1,664 (0.34/day)
VR HMD HP Reverb G2
It took a lot of fiddling with 2nd and 3rd level subtimings; I definitely had to do a lot of learning. There are other forums online that have sample configurations that work with these high speeds and low latencies.
curtisdodo
8 (0.02/day)
So I'm still not making any progress. If I want a ready to use kit without modifying anything myself that works in 1:1, should I start with the 2X32 5600CL28 in XMP?
Is lowering the frequency a bit from 6000 to 5600 but lowering the latency and going to 64GB I gain in performance?
32GB 6000CL30 < 64GB 5600C28?
1,664 (0.34/day)
VR HMD HP Reverb G2
The first thing you need to determine is whether your workloads need more than 32GB of memory. Your system will not be any faster with 64GB of memory if you never use more than 32GB.
ir_cow
4,047 (0.70/day)
USA
If you want 64GB, get 5600 for hassle free experience. Otherwise play the game of luck with 6000+
21,012 (3.40/day)
System Name Pioneer
This was my philosophy. Go with it. It will be pain free.
If you don't need 64GBs, likewise, the decision for 32GBs of faster ram should be easy.
805 (0.58/day)
System Name ASUS TUF F15
Processor Intel Core i5-10300H
Motherboard ASUS FX506LHB
Cooling Laptop built-in cooling lol
Memory 24GB @ 2933 Dual Channel
Video Card(s) Intel UHD & Nvidia GTX 1650 Mobile
Storage WD Black SN770 NVMe 1TB PCIe 4.0
Display(s) Laptop built-in 144 Hz FHD screen
Audio Device(s) LOGITECH 2.1-channel
Power Supply ASUS 180W PSU (from more powerful ASUS TUF DASH F15 lol)
Mouse Logitech G604
Keyboard SteelSeries Apex 7 TKL
Software Windows 11 Enterprise 21H2
even if you don't need 64 GB, there is also one factor: PRICE. If getting 64 GB "slower" memory is CHEAPER than 32 GB "ULTRA-FAST-OC-EXTREME-NITRO-RAM", then one should be dumb like me to overpay. I overpaid for 16 GB "faster" DDR4 vs "i had" 24 GB of "slouch", and for 32 GB for the price I could EZ have found "a little slower" 64 GB.
388 (0.13/day)
System Name 06/2023
Processor R7 7800X3D
Motherboard ROG STRIX B650E-I GAMING WIFI
Cooling Custom 240mm cooling (for CPU) with noctua nfa12x25 and Phantek T30
Memory 32gb Gskill 6000 CL30
Video Card(s) RTX 4070 dual asus deshrouded with 120mm NF-A12x25
Storage 2tb samsung 990 pro + 4tb samsung 870 evo
Display(s) Asus 27" Oled PG27AQDM + Asus 27" IPS PG279QM
Case Ncase M1 v6.1
Audio Device(s) Steelseries arctis pro wireless + Shure SM7b with Steinberg UR
Mouse Corsair scimitar pro (this mouse need an overall guys pls) + Logitech G Pro wireless with powerplay
Keyboard Sharkoon purewriter
Software windows 11
Benchmark Scores Over 9000 !
I have that combo and it works just fine.
