which rx 6700xt model is better
sadfil
2 (0.00/day)
I've spent a lot of time searching about these 2 models but can't find anything about temperatures or how loud it is. I have to choose one of these ASRock Radeon RX6700XT Challenger Pro OC 12GB or XFX Radeon RX 6700 XT SWFT 309 Gaming 12GB and don't know which.
1,886 (1.49/day)
Romania
System Name Gaming1 / Office 2
Processor Intel i7 7700k@4.8ghz / Ryzen 7 5700G
Motherboard MSI 270 SLI PLUS / MSI MAG X570S - TOMAHAWK MAX WIFI
Cooling ID-Cooling Frostflow X 120 - Liquid / ID-Cooling SE-903 V2
Memory 2x16GB Corsair Vengeance LPX 3600 Black / 2x16GB Corsair Vengeance RGB Pro SL - 3600Mhz
Video Card(s) XFX RX 6600XT 8GB / XFX RX 5700XT THICC III Ultra 8GB
Storage 1st : 1x SSD Samsung 980 Pro 1Tb + 4x SAS HDD in RAID / 2nd : 1 Tb SSD Nvme Samsung 980 Pro 1Tb
Display(s) 2x Dell 3008 WFP
Case CoolerMaster HAF 932 / GENESIS IRID 300
Audio Device(s) Soundblaster XFI / Onboard
Power Supply Seasonic Focus 850 W / Seasonic Focus 850 W
Mouse Logitech G502 HERO / Logitech G5
Keyboard Dell SmartCard Reader SK 3205 / Dell SmartCard Reader SK 3205
Software 1st - Win 10 Pro X64 / Win 7 X86 / Ubuntu / 2nd - Windows 11 Pro x64
I can't tell you which one would give better results, but i can tell you about my experience with XFX which helped me a lot.
I had 2 video cards that died and they were very pro with the warranty.
So from this point of view i can recommend XFX for the professional way they threat the customers.
On the other hand as an owner of many XFX cards i can assure that they are very good (for gaming or mining). (i own 5700XT, 6600 and 6600XT)
Since you choose a triple dissipation model i can assure it is a good choice for gaming (not to mention for mining)
2,847 (2.12/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
DO NOT buy the ASRock challenger series... they are absolute trash. i had the OC Edition and at 19°C Ambient it ran (even after a repaste with kryonaut) at almost 110°C.
Take the XFX.
Outback Bronze
Super Moderator
2,005 (0.42/day)
Walkabout Creek
System Name Raptor Baked
Processor 14900k w.c.
Motherboard Z790 Hero
Cooling w.c.
Memory 32GB Hynix
Video Card(s) Zotac 4080 w.c.
Storage 2TB Kingston kc3k
Display(s) Gigabyte 34" Curved
Case Corsair 460X
Power Supply PCIe5 850w
Mouse Asus
Keyboard Corsair
Software Win 11
ARF
4,670 (2.72/day)
Ex-usa | slava the trolls
Sapphire but if you can't buy a Sapphire, then the ASRock.
Here is a review of another model of ASRock:
ASRock Radeon RX 6700 XT Phantom Gaming D OC review - Graphics Card Thermal Imaging Measurements (FLIR) (guru3d.com)
ARF
4,670 (2.72/day)
that's a problem, this is another model with better cooling system i guess
Because it has two fans?
You can always watch a video or take advices from people who have it:
BlueprintPC
1 year ago
noise is good temps are pretty decent as well. I will eventually have a follow up video.
BlueprintPC
1 year ago
72-73c is perfecty fine for this and mosy modern GPU's. You should be good with that and no need to worry
Just a Regular Guy
1 year ago
whats the max temp in your build when under load mine is 72-73c is that ok or no I want it cooler of course but she gets toasty
18,585 (2.71/day)
System Name AlderLake
Yeah always take advice from who had it before... ;)
ARF
4,670 (2.72/day)
Yeah always take advice who had it before... ;)
Not only one person.
I can claim with the same success that xfx cards are trash. Don't buy them. Will you listen to?
18,585 (2.71/day)
Personally I buy what I think is best after reading several reviews.
263 (0.27/day)
That 110c figure is likely to be the hotspot which is supposedly technically fine though nearing the limit before it would start to throttle, could well be a one off problem if reviews don't show the same
Personally I think either would be a fine choice and have owned cards from both, my last was an XFX THICC II pro 5600 xt and it was great, the 6000 series do tend to run hotter but as long as you keep the hotspot Uber 110c, <100c would be better, and the core under 80c you should be fine
2,847 (2.12/day)
Germany
i have a bunch of RDNA2 Cards.
the ASRock is by far the absolute worst card i've ever had with no competition.
i won't stop you or anyone else buying one. i just warn people before i see another post in a couple days about "how to fix heavily thermal throttling 6700XT?"
my 6700XT from XFX runs 30 degrees cooler and is compared to the quite load asrock card barely audible.
This is the absolute BEST CASE after repasting with fresh kryonaut... before it was throttling by almost 300 MHz in an open case and stock powerlimit, clocks.
41,584 (6.59/day)
@Durvelle27 had a 5700 Challenger that I helped him unlock to XT and he either gave it away or Sold it because something important in his life came up. It ran fine.
1,886 (1.49/day)
Romania
I agree with my forum fellows.
Correct is "in my opinion" this card is the worst.
As i said earlier in my post i can speak only from my point of view after having the experience with all producers from AMD.
I will purchase only the next 3 producers in this order : Sapphire, XFX and AsRock.
But, also it is a matter of luck
41,584 (6.59/day)
AsRock Product Line is Challenger, Phanton Gaming, Taichi, OC Formula. I believe Taichi name was replaced by OC Formula currently.
Id take the AsRock cards over Asus, MSI and Gigabyte anyday.
1,886 (1.49/day)
Romania
At any time....most certain.
I had only trouble with those 3 producers that @eidairaman1 mentioned earlier.
41,584 (6.59/day)
Yup because their heads are so inflated that they cant get in the door
2,061 (1.07/day)
Hungary
Display(s) 29" 2560x1080 75 Hz / LG 29WK600-W
Mouse Canyon Puncher GM-20
Since I'm also in the market for a 6700 XT later the year if nothing else happens, I've narrowed it down to these models mainly:
https://www.techpowerup.com/review/sapphire-radeon-rx-6700-xt-nitro/
https://www.techpowerup.com/review/powercolor-rx-6700-xt-red-devil/
https://www.techpowerup.com/review/asrock-radeon-rx-6700-xt-phantom-gaming-d/
If you do get the Asrock then make sure its the Phantom gaming D with the RGB, that one had the best cooler on the 6600XT serie too.
While I can't say for sure w/o owning the cards but if those 2 are your only option then probably I would go for the XFX one.
355 (0.42/day)
System Name EA-ZEN
Processor AMD Ryzen 7 5800X3D with -50mW UV
Motherboard Asus X570
Cooling Big Air
Memory 2x16 GB DDR4 3600 CL16
Video Card(s) Asus RTX 2080 Ti Strix highly OC’ed
Storage 1 TB NVME, 500 GB SSD etc
Display(s) 2x 27”, main: curved 144Hz SVA with BLS and HDR
Case Full Tower
Audio Device(s) Z906 5.1 and Audeze Headphones, Shure SM7B mic
Power Supply Enough
Mouse Old but gold
Keyboard Mechanical Cherry Brown
Benchmark Scores A lot
From Asrock only the Challenger PRO and higher, Phantom and OC Formula are pretty good, Challenger Pro with 3 fans and bigger heatsink is fine. 6700 XT generally better with 3 fans cards.
