Which ssd is better ? 990 pro vs kc3000
egefitness
1 (0.00/day)
Both are the same price in my country and samsung's model with sa cooler.
Mayonnaise
13 (0.02/day)
From these two the 990 pro, but a comparison with the Fury Renegade is a bit of a closer comparison. I'd say you're probably good with whichever you choose, so get the one that's the best value for the prices available to you.
310 (0.57/day)
Processor AMD Ryzen 7900X
Motherboard MSI MPG X670E Carbon WiFi
Cooling Custom Loop (Watercool/HWLabs)
Memory G.Skill Trident Z5 DDR5-6000 64GB (F5-6000J3040G32GX2-TZ5K)
Video Card(s) Gainward RTX 4090 Phantom GS
Storage 7 x M.2, 4 x SSD, 2 x HDD.
Display(s) Alienware AW3423DW
Case Corsair 7000D Airflow
Audio Device(s) Logitech Z207, Shanling UA1 Plus
Power Supply Corsair HX1200
Mouse Logitech MX Master
Keyboard Logitech k360
Benchmark Scores None, but I think they'd be fairly decent.
Either one will do just fine, they're both among the best SSDs around. Functionally you won't notice any difference and the longevity of both should be more than good enough.
6,398 (1.55/day)
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
VR HMD Whahdatiz ???
Benchmark Scores PDQ
Or, if available, look at the WD 850x Black....extremely fast, reliable and usually less $$ than a Sammy....
says the guy that uses them exclusively for many years in both client builds & his 5 personal rigs :D
795 (0.11/day)
GA, USA
System Name Gamer
Cooling Apogee XL, MCR360, MCP655, Micro-rez
Video Card(s) Red Dragon RX 6800 XT
Case Rocketfish (Lian Li) e-ATX
Audio Device(s) Harman Kardon HK695 2.1
Power Supply Seasonic Focus GM-750
Mouse HP Gaming wired
Keyboard Logitech G110 wired
VR HMD HP WMR 1440^2
Software Win10 Pro 64bit
877 (1.20/day)
Belgium
System Name Prometheus
Processor AMD Ryzen 7 9800X3D
Motherboard ASUS ROG Crosshair X870E Extreme Gaming Wifi
Cooling AIO Cooler Master MasterLiquid 360
Memory 32GB DDR5 6000Mhz CL30
Video Card(s) Gigabyte GeForce RTX 3060 OC Edition 12GB
Storage Samsung 970PRO 2TB, Samsung 990PRO 4TB, WD SN850X 2TB, Samsung 980PRO 2TB. WD GOLD HDD 8TB
Display(s) Corsair XENEON 32UHD144 32" 4K UHD gaming monitor
Case Cooler Master HAF
Audio Device(s) Creative Sound Blaster AE7 + Logitech Z-5500 500W 5.1.
Power Supply Corsair AX850 Titanium.
Mouse Logitech MX Master 3
Keyboard Corsair K95 RGB Platinum Cherry MX
Software W10-11 Enterprise- Linux Mint 22.1 Cinnamon Edition.
Both of them are Powerfull SSD, but the Samsung one also uses less Power and have a bit greater TBW. But i think that Samsung is more reliable at the moment. This is mostly a bit of your personal thinking, just go for the one you feel good.
3,477 (1.11/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Case Thermaltake Core X9
Mouse PMM P-305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
At the same price I'd get the Samsung as it's very slightly faster but it'd be impossible to tell them apart in any real world scenario either way.
877 (1.20/day)
Belgium
No you would see no difference at all, just that the Samsung uses less power and a higher TBW is an no brainer IMHO.
And less Power also translates to less heat dissipated while working with it.
1,062 (0.17/day)
Hungary / Budapest
System Name Kincsem
Processor AMD Ryzen 9 9950X
Motherboard ASUS ProArt X870E-CREATOR WIFI
Cooling Be Quiet Dark Rock Pro 5
Memory Kingston Fury KF560C32RSK2-96 (2×48GB 6GHz)
Video Card(s) Sapphire AMD RX 7900 XT Pulse
Storage Samsung 990PRO 2TB + Samsung 980PRO 2TB + FURY Renegade 2TB+ Adata 2TB + WD Ultrastar HC550 16TB
Display(s) Acer QHD 27"@144Hz 1ms + UHD 27"@60Hz
Case Cooler Master CM 690 III
Power Supply Seasonic 1300W 80+ Gold Prime
Keyboard HyperX Alloy Elite RGB
Software Windows 10-64
Benchmark Scores https://valid.x86.fr/9qw7iq https://valid.x86.fr/4d8n02 X570 https://www.techpowerup.com/gpuz/g46uc
986 (1.40/day)
System Name BarnacleMan
Processor 14700KF
Motherboard Gigabyte B760 Aorus Elite Ax DDR5
Cooling ARCTIC Liquid Freezer II 240 + P12 Max Fans
Memory 32GB Kingston Fury Beast
Video Card(s) Asus Tuf 4090 24GB
Storage 4TB sn850x, 2TB sn850x, 2TB Netac Nv7000 + 2TB p5 plus, 4TB MX500 * 2 = 18TB. Plus dvd burner.
Display(s) Dell 23.5" 1440P IPS panel
Case Lian Li LANCOOL II MESH Performance Mid-Tower
Audio Device(s) Logitech Z623
Power Supply Gigabyte ud850gm pg5
Keyboard msi gk30
They are both top of line ssds. You probably wouldn't notice a difference but depending on the workload you can check out the TPU reviews, see where each excels.
If I had to pick I think I would go with Kingston because it looks like the sustained write is slightly better. Also I've had a Kingston before which lasted a long time, never had a Samsung. But splitting hairs here.
