Whirring/Grinding Case Fan
519 (0.13/day)
UK
System Name Daedalus
Processor AMD FX 6300
Motherboard ASUS M5A97 EVO R2.0
Cooling Coolermaster Hyper 212 EVO
Memory 8GB Kingston HyperX Genesis (2x4GB)
Video Card(s) MSI R9 270X Gaming 2GB
Storage 1TB Seagate Barracuda
Display(s) LG Flatron E2442 (main - 24in 1080p)
Case NZXT Phantom 410 (Gunmetal Edition)
Power Supply XFX Pro 650W
Mouse Steelseries Siberia [RAW]
Hello,
One of my fans (the stock 140mm) in my Phantom 410 has started to make whirring and/or grinding noise. It seems to be pretty intermittent, and I am yet to find a pattern. The only time I've heard that kind of noise before was on a pretty old 80mm fan, which was due to the bearings. I'd be surprised if it was related to this, as the case fan is less than a year old.
It doesn't bother me too much as its fairly irregular, but it doesn't sound that good - if there's a fix for it, that would be great. I know I could always replace the fan if need be.
Any ideas?
Layton
44,212 (6.80/day)
Clean it thoroughly. If it continues replace or try it on another power connector.
FreedomEclipse
~Technological Technocrat~
24,751 (3.76/day)
(currently) Hong Kong
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
Just replace it. you can get some cheap ass Yate Loon fans off ebay for a few quid. I have a 230mm fan thats been clicking since last year but I could never be arsed to replace it - It just keeps working
9,923 (1.80/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
just check does it spins right? maybe the oil dries or the metal just touching so it sounds like that
if it sounds bad just replace it since fans are easy to buy from local shop
OneMoar
There is Always Moar
8,832 (1.61/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
pull the fan out remove the sticker and or plug on the back of it and put some light grade oil in there
de.das.dude
Pro Indian Modder
9,244 (1.70/day)
Internet is borked, please help.
System Name Monke | Work Thinkpad | Old Monke
Case Ant Esports Tempered case | Thinkpad | NZXT Guardian 921RB
Audio Device(s) Logitech Z333 | Jabra corpo stuff | Some USB speakers
Mouse Logitech G400 | nipple | Dell
VR HMD ;_;
Hello,
Any ideas?
Layton
was a bit hard to find... someone should have stickied this.
http://www.techpowerup.com/forums/t...ow-to-succesfully-perform-fan-surgery.131473/
anyway sometimes dirt gets on and makes the fan unbalanced, making the bearing grind.
also sometimes obstruction in the airflow results in a reaction force on the fan bearings which make a grinding noise.
sneekypeet
not-so supermod
29,709 (4.28/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
If the chassis is less than a year old, that fan is covered in the warranty for the chassis. Get in touch with NZXT and get it replaced.
519 (0.13/day)
UK
So I have an update, but before that, thanks for all the suggestions :toast:
I contacted both the retailer and NZXT to see what they could do. The retailer decided to try and escape helping me, but I had much better luck with NZXT, who are shipping me a replacement fan as I speak. Excellent customer service.
1,407 (0.35/day)
Alabama, USA
Processor 5900x
Motherboard MSI MEG UNIFY
Cooling Arctic Liquid Freezer 2 360mm
Memory 4x8GB 3600c16 Ballistix
Video Card(s) EVGA 3080 FTW3 Ultra
Storage 1TB SX8200 Pro, 2TB SanDisk Ultra 3D, 6TB WD Red Pro
Display(s) Acer XV272U
Case Fractal Design Meshify 2
Keyboard Ducky One 2
NZXT is good with these things. My NZXT case fan might actually be on the go itself, but it's been 24/7 100% for almost 8 months now. Maybe they don't have the best fans but they're good at replacing them. :p
de.das.dude
Pro Indian Modder
9,244 (1.70/day)
VR HMD ;_;
indeed! i am a fan of them too! the guardian cabinet i bought had a faulty temp sensor and i asked the retailer for help and they contacted nzxt and they shipped me a new temp display section :D
retailer was nice too since i am known in my city's pc community lol.
