Why aren't there many cases without glass?
196 (0.43/day)
Motherboard ASUS Prime X670E-Pro WIFI
Cooling Noctua NH-D15S
Memory Kingston FURY Beast 2x16GB 6000MHz CL36
Video Card(s) Gainward RTX 2070 Super
Storage Samsung 990 Pro 2TB, Samsung 990 Pro 4TB, Samsung 970 EVO Plus 2TB, Lexar NM790 4TB
Case Fractal Design Meshify 2
Power Supply Corsair HX1000i ATX 3.1
There are only a handful and I have hard time finding something similar to NZXT H7 Flow (2024) but with side intake instead of front.
651 (1.14/day)
Processor Ryzen 5700x
Motherboard Gigabyte Auros Elite AX V2
Cooling Thermalright Peerless Assassin SE White
Memory TeamGroup T-Force Delta RGB 32GB 3600Mhz
Video Card(s) PowerColor Red Dragon Rx 6800
Storage Fanxiang S660 1TB, Fanxiang S500 Pro 1TB, BraveEagle 240GB SSD, 2TB Seagate HDD
Case Corsair 4000D White
Power Supply Corsair RM750x SHIFT
There are tons of cases without glass side panels, you will struggle to find one in 2024 with a side intake however as that was mainly a thing in the 00's/early 10's not so much now and the best method of airflow and getting rid of warm air from a PC case is front intake and rear exhaust, of course you can mod a side panel and put a fan/s on it as you wish
196 (0.43/day)
So why do dual chamber cases put the exhaust on the side instead of front? There are thousands of cases like the Lian Li O11, but not without glass.
I was of getting a Lian Li LANCOOL III, but you are pushing fresh air out on the bottom since it's fully open and the front too if I make it side intake. So how do I seal the front and how do I drill the glass?
At that point I just make my own case using Plywood ans mesh filters.
985 (0.69/day)
Processor E5-4627 v4
Motherboard VEINEDA X99
Memory 32 GB
Video Card(s) 2080 Ti
Storage NE-512
Display(s) G27Q
Case DAOTECH X9
Power Supply SF450
The bottom doesn't push air out unless you deliberately reverse the fans. You can make a custom carbon fiber side and front panel with holes to mount the fan where needed, but I really don't see why you want it that way. Better as a chimney and cover the rest with mesh filters, Why have side intakes..
Ruru
S.T.A.R.S.
12,797 (2.93/day)
Jyväskylä, Finland
System Name 4K-gaming / media-PC
Processor AMD Ryzen 7 5800X / Intel Core i7-6700K
Motherboard Asus ROG Crosshair VII Hero / Asus Z170-A
Cooling Arctic Freezer 50 / Thermaltake Contac 21
Video Card(s) RTX 3080 10GB / RX 6700 XT
Storage 3.3TB of SSDs / several small SSDs
Audio Device(s) Creative Omni BT speaker
VR HMD Oculus Rift CV1
Wait, what? Exhaust in the front? That's an intake, not exhaust :confused:
17,269 (4.67/day)
Processor 7800X3D -25 all core ($196)
Motherboard B650 Steel Legend ($179)
Cooling Frost Commander 140 ($42)
Memory 32gb ddr5 (2x16) cl 30 6000 ($80)
Video Card(s) Merc 310 7900 XT @3100 core $(705)
Display(s) Agon 27" QD-OLED Glossy 240hz 1440p ($399)
Case NZXT H710 (Red/Black) ($60)
yeah, to this day I regret getting rid of my corsair carbide 500r with custom made dust filters. :banghead:
Ruru
S.T.A.R.S.
12,797 (2.93/day)
Jyväskylä, Finland
I regret selling my Antec P280 White in 2015, that was probably the best case I've ever had. Also hella good sound insulation in that case, my then-PC (i7 920, 24GB, GTX 570) was practically inaudible.
3,606 (1.69/day)
UK, Midlands
System Name Main PC
Processor 13700k
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
For me side intake is a game changer, if its rare on modern cases, I assume designers have made an assumption is no front mounted storage, and that AIO is used for CPU cooling, because the problem with front intake is the air has to navigate around storage and then around CPU heatsink. It isnt good enough.
Dont need to use it on AMD system, as that system generates far less heat plus its just using a stock CPU cooler which barely blocks anything.
339 (0.19/day)
System Name myPC
Processor i5-11600k @ stock
Motherboard Asus TUF Z590 Gaming Plus
Memory Corsair Vengeance LPX 2x8GB DDR4 3200
Video Card(s) Asus Dual RTX 3060 ti
Storage Boot: WD Black SN770 1TB - Game Storage: WD Black SN770 2TB - Other Storage: 4TB
Display(s) Samsung Odyssey G5 curved 27" 1440p 144hz
Case Thermaltake v100 perforated
Audio Device(s) Some headphones and some speakers
Power Supply Gigabyte UD750GM
Mouse Logitech G203
Keyboard Redragon K509
Software W11 Pro
I didn't know my case was a unicorn these days.
2,651 (0.57/day)
East Europe
System Name PLAHI
Processor I5-10400
Cooling 120 AIO
Video Card(s) PNY QUADRO RTX A2000
Storage Intel 670P 512GB
Case Silverstone Raven 03 (RV03)
Mouse Logitech Triathlon
Keyboard REDRAGON MITRA
Software Windows 11 Home x 64
Always wanted to have one of those. Narrowly missed one at the second hand market. Looks like a very versatile case.
bug
13,779 (3.96/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
And that's because airflow was not a thing back then. All we needed was to push a bit more air over the CPU cooler. Used to be enough.
361 (3.01/day)
As far as I know, the fractal design north has a variant in white with mesh side panel.
32 (0.03/day)
System Name Nirn
Processor Amd Ryzen 7950X3D
Motherboard MSI MEG ACE X670e
Memory 128 GB Kingston DDR5 6000 (running at 4000)
Video Card(s) Radeon RX 7900XTX (24G) + Geforce 4070ti (12G) Physx
Storage SAMSUNG 990 EVO SSD 2TB Gen 5 x2 (OS)+SAMSUNG 980 SSD 1TB PCle 3.0x4 (Primocache) +2X 22TB WD Gold
Display(s) Samsung UN55NU8000 (Freesync)
Case Corsair Graphite Series 780T White
Audio Device(s) Creative Soundblaster AE-7 + Sennheiser GSP600
Power Supply Seasonic PRIME TX-1000 Titanium
Mouse Razer Mamba Elite Wired
Keyboard Razer BlackWidow Chroma v1
VR HMD Oculus Quest 2
that whole case looks good except for the faux wood front panel.
17,269 (4.67/day)
I think it looks amazing with the white/wood theme personally, I really like this case. A little too pricey for me though.
9,174 (3.35/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
Does that come with mounting for a side fan or would you have to Frankenstein a mount?
361 (3.01/day)
Please accept the quick and dirty screenshot of https://www.fractal-design.com/app/uploads/2022/12/North-Manual-V1.2.pdf
It seems that is only a part of the mesh version.
I do not think so.
I have a Fractal Design Meshify 2 Case.
I sold a new Jonsbo D41 Case with screen where all my hardware was put in for a month. The cheaper cases like the D41 do not have the build quality, the text build manual or the spare parts.
The Be Quiet Pure Base 500 Case is another case I personally build in which is far overpriced for the low asking price.
Fractal puts a lot of time and efforts in their cases.
If you want to save a few coins you can buy second class computer cases. The seller here calls it "B-Ware". My case was also "B-Ware". I did not saw any scratches or other imperfections on the case. Sometimes "B-Ware" is just returned goods from a buyer or a damaged packaging case. Not sure if the english call it "B-grade".
732 (0.15/day)
coventry UK
System Name Gwafwar
Processor Ryzen 5 3600
Motherboard Msi MPG X570 Gaming Plus
Cooling Montech D24
Memory 16Gb Adata Spectrix 3600 Cl18
Video Card(s) XFX 7900 GRE
Storage Adata 512Gb SX8200 pro
Display(s) 3x 27" 1080p Lg's
Case Montech King 95 pro
Power Supply Coolermaster 750W Masterwatt
Mouse Saitek X65-f HOTAS
Software Win10 Pro
I got a Montech King 95 pro for my last case and I can't fault it.
There is a hinged fan mount at the front of the case, and the front curved glass can be replaced with a mesh section that is also included.
In the standard configuration the bottom 3 fans are intake, the offside internal fans are intake, and you have a single exhaust at the rear with an open mesh top.
In the mesh configuration the bottom 3 are still intake, but you have to reverse the offside fans that are swung to the front of the case on the hinge to then become intakes, and you retain the single exhaust and the open top.
freeagent
8,560 (3.78/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
I actually don't mind glass that much. I dropped the glass for my Meshify C a couple of times and it was ok, so I thought I would try a Torrent. I lay it down on the glass all the time, though I used to take it off, but I got brave. As long as the surface is flat and clean you will be ok. And don't kick it if its on the floor :D I keep mine at the height of a TV stand so its a couple of feet off the floor.
9,174 (3.35/day)
Cooling In Win SR36
42,230 (6.64/day)
Popular thing is why.
196 (0.43/day)
It does if I dont put fans in there. In my current Meshify 2 the front fans push air out of through the PSU. How do I tell them not to do that? I tried asking nicely or yelling at then, but they wont listen. Please help me out here m8.
So if I get a 7000D AIRFLOW, put fans on the side(intake) and nothing in the front, you say it wont just push out the air through the front mesh? Who's telling the air not to do that?
So who's in the wrong. You guys who don't understand what side intake is or the manufacturers who list the intakes as side intake?
This is the case i'm looking for
  • Like
Reactions: N/A
39 (0.10/day)
planet Earth
Processor Ryzen 7 7800X 3D
Motherboard Gigabyte B650 Gaming X AX
Cooling Deepcool AK620
Memory Corsair Vengeance 32GB 6000 CL30
Video Card(s) MSI GeForce RTX 3080 SUPRIM X 12G LHR
Storage Samsung 980 NVMe 1TB, Kingston KC3000 NVMe 2TB
Display(s) Dell Alienware AW2724DM, Dell S2522HG
Case Phanteks Eclipse P600s black
Power Supply EVGA supernova G6 850W
Mouse Razer DeathAdder V2
Keyboard Razer Ornata v3
Software Win 11 pro
y2faulty
22 (0.55/day)
that's why im going to mod my 14years old Corsair Carbide 300r to bring it up to spec to the year 2025
remove the drive cage to ensure extra airflow from the front, substitute the optical drives bay with a grill, a dust filter and a fan, add a mobo tray side panel to help hide the cables and to hang a couple of HDD vertically, I don't have a side intake, I have 2 140mm ones and they fit perfectly even a bulky fan and a tall gpu.
14,105 (3.82/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Get the H7 flow and an extra mesh side panel to replace the glass, I don't mind the glass on mine, but use the fans on the base for intake so the "flow" is bottom to top.
Side intake is a fad that needs to die, it has no inherent advantages and is mainly for appearance.
