- Nov 23, 2020
- 169 (0.11/day)
System Name | PC-Casa |
Processor | i7-9700F |
Motherboard | Gigabyte Z390 Gaming X |
Cooling | Artic Liquid Freezer II 240 |
Memory | 2x16gb DDR4 3200 Kingston HyperX |
Video Card(s) | Gigabyte RTX 3070 Eagle OC 8Gb |
Storage | Samsung 970 EVO Plus NVMe M.2 500Gb + Samsung SSD 870 QVO 2TB + 2x WD 2Tb HDD SATA |
Display(s) | Samsung LU28R55 4K |
Case | Sharkoon TG5 Pro RGB |
Power Supply | Cooler Master 600W 80+ |
Mouse | Corsair M65 Pro RGB |
Keyboard | Corsair Strafe |
Software | W10 Pro - 64 |
Benchmark Scores | 3D Mark Performance: 30167 3D Mark Extreme : 15862 |
Hi, it seems it is what the CPU is able to send to the GPU, not its work.Why cpu limit fps?
you can see in this video CPU usage only 50% so why it isn't load more to get max fps in same CPU?
1700X use only 50% and get so low fps to compare 5600X
How it possible?
System Name | Veral |
Processor | 7800x3D |
Motherboard | x670e Asus Crosshair Hero |
Cooling | Thermalright Phantom Spirit 120 EVO |
Memory | 2x24 Klevv Cras V RGB |
Video Card(s) | Powercolor 7900XTX Red Devil |
Storage | Crucial P5 Plus 1TB, Samsung 980 1TB, Teamgroup MP34 4TB |
Display(s) | Acer Nitro XZ342CK Pbmiiphx, 2x AOC 2425W, AOC I1601FWUX |
Case | Fractal Design Meshify Lite 2 |
Audio Device(s) | Blue Yeti + SteelSeries Arctis 5 / Samsung HW-T550 |
Power Supply | Corsair HX850 |
Mouse | Corsair Harpoon |
Keyboard | Corsair K55 |
VR HMD | HP Reverb G2 |
Software | Windows 11 Professional |
Benchmark Scores | PEBCAK |
Game isn't coded to use all CPUs, and instructions per clock on the 1700x are much lower than the 5800x.Why cpu limit fps?
How it possible?
so how can I know if have limit from CPU ?Hi, it seems it is what the CPU is able to send to the GPU, not its work.
upGame isn't coded to use all CPUs, and instructions per clock on the 1700x are much lower than the 5800x.
System Name | IceStorm |
Processor | i7 10700 |
Motherboard | Asus ROG Strix B460-F |
Cooling | Aerocool P7-240 AIO Water Cooler |
Memory | 16GB Corsair Vengeance Pro |
Video Card(s) | Gigabyte Gaming OC RX 5700 XT |
Processor | Intel Core i9 11900KF @ -.080mV PL max @220w |
Motherboard | MSI MAG Z490 TOMAHAWK |
Cooling | DeepCool LS520SE Liquid + 3 Phanteks 140mm case fans |
Memory | 32GB (4 x 8GB SR) Patriot Viper Steel Bdie @ 3600Mhz CL14 1.45v Gear 1 |
Video Card(s) | Asus Dual RTX 4070 OC + 8% PL |
Storage | WD Blue SN550 1TB M.2 NVME//Crucial MX500 500GB SSD (OS) |
Display(s) | AOC Q2781PQ 27 inch Ultra Slim 2560 x 1440 IPS |
Case | Phanteks Enthoo Pro M Windowed - Gunmetal |
Audio Device(s) | Onboard Realtek ALC1200/SPDIF to Sony AVR @ 5.1 |
Power Supply | Seasonic CORE GM650w Gold Semi modular |
Software | Win 11 Home x64 |
If you can play the game and it's working as expected why worry? Lower resolution gaming (1080p and less) is more CPU bound so depending on the game the CPU may well be working harder than the GPU, once you get to 1440p it's the other way around, however resolution, the game (and it's detail settings) and graphics card play their part but you have not mentioned them, why does the CPU have to work harder if it is delivering the settings you have set such as refresh rate, visual quality and effects etc.so how can I know if have limit from CPU ?
I meant in percent like this cpu limit on 62% is max for 4 cores?
up
System Name | Computer |
Processor | Intel Core i9-9900kf |
Motherboard | MSI MPG Z390 Gaming Pro Carbon |
Cooling | MSI MPG Coreliquid K360 |
Memory | 32GB G.Skill Trident Z DDR4-3600 CL16-19-19-39 |
Video Card(s) | Asus GeForce RTX 4070 DUAL OC |
Storage | A Bunch of Sata SSD and some HD for storage |
Display(s) | Asus MG278q (main screen) |
Instead of CPU usage which depend on number of core in use as baris.saracli mentionned, you could start by checking your GPU usage. It should be closer to 100% if you are not CPU bound. It's obvious in the video.so how can I know if have limit from CPU ?
There are two important things about CPU and FPS. First, how many cores does a game utilize? Second, how strong is each core? In your case, if the game only uses 4 cores, your CPU usage will be about 50% in an 8-core CPU. So, if the cores are weak, your CPU won't produce enough fps.
Devil May Cry, for example, does not use more than 4 cores as far as I remember. As a result, a 4-core i3 processor can perform better than an 8-core FX because intel cores are stronger.
System Name | Tiny the White Yeti |
Processor | 7800X3D |
Motherboard | MSI MAG Mortar b650m wifi |
Cooling | CPU: Thermalright Peerless Assassin / Case: Phanteks T30-120 x3 |
Memory | 32GB Corsair Vengeance 30CL6000 |
Video Card(s) | ASRock RX7900XT Phantom Gaming |
Storage | Lexar NM790 4TB + Samsung 850 EVO 1TB + Samsung 980 1TB + Crucial BX100 250GB |
Display(s) | Gigabyte G34QWC (3440x1440) |
Case | Lian Li A3 mATX White |
Audio Device(s) | Harman Kardon AVR137 + 2.1 |
Power Supply | EVGA Supernova G2 750W |
Mouse | Steelseries Aerox 5 |
Keyboard | Lenovo Thinkpad Trackpoint II |
VR HMD | HD 420 - Green Edition ;) |
Software | W11 IoT Enterprise LTSC |
Benchmark Scores | Over 9000 |
But if I see games that have CPU like 10700K with 3080 get 100fps for example and GPU is 100% it mean no limit from CPU , and another option 3700X with same graphics card and same 100% but he get only 92fps how it possible look like CPU doesn't limit here because GPU on max usage.
And still have gap for fps
Thank for answer but I have another example- Monitoring of stats is 'an estimate over time' and tied to a polling rate, so you won't always see the exact same numbers. Small differences are 'margin of error' - ignore them.
- Different architectures work differently together. Intel CPU might be better optimized for the task so it can feed the GPU better. The GPU might still have maxed utilization, but that is ALSO an estimate.
The % you see in on-screen monitoring are 'global' numbers, but you really are performance capped if ONE subsystem of your rig is maxed out. For example, if you are transporting the maximum number of bytes over the VRAM/system memory to feed the GPU, you will have 100% utilization on something and the GPU will do all it can, but you can still lose some FPS. You have to consider that we're talking 'Frames PER SECOND' here. An 8 FPS difference over 100 total FPS is just 8% of one second difference. We're talking about milliseconds here, so percentages are a very inaccurate way to display that.
Things you CAN check:
RTSS /Afterburner can do per-core CPU monitoring, also in games:
What you will probably see is that 1 or 2 cores are always going to be at 99% usage - even today many games still use one or two fat game logic threads and lighter ones alongside it. The performance is capped by the heaviest thread. In that case, improving the single thread CPU clocks will directly benefit gaming performance. This is a given and even DX12 with better threading doesn't completely remove that fact.
System Name | The Cum Blaster |
Processor | R9 5900x |
Motherboard | Gigabyte X470 Aorus Gaming 7 Wifi |
Cooling | Alphacool Eisbaer LT360 |
Memory | 4x8GB Crucial Ballistix @ 3800C16 |
Video Card(s) | 7900 XTX Nitro+ |
Storage | Lots |
Display(s) | 4k60hz, 4k144hz |
Case | Obsidian 750D Airflow Edition |
Power Supply | EVGA SuperNOVA G3 750W |
if your GPU is not maxed out, and your framerate is not capped - you most likely have a CPU bottleneckso how can I know if have limit from CPU ?
System Name | Rainbow Sparkles (Power efficient, <350W gaming load) |
Processor | Ryzen R7 5800x3D (Undervolted, 4.45GHz all core) |
Motherboard | Asus x570-F (BIOS Modded) |
Cooling | Alphacool Apex UV - Alphacool Eisblock XPX Aurora + EK Quantum ARGB 3090 w/ active backplate |
Memory | 2x32GB DDR4 3600 Corsair Vengeance RGB @3866 C18-22-22-22-42 TRFC704 (1.4V Hynix MJR - SoC 1.15V) |
Video Card(s) | Galax RTX 3090 SG 24GB: Underclocked to 1700Mhz 0.750v (375W down to 250W)) |
Storage | 2TB WD SN850 NVME + 1TB Sasmsung 970 Pro NVME + 1TB Intel 6000P NVME USB 3.2 |
Display(s) | Phillips 32 32M1N5800A (4k144), LG 32" (4K60) | Gigabyte G32QC (2k165) | Phillips 328m6fjrmb (2K144) |
Case | Fractal Design R6 |
Audio Device(s) | Logitech G560 | Corsair Void pro RGB |Blue Yeti mic |
Power Supply | Fractal Ion+ 2 860W (Platinum) (This thing is God-tier. Silent and TINY) |
Mouse | Logitech G Pro wireless + Steelseries Prisma XL |
Keyboard | Razer Huntsman TE ( Sexy white keycaps) |
VR HMD | Oculus Rift S + Quest 2 |
Software | Windows 11 pro x64 (Yes, it's genuinely a good OS) OpenRGB - ditch the branded bloatware! |
Benchmark Scores | Nyooom. |
And possibly because Mafia definitive edition does not need anything like the power of a 3080 and a 10700k I mean they recommend a 3770 and a GTX1080, take a look at it's recommended specs, it is after all a DX11 game …...……….
Mafia: Definitive Edition | Mafia Games
Starring Tommy Angelo, Mafia: Definitive Edition is a complete overhaul of the original 2002 game, remade from the ground up.mafiagame.com
so that game use only two cores ? it possible in 2020 look so bad for game this yearAnd possibly because Mafia definitive edition does not need anything like the power of a 3080 and a 10700k I mean they recommend a 3770 and a GTX1080, take a look at it's recommended specs, it is after all a DX11 game …...……….
I love that information like hobby moreover it curious me.Stop watching benchmarks and start playing. Gaming on PC has never been smoother in the history of gaming really, especially with the high refresh monitors and VRR tech we have now.
Games aren't about FPS counters and they won't give you the deep dive on how PCs work either.
If you want information, start researching architecture differences between brands and generations. This isn't an overnight thing to learn and you've already got your answer from this thread.I love that information like hobby moreover it curious me.
Do you know the reason? it very weird.
I do it anytime but still have last question issue .If you want information, start researching architecture differences between brands and generations. This isn't an overnight thing to learn and you've already got your answer from this thread.
Some games don't use all threads as said in post #3. Some use one, or two, or all. Some games it won't matter what hardware you give it just won't run well. Nothing in your control.I do it anytime but still have last question issue .
comments #15 and #10
The low system specs requirement answers your question (relative to a 2020 game release), 16 threads in a CPU will not really help if the game is only able to use 2 or 4, recommended specs is a 4 core 8 thread Intel CPU that is now 7 generations old, posts 4, 5, 9, 11 and 14 answer your questions …… thread closed as I am getting dizzy again...……. research is the best way to further your knowledge if you would like to know more to feed your hobby.I do it anytime but still have last question issue .
