Why do my cpu fan go crazy?
spirates
41 (0.01/day)
Hi, ever since I installed a new gpu ( gtx 275 ) my cpu fan sometimes ( after the computer been on for a while) gets really loud and spins incredible fast.. I dont have a program to see this but i can hear how it increases with atleast 500% I would say.
I haven't seen a heat increase on my cpu when this happens which I thought was the problem. To get my cpu to slow down I will have to exit all my games and then wait a few minutes, or i can remove one side of my computer chssi and it stops instantly :O..
I guess its not very easy for you to say since you cant see how my computer is build up but can you atleast guess what the problem may be?
Summary: My Cpu-fan starts to spin really fast and gets really loud after playing a few hours though I can't see a heat increase over my cpu. When I remove one side of my chassi it stops.
What program can I use to see my computer fan speed with btw?
I have a Coolermaster Storm Sniper Gaming Chassi.
EDIT: Right now I cant have my chassi side on at all, whenever I put it back on the fan goes fast right away :S.
Polaris573
Senior Moderator
4,268 (0.58/day)
Little Rock, USA
Processor LGA 775 Intel Q9550 2.8 Ghz
Motherboard MSI P7N Diamond - 780i Chipset
Cooling Arctic Freezer
Memory 6GB G.Skill DDRII 800 4-4-3-5
Video Card(s) Sapphire HD 7850 2 GB PCI-E
Storage 1 TB Seagate 32MB Cache, 250 GB Seagate 16MB Cache
Display(s) Acer X203w
Case Coolermaster Centurion 5
Audio Device(s) Creative Sound Blaster X-Fi Xtreme Music
Power Supply OCZ StealthXStream 600 Watt
Are you sure it's the CPU fan and not the video card fan? You did say you noticed it right after you installed a new card. I bet since you don't notice any heat increase on your CPU that the video card is getting hot and its fan is speeding up to compensate.
Kursah
Super Moderator
14,757 (2.19/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
No offense, but haven't you already made a thread or two about this issue with your CPU fan recently?
And as Polaris asked, are you sure it's the CPU fan and not the GPU fan? Everest should display cpu fan rpms, maybe the MB utility that comes on the MB CD or on the MFG's website, Speedfan, etc all should show you at least a percentage if not an RPM value. Then I'd use EVGA Precision for monitoring my GPU stuff (though everest will monitor GPU fans too, among many other things...great utility).
spirates
41 (0.01/day)
well... I've kinda put my ear into my computer and iam sure its the cpu :S, to confirm this can someone tell me programs´(s) where i can see my cpu fan speed?
4,541 (0.81/day)
Denmark
System Name The work PC /2700x/5950x
Processor 3900X stock/ 2700x stock/ 5950x 4200 MHz fixed @ 1,056-1,08V
Motherboard Gigabyte AORUS Master X570/2xMSI X470 M7 AC
Cooling Custom WC XSPC RX480, Laing DDC, XSPC Laing DDC Top V3 and EK Velocity/NH15/NH-U12S SE
Memory 32 GB Viper 3600/14 /16 GB Trident Z F4-4000C18D-16GTZSW 3600 /32 GB G Skill Flare CL14 3400
Video Card(s) 2070 Super X MSI/GTX 970 MSI/ GTX 970 MSI
Storage 1 TB SSD+500 GB NVMe / 500 GB SSD/ 2 TB 990 Pro
Display(s) Dell UltraSharp U2518D/2408WFP
Case Corsair 800D / Lian test bench/NZXT 500
Power Supply AX 850 Titanium/AX 860i/AX 760
Software Dual boot/Win 10 / Linux / Win 10+Linux
In order to find out which fan that does ramp up install CPUID Hardware monitor or a similar program. That should tell you the different fan speeds among other things.
spirates
41 (0.01/day)
Hm, what I understood of that post is that there is a program called "everest". Thanks, gonna check that out :)
Polaris573
Senior Moderator
4,268 (0.58/day)
Little Rock, USA
You have multiple threads for what is basically the same problem. Choose which one you want to continue the discussion in and I'll close the rest. If you do not choose I will choose for you.
spirates
41 (0.01/day)
Well I installed both Everest and HWMonitor. In everest i found no cpu fan, in HWMonitior I found 1 fan but dunno if its for my cpu. uploading pic so you cann tel me if its the cpu fan or not..
EDIT: I also downloaded fanspeed, and got this. Can someone tell me what the different heat-thingys is? And why is tehre a fire icon infrom of some of them :s
3volvedcombat
1,514 (0.26/day)
South California, The desert.
System Name My Computer
Processor Core 2 Q9550 4Ghz 1.23volts
Cooling Corsair
Memory OCZ
Video Card(s) Galaxy
Storage Western Digital
Display(s) Acer
Case Lian li
Audio Device(s) Asus
Power Supply Corsiar
Software Microsoft
Benchmark Scores 25,000 3dmark06 at 4.35Ghz processor, 835core card!
http://img195.imageshack.us/img195/6698/cpus.png
http://img39.imageshack.us/img39/325/cpuud.png
WOW YOUR GTX275 IS OVERHEATING TERRABLY, ITS NOT YOUR CPU FAN, If that your temp at your desktop im surprised you didn't hit 105c and shut the hell down. 83C FOR THE GPU IS REDICULAS. Your new GTX 275 is getting hot enough to cook eggs on it, thats way to hot. I ALREADY POSTED ON another of your threads that it was your new video card, that was the problem. Now you should consider getting a new case for your computer because it has no airflow once so ever.
4,012 (0.70/day)
Sarasota, Florida, USA
System Name Awesomesauce 4.3 | Laptop (MSI GE72VR 6RF Apache Pro-023)
Processor Intel Core i7-5820K 4.16GHz 1.28v/3GHz 1.05v uncore | Intel Core i7-6700HQ @ 3.1GHz
Motherboard Gigabyte GA-X99-UD5 WiFi LGA2011-v3| Stock
Cooling Corsair H100i v2 w/ 2x EK Vardar F4-120ER + various 120/140mm case fans | Stock
Memory G.Skill RJ-4 16GB DDR4-2666 CL15 quad channel | 12GB DDR4-2133
Video Card(s) EVGA GTX 1080 Ti Hybrid SC2 11GB @ 2012/5151 boost | NVIDIA GTX 1060 6GB +200/+500 + Intel 530
Storage Samsung 840 EVO 500GB + Seagate 3TB 7200RPM + others | Kingston 256GB M.2 SATA + 1TB 7200RPM
Display(s) Acer G257HU 1440p 60Hz AH-IPS 4ms | 17.3" 1920*1080 60Hz wide angle TN notebook panel
Case Fractal Design Define XL R2 | MSI
Audio Device(s) Creative Sound Blaster Z | Realtek with quad stereo speakers and subwoofer
Power Supply Corsair HX850i Platinum | 19.5v 180w Delta brick
Software Windows 10 Pro x64 | Windows 10 Home x64
I've usually had this happen with stock AMD CPU coolers when the case door is closed. This is because the fan will begin sucking in hot air that builds up in the case, which heats up the thermistor on the particular fans that AMD uses (a resistor that is sensitive to heat changes, and as heat increases, the resistance decreases, thus causing an increase in fan speed). If you have poor air flow or a side panel fan is not blowing cool outside air onto your stock CPU fan (if that is what you have), then that is most likely the problem.
An example is my 3 month old AMD Phenom II X4 955BE's stock cooler, which I just took apart because I didn't need it.
Here's the Heatsink and fan:
And the thermistor on the back side of the fan.
I also agree with this.
3volvedcombat
1,514 (0.26/day)
Cooling Corsair
Memory OCZ
Display(s) Acer
Case Lian li
Software Microsoft
http://img.techpowerup.org/091114/1114091747.jpg
http://img.techpowerup.org/091114/1114091748.jpg
Look at his gtx 275 temperature in his screen shots. My GTX260 dosnt even reach 81c when in crysis on ultra high. When he is in a game for a couple of hours the GPU must hit 95c+ and thats insanely hot.
spirates
41 (0.01/day)
:SSSSSSSSSSSSSSSSSSSSSS ouch, how bad is this :(((, how can my air flow be this bad :z
355 (0.06/day)
Canberra Australia
Processor i5 750 4.2ghz 1.4V
Motherboard Gigabyte P55-UD4P
Cooling Corsair H70
Memory 2X2G Gskill @2140 8-11-8-28-1T
Video Card(s) 2xGainward Phantom3 570@860/4200
Storage 2xWD 500G AAKS Raid0 + 2XWD 1T Green in Raid0
Display(s) 24" HP w2408h+23" HP w2338h
Case SilverStone Raven2E-B
Audio Device(s) onboard for now
Power Supply Antec 1000W Truepower quattro
Software Win7 Ultimate 64bit
err, your 275 idles at 80 degree+?
MK4512
222 (0.04/day)
Toronto, Canada
System Name MK4512's Computer
Processor Phenom II X3 720 @3.4GHz
Motherboard ASRock AOD790GX
Cooling Artic Cooling Freezer 64 Pro
Memory 4 GB GSkill DDR2 800 RAM @4-4-4-12
Video Card(s) Sapphire Radeon 4890
Storage 500GB Seagate
Display(s) 22" Philips 1920x1080
Case Antec 300 (w/ New LED Fans!)
Power Supply 600w OCZ XStream Modular PSU
Software Windows 7
Bad cable management, lack of fans(?).
If no fans, try installing one next to the GFX card, on the side of the case. Also make sure you have all of your fans running properly (eg. Exhaust not acting as intake)
EDIT: Note for the future, flames = bad :D
3volvedcombat
1,514 (0.26/day)
Cooling Corsair
Memory OCZ
Display(s) Acer
Case Lian li
Software Microsoft
Put your computer on a desk, unscrew the side panel and take a picture of your case. Now i don't know what is cause this, also if you can show me what model your gtx275 is because im having a good feeling that it has a after market cooler on the video card. Not the stock sleak one that most have.
4,012 (0.70/day)
It could be a bad case airflow problem too that can cause both the GPU and CPU to overheat. The example I have provided is also plausible (i've experienced it firsthand). His CPU cooler is already running at 4500RPM, so I bet it almost reaches 6000 RPM under load, along with the cooking GTX 275.
spirates
41 (0.01/day)
I would really want to upload some pictures but i cant find my iphone cable :s, will check in the main house for another camera but guess everyones asleep already
3volvedcombat
1,514 (0.26/day)
Cooling Corsair
Memory OCZ
Display(s) Acer
Case Lian li
Software Microsoft
Im thinking that his CPU fan, is not being read and its a 4 pin molex fan and im thinking that 3000 rpm rating is the GPU fan itself already getting really load.
6,512 (1.11/day)
Midlands,UK
System Name Ultraman|Living room
Processor Intel core i9 13900HK|AMD Ryzen 7 5700x
Motherboard Alienware/Dell inverted motherboard|Asus B550m Prime Wifi
Cooling Alienware/Dell cooling + IETS GT500 cooling pad | Thermalright Silversoul 135 + Corsair 140mm white
Memory Alienware/Dell 32GB 6000mhz DDR5|Corsair DDR4 16GB 3200mhz
Video Card(s) Nvidia RTX4080 12GB| Zotac Nvidia RTX 4080 Super Trinity black edition 10GB
Storage 1TB Dell NVME + Samsung Evo 1TB NVME|WD Blue 500GB NVME,Kingston 240GB SSD,2TB Corsair NVME
Display(s) AOC Gaming CU34G3S/BK | LG C1 65" TV
Case Alienware X16| Corsair Carbide Air 240 White
Audio Device(s) onboard/Speakers: Logitech G560 | LG Eclair QP5 soundbar
Power Supply Alienware/Dell battery + 330W charger | Corsair RMx White 750w Gold Modular
Mouse Microsoft Pro Intellimouse - White | Logitech wireless
Keyboard EPOS mechanical keyboard| Logitech wireless
my 8800GT hits 80C when i play on any games but 8800GT temp is normally quite high with single slot coolers, what i did now was apply some MX-2 thermal paste and increase the cpu fan speed and when i play games it hits about 66-75 when i put fan speed up to 70% with my overclock its pretty good.
and my CPU hits 40-45C when i play games.
But damn those are really high temps,i recommend getting a better case too
spirates
41 (0.01/day)
meh :<<<<<<<<<< I have no idea what to do.. Will have to wait for tomorrow before i can upload pics :/
6,512 (1.11/day)
Midlands,UK
do you have a budget?? and can you show some swedish websites that sells desktop components and cases etc?
spirates
41 (0.01/day)
well I dont rly want to replace my chssi.. my friend got same chassi and a more powerful components in it and hes fine :(..
The picture i uploaded of speedfan, can anyone tell me what Fan1, Fan2, 3, 4, 5 is? And on the other side you see GPU temp but also temp1, temp2, temp 3, core.. What are those last 4 for temps?
4,012 (0.70/day)
Well, he already has a Cooler Master Storm Sniper case. We should probably wait for him to upload pictures showing us his setup before we make assumptions.
@Spirates: To better help us, you should fill out your System Specs drop down box so that we know precisely what components you are using. :)
2,682 (0.48/day)
System Name Old Gateway
Processor i5 4440 3.1ghz
Motherboard Gateway
Cooling Eh it doesn't thermal throttle
Memory 2x 8GB JEDEC 1600mhz DDR3
Video Card(s) RX 560D 4GB
Storage 240gb 2.5 SSD 3TB 7.2k Seagate
Display(s) Dell @ 1280*1024 75hz
Case Gateway
Audio Device(s) Gateway Diamond Audio EMC2.0-USB 5375U ($15 a long ass time ago)
Power Supply 380w oem
Mouse Purple Walmart special, 1600dpi. Black desk mat
Keyboard SteelSeries Apex 100
VR HMD Lmao
Benchmark Scores It can run Crysis (Original), Doom 2016, and Halo MCC
I'm pretty sure its the gpu fan making the noise, but a pic of the insides of the case would really help... ef there's a lot of dust you might want to blow it out too.
spirates
41 (0.01/day)
I will upload pictures of my computer tomorrow when i can get a camera..
