Why is GPU-Z power consumption absent?
Shohidul
5 (0.00/day)
Hi
Could anyone please help me, why TechPowerUp GPU-Z 0.6.7 cannot show power consumption option under Sensors tab?
My GPU is NVIDIA GeForce GTX 560.
It is very necessary for my research.
Thank you in advance for your time.
Shohidul.
2,750 (0.46/day)
Minnesota
Was it showing in previous versions?
Frick
Fishfaced Nincompoop
19,151 (2.84/day)
Piteå
System Name White DJ in Detroit
Processor Ryzen 5 5600
Motherboard Asrock B450M-HDV
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
It might be that it doesn't work with that card. Doesn't show with my GTX 550 Ti either.
Shohidul
5 (0.00/day)
@ Maban: Prior version TechPowerUp GPU-Z 0.6.6 does not show either.
@ Frick: Thanks much. Could you give any alternative idea?
How can I measure GPU power consumption?
Somebody use NVIDIA inspector tool for it. But I cannot find the power option there as well.
Any method is okay for me.
1,076 (0.22/day)
Botevgrad, Bulgaria, Europe
System Name Main PC/OldPC/3rd PC
Processor Intel Core i7-3770K Ivy Bridge/Core i5-3470 Ivy Bridge/Core i3-4330 Haswell
Motherboard ASUS P8Z77-V/ASRock Z68 Pro3 Gen1/ASUS H81M2
Cooling Cooler Master Hyper 212 EVO/Intel Box cooler/Intel Box cooler
Memory 32GB Corsair Vengeance/32GB ADATA/16GB ADATA
Video Card(s) SAPPHIRE R9 290 Tri-X OC 4GB/MSI RX 480 8GB/SAPPHIRE R9 390 8GB
Storage 2x1TB ADATA SSDs in RAID0+3 HDDs/2xCrucial 1TB SSDs in RAID0+3 HDDs/Samsung 1TB SSD+8TB+4TB HDDs
Display(s) Philips 274E5QHAB@HDMI + Philips 273EQH@DVI (both 27")
Case Fractal Design Define R4 Titanium
Audio Device(s) Kenwood Mini HiFi system/Microlab speakers/Philips HDMI (main)+LG TV monitor HDMI + Apple headphones
Power Supply Cooler Master Silent ProM 600 W (modular)
Mouse Microsoft Ergonomic Sculpt Desktop 2.0 (combo)@Razer Goliath mousepad (Medium speed)
Keyboard Microsoft Ergonomic Sculpt Desktop 2.0 (combo)
Software Win10 64-bit (Main PC v.1809 RTM Enterprise/2nd PC v.1903 Insider Preview Pro/3rd PC - same as 2nd)
2,750 (0.46/day)
Minnesota
Your card likely doesn't have the necessary components to monitor power consumption. Apart from buying one of them Kill A Watt or similar device, there's nothing cheap(ish) you can do about it.
Shohidul
5 (0.00/day)
@ Naki: Thank you for your reply. I installed the software but it does not show power level, even if there is a field to show power. I attached the image that contains details info.
I still have no solution for it. But badly looking for an way to measure GPU power consumption!
1,586 (0.33/day)
Kaunas, Lithuania
System Name my box
Processor AMD Ryzen 9 5950X
Motherboard ASRock Taichi x470 Ultimate
Cooling NZXT Kraken x72
Memory 2×16GiB @ 3200MHz, some Corsair RGB led meme crap
Video Card(s) AMD [ASUS ROG STRIX] Radeon RX Vega64 [OC Edition]
Storage Samsung 970 Pro && 2× Seagate IronWolf Pro 4TB in Raid 1
Display(s) Asus VG278H + Asus VH226H
Case Fractal Design Define R6 Black TG
Audio Device(s) Using optical S/PDIF output lol
Power Supply Corsair AX1200i
Mouse Razer Naga Epic
Keyboard Keychron Q1
Software Funtoo Linux
Benchmark Scores 217634.24 BogoMIPS
IIRC, HWMonitor could show my GPU power readings while other programs could not. Give it a shot - might work for You.
1,076 (0.22/day)
You are trying to run MSI Kombustor!
I suggested MSI AfterBurner - these are two DIFFERENT apps, so please try that instead. :)
Another app you can try is EVGA Precision.
Shohidul
5 (0.00/day)
@ Vinska and Naki: Thanks for your kind reply. I tried your suggestions... but still cannot find it. HWMonitor shows power for CPU but not for GPU. Attached images show details...
