Why is GPU-Z showing graphics memory bus width as 64bit instead of 128bit?
7 (0.02/day)
Trinidad & Tobago
System Name Lenovo Ideapad 3 15IAU7 (82RK001JUS) laptop
Processor Intel Core i3-1215U 6 cores, 2.5GHz (up to 4.4GHz)
Motherboard LENOVO LNVNB161216
Memory 16GB DDR4-3200 RAM
Video Card(s) 12th Gen Intel UHD Graphics (Xe) 64EUs iGPU 1.1GHz
Storage 256GB SSD
Display(s) 15.6" FHD (1920x1080) TN
Software Windows 11 64-bit Home
Hi, i'm new to the forum so excuse me if i do or say anything wrong. I have a almost 10 month old Lenovo laptop with a Core i3-1215U 6-core processor in it . I've been noticing for the past months that GPU-Z keeps showing the bus width for the graphics memory for the integrated UHD Graphics Xe 64EUs GPU as 64bit instead of 128bit, when my laptop has 12GB of RAM that is in dual-channel mode. I posted a screenshots below to prove my point. Will this be addressed soon in a next update? Thanks.
187 (0.61/day)
Hi @Starjack34 and welcome.
Unless things have changed then 12GB of RAM means likely running in flex mode. Half of the 8GB module would be combined with the 4GB module to give 8GB of dual channel and the remaining 4GB would run in single channel. Is it guaranteed the shared memory for igpu would only be in dual channel, maybe that's why it's showing 64bit? FWIW my laptop igpu which is 10 years old now shows 128bit on GPU-z 2.54.0 and earlier.
7 (0.02/day)
Trinidad & Tobago
Storage 256GB SSD
Well the 8GB is actually one module, soldered on the laptop itself. 4GB is the slotted memory. My system did come with 8GB RAM alone before upgrading with the 4GB RAM stick. I would only wondered if this affect those whose laptop come with soldered memory because some software might have problem reading onboard memory vs slotted memory. Your laptop for instance only has slotted memory (RAM sticks in slots) because obivously you're using an old laptop. That's why GPU-Z is showing yours as 128-bit. I purchase mines last year and is much slimmer, that it doesn't include a cd/dvd drive and it uses a SSD. I don't know what it is really but it doesn't seem to affect my system's iGPU's gaming performance anyway as games were playing at their best. Even if it is i'm running these games with just 64-bit bus width, then i must have a really strong iGPU.
5,469 (0.77/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Keyboard Logitech G613
As @:D:D mentions, your system is running in so-called asymmetric dual-channel mode. In other words, the first 4GB of the 8GB module + the entirety of the 4GB module are being accessed in dual-channel mode i.e. 2x 64-bit, but the remaining 4GB of the 8GB module has nothing to match with and hence runs in single-channel mode i.e. 64-bit. So technically all of these apps are both correct and incorrect.
The only variable here, then, is whether the Intel IGP accesses memory of the first 4GB or the last 4GB of memory i.e. whether it's running in 128-bit mode or 64-bit mode. I don't know if it's possible to determine, but I will defer to @W1zzard in this regard.
2,072 (0.54/day)
System Name Ryzen 2023
Processor AMD Ryzen 7 7700
Motherboard Asrock B650E Steel Legend Wifi
Memory G Skill Flare X5 2x16gb cl32@6000 MHz
Video Card(s) Sapphire Radeon RX 6950 XT Nitro + gaming Oc
Storage WESTERN DIGITAL 1TB 64MB 7k SATA600 Blue WD10EZEX, WD Black SN850X 1Tb nvme
Display(s) LG 27GP850P-B
Case Corsair 5000D airflow tempered glass
Power Supply Seasonic Prime GX-850W
Mouse A4Tech V7M bloody
Keyboard Genius KB-G255
Software Windows 10 64bit
What??? Are you comparing the system's memory with the igpu's? The igpu will always be 64 bit, it has nothing to do with the systems ram. Dont think it will go to 128 bit even if it uses system ram.
EDIT: Something I found online
Question "Hi, why is the video core memory width bus equal to 64 bits when I have two sticks of RAM and it should be 128? how can i fix it?"
Answer "
In reference to your question, the reason is, as you can confirm in the link below, that the maximum graphics memory on Windows* 10 and Windows* 11 when using Intel® UHD Graphics is limited by the Operating System to one-half of the system memory. So, if you have 128 bits of memory RAM, that means you will have 64 bits of graphics memory.
187 (0.61/day)
Half the system memory as in if there is 10GB of system memory then up to 5GB can be used for graphics.
Found a video of 2x8GB dual channel and i3-1215U with GPU-Z showing 64-bit while GPU tab of CPU-Z shows 128-bit so it's not because of flex mode as I thought earlier.
Hopefully one of the Dev's will explain.
7 (0.02/day)
Trinidad & Tobago
Storage 256GB SSD
Answer "
In reference to your question, the reason is, as you can confirm in the link below, that the maximum graphics memory on Windows* 10 and Windows* 11 when using Intel® UHD Graphics is limited by the Operating System to one-half of the system memory. So, if you have 128 bits of memory RAM, that means you will have 64 bits of graphics memory."
No i'm not comparing the system's memory with the iGPU's. I'm talking about the bus width reading on GPU-Z as to why it reads 64-bit instead of 128 bit when my system has memory (RAM) that is in dual channel mode. When your system has only one memory slot occupied (now i'm talking about the RAM), the bus width would remain at 64 bit. If it has two memory slots are occupied, them the bus width with go to 128 bit. That is not what I'm experiencing with my system as seen on the GPU-Z of my system's iGPU. Although Assimilator did tell me that my system's memory is running in asymmetric dual-channel mode which i feel is true. Asymmetric means that is not identical or not equivalent. So the 4GB, out of the 12GB RAM, runs on top and is single channeled. Maybe that's why the bus width shows 64 bit, well for the iGPU's interface.
No, you might be right. If my system's memory is running in asymmetric dual channel mode as Assimilator said, then it's in flex mode. At least according to this guy on reddit:
https://www.reddit.com/r/XMG_gg/comments/iv8b7q
W1zzard
Administrator
27,209 (3.70/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
This looks like a detection bug in GPU-Z, let me look into it
187 (0.61/day)
@Starjack34 In your screenshot CPU-Z shows a DRAM clock of 1596MHz, HWinfo 1330MHz and GPU-Z 2660MHz, weird. :confused:
If we take HWinfo clock of 1330MHz that gives a DDR speed of 2660MT/s and with dual channel 128bits (which is 16 Bytes) gives 16 x 2660 = 42,560MB/s or 42.56GB/s maximum theoretical bandwidth. Usually I see about 80% or so of that in real life in optimized benches.
DRAM bandwidth can be checked with Intel mlc
Or if you prefer to target igpu then poclmembench uses openCL
Example of my dual channel DDR3 @800MHz DRAM clock (1600MT/s)
Code:
allocated 1476395008 bytes 1.38 GB
Running Bench test on:Intel(R) HD Graphics 4600
Chunk:   0 (   0- 128)MB Speed: 21.15 GByte/s OK
Chunk:   1 ( 128- 256)MB Speed: 21.28 GByte/s OK
Chunk:   2 ( 256- 384)MB Speed: 21.37 GByte/s OK
Chunk:   3 ( 384- 512)MB Speed: 21.35 GByte/s OK
Chunk:   4 ( 512- 640)MB Speed: 21.31 GByte/s OK
Chunk:   5 ( 640- 768)MB Speed: 21.32 GByte/s OK
Chunk:   6 ( 768- 896)MB Speed: 21.25 GByte/s OK
Chunk:   7 ( 896-1024)MB Speed: 21.31 GByte/s OK
Chunk:   8 (1024-1152)MB Speed: 21.36 GByte/s OK
Chunk:   9 (1152-1280)MB Speed: 21.30 GByte/s OK
Chunk:  10 (1280-1408)MB Speed: 21.31 GByte/s OK
Max theoretical bandwidth would be 25.6GB/s
ir_cow
3,993 (0.69/day)
USA
CPU only has 2 channels. Can't run in single and dual at the same time. Either it's dual channel or single channel, not both.
As for GPUs... Idk.
187 (0.61/day)
Intel said:
Dual-Channel Mode – Intel® Flex Memory Technology Mode
The IMC supports Intel Flex Memory Technology Mode. Memory is divided into a symmetric and asymmetric zone. The symmetric zone starts at the lowest address in each channel and is contiguous until the asymmetric zone begins or until the top address of the channel with the smaller capacity is reached. In this mode, the system runs with one zone of dual-channel mode and one zone of single-channel mode, simultaneously, across the whole memory array.
7 (0.02/day)
Trinidad & Tobago
Storage 256GB SSD
Code:
Both the 8GB and 4GB RAM my system has are similar in speed and technology. They're both DDR4 SDRAM type of RAM with max speed of 3200MHz or 1600MHz each. I was really anticipating that the dual channel would've been that effective especially when you have identical specs of separate of RAM chips, despite the difference of capacity. Unless my system's motherboard has limit certain things including their clock speed which is weird. My current laptop is the most modern one i ever purchased. So modern, the Core i3-1215U processor itself was at least some months old after it was launched. By the end of this October, would be a year after i purchased my device.
W1zzard
Administrator
27,209 (3.70/day)
Memory 48 GB
Thanks for testing a private beta @Starjack34. This will be fixed in next release. Underlying reason is that ADL/RPL has two memory controllers. I only checked the bus width on one of them.
5,469 (0.77/day)
Ikenai borderline!
You mean RKL, right?
These two memory controllers, are they the ones for DDR4 and DDR5 respectively?
5,469 (0.77/day)
Ikenai borderline!
7 (0.02/day)
Trinidad & Tobago
Storage 256GB SSD
All of this having been tested, you should consider buying a matching 8GB stick and swapping it with the 4GB stick so you can get the best from your setup. 8GB sticks of DDR4-3200 are very inexpensive at the moment.
I was hoping to get a 8GB stick when my mother went NY last year along with my current laptop i purchased as well, especially since I'm living in Trinidad and things does be somewhat expensive down here. But she end up purchasing two 4GB RAM sticks, one currently use in my device. But since i started back working, i might invest in one not too soon. Probably during the last quarter of this year.
7 (0.02/day)
Trinidad & Tobago
Storage 256GB SSD
I have purchased a 8GB RAM stick and is working well in my system.
