Why Mouse Manufacturer's don't use Optical Encoders?
931 (0.56/day)
Turkey
System Name MSI-MEG
Processor AMD Ryzen 9 3900X
Motherboard MSI MEG X570S ACE MAX
Cooling AMD Wraith Prism + Thermal Grizzly
Memory 32 GB
Video Card(s) MSI Suprim X RTX 3080
Storage 500 GB MSI Spatium nvme + 500 GB WD nvme + 2 TB Seagate HDD + 2 TB Seagate HDD
Display(s) 27" LG 144HZ 2K ULTRAGEAR
Case MSI MPG Velox Airflow 100P
Audio Device(s) Altec Lansing
Power Supply Seasonic 750W 80+ Gold
Mouse HP OMEN REACTOR
Keyboard Corsair K68
Software Windows10 LTSC 64 bit
I remember like ten years ago Logitech and some other brands were using the Optical encoders which theoretically has an infinite lifespan. But as far as I know, nowadays only Zowie mouses uses this technology.
I wonder, why do manufacturers abandon the newest technology and prefer something technologically much older? In contrast to Optical encoders, the analog ones are also more prone to failures and errors. Do you think it is something to do with planned obsolescence policy?
364 (0.33/day)
Though I am not sure , I think optical encoders require more processing, plus having one part responsible of reporting wheel’s position is better than have two parts doing the same , and they probably consume more power , probably in the order of milliwatts but less is always better , as for longevity yes optical has no mechanical wear so it should last longer , but I think the parts have a finite number of operating hours , maybe they figured that other parts of the mouse fail before the encoders themselves fail so it was an opportunity to cut cost , less soldering and less parts to assemble , to me they’re both fine I don’t see a difference in accuracy or lifetime of devices
4,824 (3.86/day)
Colorado, U.S.A.
Power Supply EVGA 500W1
Software Windows 11 Home
An optical encoder is mechanical and so more prone to wear and dirt (the ball picks up crud). The scroll wheel remains an optical encoder as it picks up less dirt than a ball.
silentbogo
5,518 (1.40/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 3800X
Memory 4x8GB Samsung DDR4 ECC UDIMM
Video Card(s) Inno3D RTX 3070 Ti iChill
Storage ADATA Legend 2TB + ADATA SX8200 Pro 1TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
Software Windows 11, Ubuntu 20.04 LTS
There's only one reason: cutting costs.
Optical encoders are cool and all, but require more circuitry to run and cost more. "Infinite lifespan" is a bit of a stretch (LEDs do have limited longevity, as you know), but yeah - it's a lot more reliable than mechanical ones. My good-ole G5 still works, and scroll wheel is the only thing I haven't replaced. I've only looked at swapping the mechanical part, while IR LED and receiver are both perfectly functional after nearly 1.5 decades of service.
There are also few A4Tech Bloody models with optical encoders (and optical switches). Logitech still makes a few(G502, MX518).
9,871 (1.88/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
and mostly use mouse for some years before buying a new one so it will be pretty costly if they use expensive optical for something that their user will replace it next year
Fourstaff
10,065 (1.87/day)
Home
Processor 3570K // 10400F
Cooling Stock // Stock
Logitech uses electromagnetic encoder for their MX3 mouse scroll wheel, I think the industry is slowly stepping away from optical encoder?
12,682 (1.92/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
I can see how an encoder might add latency which would raise the hackles of gamers.
931 (0.56/day)
Turkey
System Name MSI-MEG
Memory 32 GB
Thanks everyone who contributed, but I think it is time to ask the manufacturers and encourage them to use latest innovations in their shiny colorful mices. Analog encoders are definitely not belong to this age.
12,682 (1.92/day)
Nebraska, USA
Mouse Logitech M190
Not necessary. Tell them with your wallet.
931 (0.56/day)
Turkey
System Name MSI-MEG
Memory 32 GB
After My omen reactor mouse scroll behaves strangely, I've remember this topic and wish the manufacturers use optical encoders one more time.
freeagent
8,082 (3.73/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
I love my Zowie mouse, it’s gotta be 10 years old by now..
931 (0.56/day)
Turkey
System Name MSI-MEG
Memory 32 GB
freeagent
8,082 (3.73/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
Is Zowie still being considered the best?
I honestly didn't know they were! My G7 died so he brought that one over for me, was pretty much brand new in the box, that was in 2017
