Will a laptop boot if I remove internal Wifi-card and detach antenna wires ?
Status
Not open for further replies.
144 (0.06/day)
Finland
Hello
Buying and tinkering with newer laptop wifi cards:
Will a HP or any brand laptop boot if I remove a internal Wifi-card mini pci-e half size and detach antenna wires ?
- Will it show always something like "notice: no wifi-card installed" on boot up or in Windows ?
- Or will it boot normally ( Like if a 1pc of RAM is removed or added ) and everything is normal just wifi and card is not there in Windows like if I would detach a PCI Wifi-card in a desktop computer ?
What is also the difference between 2-wire and 3-wire laptop wifi cards ? Will they work together compatibility ?
- Lenovo has: a black, grey and white wire.
- HP has: wires marked as (1.)black=AUX and (2.)black=MAIN.
2,144 (0.35/day)
Austin TX
Processor i9 11900k
Motherboard Maximus XII Apex
Cooling Custom Liquid W/ 360x60 Radiator
Memory 32Gb Team XTREEM ARGB 3600 b-die
Video Card(s) Waterblocked MSI RTX 4070
Storage Intel 900p 480Gb + 4tb Intel 670p
Display(s) LG C2 evo 42"
Case Geometric Future Model 8
Audio Device(s) HD58X + Sennheiser GSX 1000
Power Supply Corsair RM 750x
Mouse Steelseries Aerox 5 wired
Keyboard Akko Mod 007b HE
VR HMD Samsung Odyssey+
It will work fine without it. Just make sure you un plug the battery before you remove it.
40,692 (6.54/day)
Hello
Yes it will boot without it it's not a critical component of the system like a processor or Ram.
Also handle all Electronics with ESD precautions
144 (0.06/day)
Finland
Can I put a newer AC wifi card to a Lenovo T61(2008) it has "a whitelisted BIOS" (=accepts all brand mini pci-e cards) but it has 3 pcs antenna wires and the new cards have 2-connectors ?
1 TR1 ( grey )
2 TR2 ( black )
3 RO ( white )
1 AUX ( black )
2 MAIN ( grey )
The AC-one would make the internet faster.
What does the white wire do ?
40,692 (6.54/day)
144 (0.06/day)
Finland
Ok. Some site suggested leaving the 3rd white wire disconnected.
I'll start toying with different mini pci-e cards.
40,692 (6.54/day)
There you go
12,519 (1.91/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Any reason why you want to physically remove this device? You could just disable it and not worry about it.
40,692 (6.54/day)
He want's to upgrade the wifi card from N to AC which requires a custom mobo bios from Middleton to disable the hardware white list.
Hopefully the other line doesn't act as a EMI pickup
12,519 (1.91/day)
Nebraska, USA
Mouse Logitech M190
I still don't see why the the old card needs to be "physically" removed.
2,331 (0.45/day)
Processor Intel i7 970 // Intel i7 2600K
Motherboard Asus Rampage III Formula // Asus P8P67 Deluxe
Cooling Zalman CNPS9900MaxB // Zalman CNPS11X
Memory GSkill 2133 12GB // Corsair V 2400 32GB
Video Card(s) ASUS GTX1080 // MSI GTX1070
Storage Samsung 870EVO // Samsung 840P
Display(s) HP w2207h
Case CoolerMaster Stacker 830se // Lian Li PC-9F
Power Supply Seasonic X 850w Gold // EVGA 850w G2
Mouse Logitech G502SE HERO, G9
Keyboard Dell
Software W10 Pro 22H2
I've seen special plastic caps or small clear tubing used to cover the ends of the antennae wire to terminate unused wifi wires by oem's.
The OP should wrap/insulate the unused wire, so as not to cause a short.
40,692 (6.54/day)
Yup in the telco networking business we had coax terminating caps to shunt emi from affecting the rest of the hpna layout in a home.
12,519 (1.91/day)
Nebraska, USA
Mouse Logitech M190
Coax terminating caps are different as they typically are "loaded" (present a 50Ω or 75Ω load). The plastic caps found on other connectors are really just called "dust caps" for obvious reasons, though they may also be used to help protect exposed pins from getting bent.
dorsetknob
9,106 (1.29/day)
:) to Physically fit the Replacment Card ( bill has Doh headslapping moment :))
12,519 (1.91/day)
Nebraska, USA
Mouse Logitech M190
LOL - you're right. I was not thinking about a removable "card" (even though that is what the OP said) since most (NICs) network interface cards are integrated these days and not really "cards". I'll go away now. :oops:
2,800 (0.66/day)
System Name BoX-Server | 775PC
Processor I3 3.5GHZ (3150) | Modded Xeon E5450 (OC @3.60)
Motherboard ASRock B85M-ITX | ASUS P5Q-EM
Cooling OEZM HSK | 92MM Heatsink RGB
Memory 8GB DDR3 | 8GB DDR2
Video Card(s) AMD 6450 | AMD RX 550 4GB
Storage 120GB SSD 1TB WD | 120GB SSD 1TB Seagate 500GB HDD <<
Display(s) DELL 17" LCD 1280x1024 | ASUS 24" LCD IPS
Case CoolerMaster 110 | RoseWill ZIRCON
Power Supply Rosewill 610WATT | Rosewill 550WATT
Mouse Input-Director| RoseWill FUSION C40
Keyboard Input-Director | RoseWill FUSION
Removing the antennas or the card wouldn't matter. It would still boot but you'd have no Wi-Fi. My HP 8460P has 3 wires but my card only has two places to attach. Not sure why it has 3 but maybe it has a similar model with a Wi-Fi card that uses 3. HP's Elite Books use only specific Wi-Fi cards. Most are black listed in the BIOS
Status
