Will "poor VRMs" affect Ryzen 7 7800X3D performance? (not overclocking)
152 (0.04/day)
United Kingdom
Motherboard ASRock B650M Pro RS
Cooling Arctic Liquid Freezer II 240 A-RGB
Memory 32 GB DDR5-6000
Video Card(s) NVIDIA GeForce RTX 3080
Storage Samsung 990 Pro
Display(s) LG C2 42" (4K OLED), TCL 43" (4K VA)
Case Cooler Master MasterBox NR400
Audio Device(s) Logitech Z906
Power Supply Corsair RM850x (2018)
Mouse Logitech G305
Keyboard Tecware Phantom RGB (105-key)
I am looking for an affordable microATX motherboard to go with my Ryzen 7 7800X3D CPU, Arctic Liquid Freezer II 240 and RTX 3080.
As of today, these are currently the cheapest AM5 microATX motherboards in the UK:
I bought the Gigabyte B650M K (top one in the table) for £100 on special a few days ago but have since watched Hardware Unboxed, who said the VRMs were "poor".
In reality, will the VRMs cause me any issues? I will not be overclocking the 7800X3D.
I will pay an extra 29% to get better VRMs if needed, for example, but it is obviously pointless if I will not notice a difference in performance.
3,135 (1.54/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
Right after the gigabyte he suggests the asrock hdv board with one reason being the much better VRM. So maybe that board is a good choice.
Sadly the basement of the market has some junk stuff in it, but hopefully that one can run the chip to its rated spec.
152 (0.04/day)
United Kingdom
Mouse Logitech G305
You're not wrong, but the 44% jump from £100 (which is what I paid for the Gigabyte B650M K) to £144 (for the ASrock B650M HDV M.2) is quite large if it turns out the Gigabyte B650M K won't hold my 7800X3D back anyway.
2,796 (2.15/day)
Germany
System Name Sunk Cost Fallacy
Cooling Thermalright Phantom Spirit 120
Storage WD Black SN850X 1TB + 2x 2TB, 2x 4TB Crucial MX500, 4TB Samsung 870 Evo.
Display(s) Alienware AW2723DF, LG 27GR93U, LG 27GN950-B
Case Streacom BC1 V2
VR HMD Oculus Rift S
you can not overclock a 7800X3D.
and a 7800X3D pulls like 80W in all core workloads. a phone charger can run this CPU.
3,135 (1.54/day)
UK, Midlands
System Name Main PC
Processor 13700k
If you already have purchased the board, then test it and see if its held back. If it isnt, then it doesnt matter if thats your only concern.
9,279 (3.32/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
7800X3D is a fairly low wattage CPU, it will be fine.
11,140 (5.42/day)
Midlands, UK
System Name Nebulon B
Cooling be quiet! Dark Rock 4
Storage 2 TB Corsair MP600 GS, 2 TB Corsair MP600 R2, 4 + 8 TB Seagate Barracuda 3.5"
Mouse Logitech MX Master 2S
Keyboard Logitech G413 SE
I've got the MSi Pro B650M-A Wifi, and it's an absolutely superb board! It can handle much hungrier CPUs than the 7800X3D. :)
With that said, the 7800X3D is a very conservative CPU in terms of power consumption, so I doubt you'll have much trouble with it in any board.
I don't think you should ditch what you have for a better VRM that you most probably won't need with the 7800X3D.
This! OP: Don't change your motherboard unless you absolutely have to. ;)
freeagent
8,109 (3.73/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
CPU Nazi says:
No OC For You!
Seinfeld Soup GIF
You dont need anything fancy at all to run an X3D. You have just turned your PC into an Xbox :)
ir_cow
4,161 (0.71/day)
USA
"poor" VRM can lead to random shutdowns from overheating or random restarts when the CPU doesn't get the requested voltage for the turbo and hard locks the computer.
Will it happen to you? Probably not, I think most motherboards can handle 80 watts.
152 (0.04/day)
United Kingdom
Mouse Logitech G305
The 7800X3D has a TDP of 120 W.
18,542 (2.72/day)
System Name AlderLake
Personally I would never buy a high-end CPU to pair it with a bottom of the barrel motherboard....
11,140 (5.42/day)
Midlands, UK
Yeah, that means a 162 W power limit - but you'll never see it happen on the 7800X3D. The processor consumes 80 W maximum in a Cinebench all-core test.
Peak, so you'll only reach that with Prime95, R23 or CPU rendering. Gaming probably will be around 80
Nah, gaming is around 40, sometimes 50.
77 (0.02/day)
No you dont need any "expensive" overkill VRMs for a 7800X3D, so the cheapest board will do fine. I bough the Asrock B650M Pro RS WiFi for 150Euros and am happy with it. The only downside is with these "cheaper" boards, they dont support LLC (load line calibration). Which is important if you want to undervolt the CPU. I "only" can run a -20 all core PBO curve optimizer with my Asrock board and the 7800X3D, mostly could undervolt way more, if the board would support LLC. Only thing annoying about the Asrock is, it has a little bit of coil whine next to the CPU area, but you only hear it if the case is open and you go with your ears next to the board.
I have set a 75W PPT power limit with -20 PBO, and I get 18400 in Cinebench R23 and CPU hits around 73°C with air cooling (Endorfy Fortis 5 with 1 fan installed) in CB.
2,207 (0.47/day)
Springfield, Vermont
System Name KHR-1
Processor Ryzen 9 5900X
Video Card(s) Sapphire Nitro+ Radeon RX 6750 XT
Case Corsair 275R
Mouse Logitech G Pro (Hero)
I had a wake up call with what seems to be bad MOSFETs! I suddenly found the motherboard off and literally shows zero life entirely when plugged in. Looks like I payed the price for running anything more than a Ryzen 5, pretty much. Looks like the Ryzen 7 3700X took out the MOSFETs! And that 3700X was still working fine in another motherboard.
Get a cheapo motherboard=Don't be surprised for it to suddenly lose power and never power on again!
6,713 (1.46/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW | Sapphire PULSE RX 590
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
I always have a fan over vrms on any board I use. Less chance of failing from heat is a good thing.
16,671 (4.62/day)
most cheapo motherboards are not worth it, i always try to aim for mid-range. my current mobo is bottom of mid-range, but still mid-range. got it for $109 on sale, and its been rock solid for me.
2,207 (0.47/day)
System Name KHR-1
Case Corsair 275R
And, even that A620 just above, looks a ton better than the B450 motherboard that died on me.
