Will the RX 6950 XT work with my Z97 Motherboard?
Asaster
4 (0.00/day)
Hello dear community,
I bought my computer many years ago with a GTX980, but noticed now that it's no longer able to run high graphics with the newest games so I wanted to buy this graphics card:
Or this one
Now my problem is I have a rather old motherboard which is the MSI Z97 GAMING 7:
As for the latter graphics card, I wasn't sure if the PCI x16 4.0 would fit to the motherboard.
But honestly idk if either of them fit to my motherboard.
My power supply is also not crazy at 700W.
So I wanted to ask you if they would fit into my motherboard or if I should get a new one, and if so I'd be thankful if you could send me links to motherboards/ power supplies that are good quality and fit my situation. Thanks a lot!!
Best regards,
Asaster
38 (0.04/day)
São Paulo, Brazil
System Name N/A
Processor AMD Ryzen 5 5600
Motherboard ASRock B450M Pro4-F
Cooling Snowman MT6S
Memory 24 GB DDR4 SDRAM
Video Card(s) AMD Radeon RX 6600M (Navi23) [AMD]
Storage Reletech P400 SSD 1024GB
Display(s) 1920x1080p TV
Case Deepcool Tesseract
Power Supply WPM Gold Zero, 550W, 80 Plus Gold, Semi-Modular
Benchmark Scores Old X3440 Build on HWBOT: https://hwbot.org/submission/3915974_marvin129_cinebench___r15_xeon_x3440_
The GPU says it has PCIe 4.0 but it will still work on 3.0 just fine.
2,965 (2.06/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
PCIe is backwards compatible.
the only thing you'll miss out is resizeable BAR (Smart Access Memory) and your PSU might on the absolute edge. (RDNA2 Graphics Cards have nasty transients!)
install the card, use seperate power connectors (no daisy chain) and try it out.
if your system crashes under load the only issue might be your PSU.
18,584 (2.67/day)
System Name AlderLake
Another problem will be your whatever CPU you have in that motherboard being a major bottleneck for this high-end GPU.....
Your other problem will probably your 700W PSU....
Asaster
4 (0.00/day)
Thank you a lot and to all the others who answered, just one question, could you send me a link to a separate power connector that I could buy for this card? Thanks!!
1,293 (1.53/day)
The power supply is probably going to be an issue. The Red Devil you have listed above recommends 900w as a minimum.
2,965 (2.06/day)
Germany
i guess you didn't understood what i've meant with that.
with seperate power connectors i mean this:
Toothless
Tech, Games, and TPU!
9,700 (2.46/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Get a new power supply before anything else. You don't want to risk your shiny new card
7,277 (4.91/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Software Windows 10 Pro 22H2
It will work, provided your power supply is up to par. However, you should keep in mind that there is no processor on that platform that can push this GPU to its full performance - be that an i7-4790K or i7-5775C. These processors are based on 9 year old technology at this point, and you're effectively just shifting the bottleneck from the graphics card onto your poorly performing processor.
Unless you're buying this card on a significant discount and planning a platform upgrade beforehand, you should buy a slower GPU and a new system platform instead.
1,891 (1.38/day)
Romania
System Name Gaming1 / Office 2
Processor Intel i7 7700k@4.8ghz / Ryzen 7 5700G
Motherboard MSI 270 SLI PLUS / MSI MAG X570S - TOMAHAWK MAX WIFI
Cooling ID-Cooling Frostflow X 120 - Liquid / ID-Cooling SE-903 V2
Memory 2x16GB Corsair Vengeance LPX 3600 Black / 2x16GB Corsair Vengeance RGB Pro SL - 3600Mhz
Video Card(s) XFX RX 6600XT 8GB / XFX RX 5700XT THICC III Ultra 8GB
Storage 1st : 1x SSD Samsung 980 Pro 1Tb + 4x SAS HDD in RAID / 2nd : 1 Tb SSD Nvme Samsung 980 Pro 1Tb
Display(s) 2x Dell 3008 WFP
Case CoolerMaster HAF 932 / GENESIS IRID 300
Audio Device(s) Soundblaster XFI / Onboard
Power Supply Seasonic Focus 850 W / Seasonic Focus 850 W
Mouse Logitech G502 HERO / Logitech G5
Keyboard Dell SmartCard Reader SK 3205 / Dell SmartCard Reader SK 3205
Software 1st - Win 10 Pro X64 / Win 7 X86 / Ubuntu / 2nd - Windows 11 Pro x64
I totally agree to this point of view.
You will face soon the limit of the system (mainboard + CPU) - cause the video card won't have any trouble to run any game.
Ruru
S.T.A.R.S.
13,165 (2.98/day)
Jyväskylä, Finland
Audio Device(s) Sony WH-CN720N / TV speakers
VR HMD Oculus Rift CV1
Agree as well. Even something like a 2080 Ti or equivalent card would be practically bottlenecked by any 4c/8t CPU.
873 (0.48/day)
I have a 4790k @4.6 with a 6800xt and at 4k max detail the cpu bottleneck is not a big dea for my use case. I get at least 60 fps in everything I play.
At stock it'd be more an issue I think.
Toothless
9,700 (2.46/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
You're at 4k, you wouldn't see the issue.
I went from a 4790k at 4.7 to a 3700x and got a bump with my 1080ti at 3440x1440. Honestly anything on DDR3 is too old and will hold back your 6800XT, and anything OP is planning.
302 (0.32/day)
Germany
System Name Galaxy Tab S8+
Processor Snapdragon 8 gen 1 SOC
Cooling passive
Memory 8 GB
Storage 256 GB + 512 GB SD
Display(s) 2.800 x 1.752 Super AMOLED
Power Supply 10.090 mAh
Software Android 12
Based on what games you are playing at a given resolution and given detasils - we have no information on that - you will run into a cpu bottleneck very fast with anything about 6600nonXT/6600XT class or comparable. There are quite good videos about that topic available. Maybe you should think about upgrading your DDR3 based MB/CPU first. AM4 (same is true for socket 1700) might be end of life but the 5800XD is currently selling for 360€ if you don't want to spend quite a lot more on a future proof - but expensive - AM5 system. Then you can think about replacing your aged GPU by a mid-class RTX 4000 or RDNA3 GPU next year. They will probably be at least equally fast compared to the 6950XT.
