Will This Power Supply Unit Work?
TechnicGeek
15 (0.01/day)
Please take a look at this PSU:
It's a generic PSU ZEUS 520W made by Codegen.
I need to test if my motherboard powers on and I want to use this PSU. Will it be okay just for that purpose?
My system specs:
CPU: AMD Ryzen 5 3600X
Motherboard: Gigabyte B450 Aorus Elite
RAM: 2x8GB Corsair Vengeance LPX 3200MHz
GPU: EVGA GeForce RTX 2060
1,294 (0.18/day)
This PSU probably doesn't have the required 1x8pins PCI-E cable to power your RTX2060.
Check first, and try to find more pictures of the product from different angles.
edit: indeed, nowhere on the front box it is written that it has some 6pins/8pins gpu cables
13,598 (3.82/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
What region are you in, do you have 230V power?
I'd avoid that like the plague.
520W total that says 372 Max on the 12V rails and it only supplies 16Amps on the first 12V rail and 15 Amps on the second 12V rail.
It would be a good door stop, or firestarter for a BBQ.
19,368 (3.64/day)
Utter trash, that power supply.
Where are you buying from? Got a link?
TechnicGeek
15 (0.01/day)
I am from Middle East. This power supply costs $25. All I need is to power on my motherboard. I don't need BIOS, nor do I need POST. Just to see that motherboard starts and delivers power across it. I will plug 4-pin CPU fan to see if it spins and if power supply fan spins. That's all I need.
19,368 (3.64/day)
This doesn't even have the connectors you need to make it work man... we said that.
At least try a POS that has the connectors you need.
4,156 (0.87/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
But it says "high quality" on it?! If we can't trust tech marketing who can we trust???
1,321 (0.87/day)
That PSU is 520/2=260W PSU with questionable ripple suppression, as is with most cheap PSUs. You might find a good one but usually their (max.) power is (power on the box)/2.
19,368 (3.64/day)
You make a great point. Please accept my apologies for missing something so obvious. :(
/s :laugh::roll:
If you look at the label, it can output a combined 327W (15A/16A 12V rails). Someone already clarified what the label says. What it can really output, nobody knows.
4,156 (0.87/day)
if ripple suppression was the only thing you had to worry about that unit I would say you were rather lucky. If you somehow managed to hook up the RTX 2060 to that unit through adapters, I would fully expect a spark show followed by a smoke show followed by new paper weights that would look similar to your mobo and video card (possibly even more hardware)
1,321 (0.87/day)
Forget the label, it is at best half the power.
Not necessarily a spark show. It could work but not more than a year. Spark show would start at 372W. :)
4,156 (0.87/day)
interesting because when I think of Zeus on a power supply I think of Silverstones Zeus which has an eerily similar split on its 12v rail but the cables dont match up as Silverstone had 6 pin pcie power cables. The silverstone was made by enahnce not Codegen (powmax).
4,156 (0.87/day)
here is the best image I can find of that unit, it's a powmax special. If you can draw 372w out of it in a 40c case then you need to fly that unit to the Shenzhen Junk Hall of Fame
in case anyone wants to know more about powmax
I can get 2xMolex to 1xPCIe 8-pin adapter :rolleyes:
may want to take out an insurance policy on your PC (make sure it covers acts of god since the PSU is a Zeus)...possibly fire insurance for your home as well
19,368 (3.64/day)
Why are you insisting on using this? Why not get something that has the connectors and isn't a piece of shit (maybe spelling it out helps)?
Powmax, Raidmax, Chieftec.....all better at starting fires than powering PCs. :p
Maybe... but you(we) have no idea. Stop adding details where none (factually) can be had. :)
2,074 (0.54/day)
System Name Ryzen 2023
Processor AMD Ryzen 7 7700
Motherboard Asrock B650E Steel Legend Wifi
Memory G Skill Flare X5 2x16gb cl32@6000 MHz
Video Card(s) Sapphire Radeon RX 6950 XT Nitro + gaming Oc
Storage WESTERN DIGITAL 1TB 64MB 7k SATA600 Blue WD10EZEX, WD Black SN850X 1Tb nvme
Display(s) LG 27GP850P-B
Case Corsair 5000D airflow tempered glass
Power Supply Seasonic Prime GX-850W
Mouse A4Tech V7M bloody
Keyboard Genius KB-G255
Software Windows 10 64bit
TBH even if it's a total junk it should be able handle one boot up and staying on in IDLE, but this model seems to be a total junk. I would not risk a RTX 2060, but if you are planning to buy it just to test your system you should find a better used one or try to borrow one from a friend. When my GPU died I had to test my system with my old PSU that was half working but it did the job and I was able to determine the GPU was faulty, but that psu had all the necessary connectors.
833 (0.50/day)
Maryland, USA
Processor Ryzen 5 5600X
Motherboard MSI MPG X570S Carbon Max Wifi
Cooling CPU: bequiet! Dark Rock 4. Case fans: 2x bequiet Silent Wings 3 140s, 2x Silent Wings 3 120s
Memory 2 x 8 GB Patriot Viper Steel DDR4-4400 C19
Video Card(s) Sapphire NITRO+ RX 5700 XT
Storage 2TB Mushkin Pilot-E M.2, 1 TB SK Hynix P31 M.2, 1 TB Inland Professional, 500 GB Samsung 860 Evo
Display(s) MSI Optix MAG271CQR 1440p 144Hz, MSI Optix MAG241C 1080p 144Hz
Case Lian Li Lancool III
Audio Device(s) Philips SHP9500, V-Moda BoomPro, Sybasonic Better Connectivity USB DAC/Amp
Power Supply EVGA SuperNOVA G3 80+ Gold 750W
Mouse Glorious Model D Wireless
Keyboard Custom Qwertykeys Navy QK80: Sarokeys Strawberry Wine switches, GMK CYL DMG3 keycaps
Would you rather pay $25 for a POS PSU and then another $300 for a new 2060 and $110 for a new mobo, or pay $50 for a less POS PSU?
Rei
656 (0.45/day)
Guam
System Name 1 Desktop/2 Laptops/1 Netbook
Processor AMD Athon X2 64/Intel Pentium 997/Intel Pentium 4/Intel Atom
Motherboard EpoX ATX motherboard/Samsung/Toshiba/Lenovo
Cooling Stock
Memory 4 GB/4 GB/2 GB/2 GB
Video Card(s) Asus GeForce GTX 780 Ti/Intel HD Graphics/GeForce 4MX/Intel GMA
Storage 6+ TB Total
Display(s) HP Pavilion 14 Inch 1024x768@60Hz 4:3 Aspect Ratio CRT Monitor
Case None
Audio Device(s) Various
Power Supply Seasonic 500 Watt & VenomRX 500 Watt
Mouse Wayes Iron Man Wireless Mouse
Keyboard Rexus VR2 Wireless Keyboard
Software Win10 & WinXP SP3
Benchmark Scores It sucks...
Why this PSU specifically? Is it for some sort of review or just cuz its the cheapest, most readily available PSU?
As others have pointed out, it doesn't seem have the connector for your GPU unless you won't be powering your GPU. If its just powering on your motherboard & nothing more, then that PSU should do the job just fine albeit without the use of your GPU.
It is pretty costly though just to power up your motherboard, so you should just borrow from a friend or some other.
Also, does your motherboard/chipset/CPU comes with an integrated GPU?
