Win 11 won't boot, need help!
148 (0.04/day)
Processor Amd Ryzen 7 Pro 1700@3.6Ghz
Motherboard Asus Prime B350 Plus (needed pci slot for Ht Omega Claro Halo)
Cooling Noctua C-14
Memory 16GB A-Data DDR4-3200
Video Card(s) AMD Radeon Pro Duo
Storage Patriot Torch 512gb, Seagate Barracuda 512gb , Adata 128gb SSDs & 1TB Western Digital Black
Display(s) Seiki 39" 4k
Case MetallicGear Neo Air
Audio Device(s) Ht Omega Claro Halo
Power Supply Rosewill Glacier 850 watts
Mouse Ancient Razor Diamondback
Keyboard Logitech Illuminated
Software Windows 10 Home 64-Bit
Did a ssd upgrade on my laptop from a mechnical drive. I'm getting error code 0xc0000225 - a required device isn't connected or can't be accessed.
HP Model-ca10007ca
Toothless
Tech, Games, and TPU!
9,513 (2.49/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x32 Corsair Dominator
Display(s) Acer Nitro XZ342CK Pbmiiphx + 2x AOC 2425W
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Reinstall OS.
41,314 (6.58/day)
There weren't any other hdds/ssds attached alongside the newdrive when windows was installed correct?
This link goes to microsoft for your error code, I'm not sure why it appears as redirecting...
1,357 (0.30/day)
Processor i7-13700k
Motherboard Asus Tuf Gaming z790-plus
Cooling Coolermaster Hyper 212 RGB
Memory Corsair Vengeance RGB 32GB DDR5 7000mhz
Video Card(s) Asus Dual Geforce RTX 4070 Super ( 2800mhz @ 1.0volt, ~60mhz overlock -.1volts)
Storage 1x Samsung 980 Pro PCIe4 NVme, 2x Samsung 1tb 850evo SSD, 3x WD drives, 2 seagate
Display(s) Acer Predator XB273u 27inch IPS G-Sync 165hz
Power Supply Corsair RMx Series RM850x (OCZ Z series PSU retired after 13 years of service)
Mouse Logitech G502 hero
Keyboard Logitech G710+
Did you clone the drive or install windows on to it? If you pulled the old 1tb out and put the SSD in and nothing more well you put a blank drive in hence the problem.
